[Qgis-user] Finding a flat spot
Simon Dietmann
dietmann at pgnu.de
Tue Oct 21 23:30:59 PDT 2025
Hi Morgan,
to achieve this, you need a digital elevation model (DEM) with a resolution that is not too coarse. I don´t know where you are located or what your area of interest is, so I can´t tell where you might get it.
Once you have your DEM, you can use raster functions like roughness, inclination or topographic position index to identify your spots.
Hope that helps, regards
Simon
Von: QGIS-User <qgis-user-bounces at lists.osgeo.org> Im Auftrag von Morgan Fletcher via QGIS-User
Gesendet: Mittwoch, 22. Oktober 2025 02:28
An: qgis-user at lists.osgeo.org
Betreff: [Qgis-user] Finding a flat spot
I use qgis mostly for visualizing gpx tracks, georeferencing old maps, drawing vectors to reveal or highlight information related to a map or physical location.
I have a real-world need, a wish list item, and I wonder if QGIS might be able to solve it.
I want to know where the flat spots are. Given a bounded area on a map, could I ask QGIS to find me all locations that are at least 100 square feet, with less then 1' vertical delta across that space? Yes, I'm trying to find flat camping spots.
Morgan
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20251022/d92cee14/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20251022/d92cee14/attachment.png>
More information about the QGIS-User
