[Qgis-user] Image import
Rock Orpheus
orlibohrer at gmail.com
Thu Sep 18 06:15:15 PDT 2025
Hello,
I am trying to create a project for creating land registers with
images referenced to GPS points obtained using QField. I am using
QFieldCloud for communication between QGIS and QField. The project was
working until Monday, September 15, but now QField can no longer read
the images. The Shapefile table settings should be correct, with the
image field set to attachment and the path set to relative to the
project. The camera icon appears on QField, and the phone's camera
opens, but the field remains empty. I also tried de-versioning the
application and the QFieldSync plugin, but nothing changed. I also
tried creating a GeoPackage project.
I noticed that the DCIM folder is no longer created in the project
folders, but even when I create it manually, the images are not saved.
The problem also occurs with old projects that I had no problems with before.
What can I do?
Thank you for your help
More information about the QGIS-User
