[Qgis-user] Please help me
平田亜沙代
ashayo.hirata at gmail.com
Wed Apr 1 08:09:20 PDT 2026
I am working with shapefile data from a Geoportal, which I imported into
QGIS and then exported as a DXF file.
When I import this DXF into Allplan, I get errors when using certain
architectural tools (e.g., updating architectural elements fails with
inconsistency errors).
Could you please help me identify the issue?
I suspect the problem might be related to the DXF export settings or the
geometry quality from QGIS.
that in Allplan said. *"he last action could not be executed due to
inconsistencies while updating architectural components.*
*The problematic area is indicated by a blinking hatch. **Press the ESC key
to stop the blinking and continue your work as usual."*
[image: 2.png]
[image: 1.png]
[image: 3.png]
*"he last action could not be executed due to inconsistencies while
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260401/514ca98b/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260401/514ca98b/attachment-0003.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260401/514ca98b/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260401/514ca98b/attachment-0005.png>
More information about the QGIS-User
