[Qgis-user] Please help me Nr.2
ramon
custard at thornbill.net
Mon Apr 6 22:58:29 PDT 2026
Likely there’s a better way, but I’d use the Field Calculator.
1. The icon looks a bit like an abacus, and you can find it at the top of the map window and at the top of the attribute window.
2. To work only on your selected features, select the box
3. You want to update an existing field - from NULL to your value
4. Select the field that you want to work on.
5. Enter in here the value, ’string’, or expression you want in the selected fields.
This is a useful and powerful tool - but if you don’t make sure that it’s only working on the selected fields (2) it will work on all the entries in the field, and you’ll need to rollback.
> On 19 Mar 2026, at 1:04 am, 平田亜沙代 via QGIS-User wrote:
> I would like to create a land use plan (Flächennutzungsplan) in QGIS. For this purpose, I intend to add a new field named "Nutzung" to the attribute table of the cadastral dataset and populate it accordingly.
> Would it be possible to assign text to the "Nutzung" field for multiple selected areas at once?
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260407/afbb9f67/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260407/afbb9f67/attachment-0001.png>
More information about the QGIS-User
