[Qgis-user] QGIS2web crash
Andreas Neumann
a.neumann at carto.net
Mon Sep 29 23:07:44 PDT 2025
Hi Steve,
QGIS2web is a Python plugin, not officially supported by QGIS.
In such a case you should reach out to the plugin author (or team). See
https://github.com/qgis2web/qgis2web for more details. They also have an
issue tracker at Github for their plugin.
Hopefully this helps to reach out to the ones who could probably help.
Andreas
On 2025-09-30 00:42, Stephen Sacks via QGIS-User wrote:
> QGIS2web problem.
> My map has two layers (trees and shrubs). If both layers use a single
> svg marker everything looks as it should, both on my desktop and when I
> export to the web (Leaflet). But if one layer (shrubs) uses
> categorized svg markers then qgis2web crashes when I click Export (see
> attached error message). The crash occurs even if all six categories
> use the same svg file (which is the same svg which works smoothly in
> the single marker, i.e., not-categorized, case). The error message says
> can't find 'chosen/ShrubPoss1_green.svg' , which is a reference to a
> folder and file which I had used earlier but don't use now. I
> recreated both the folder and the file just so they can satisfy some
> software bug that failed to clear some buffer, but that does solve my
> problem.
> I'm using QGIS2web(version 3.29.0) and running QGIS v3.40.10 Bratislava
> on Windows 11.
> Any advice would be most welcome. Thanks in advance for your time.
> Steve
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20250930/65ff5b77/attachment.htm>
More information about the QGIS-User
