[Qgis-user] sharing project with pg user and ssl connection
damien stephens damien.stephens at gmail.com
Mon Aug 17 06:04:46 PDT 2026
trap for new players connecting arcgis to postgres. both table names,
fieldnames and user names need to be lowercase.
also you can't edit postgres tables in arc.
On Fri, 14 Aug 2026, 17:44 Greg Troxel via QGIS-User, <
qgis-user at lists.osgeo.org> wrote:
> Namik SCHERZL - SLA via QGIS-User <qgis-user at lists.osgeo.org> writes:
> > In my structure we are currently migrate our GIS architecture from
> > ESRI to Qgis & Postgres.  We would like to know the most recommended
> > method for authenticating PG via Qgis knowing that :
> Stepping back, the issue here is that your requirements are not at all
> defined.  I've reordered your message.
> > * Securing the data flow.
> "Securing the data flow" doesn't really say anything.  My own view is
> that there is little justification for transmitting (nonpublic) data
> across computers, unless protected by ssh, TLS, or similar.  CPUs are
> fast, and the cost of encryption/decryption and authentication is surely
> small compared to the processing of that data.  If you see it
> differently, please run tests and post a description of them and
> results.
> In particular, if you are controlling access to a resource with a
> password, I do not see it has responsible to transmit that password in
> cleartext connections even on your LAN that you think is ok, but surely
> is not reliably ok, in that proving that no device is compromised
> (including thermostats) is nearly impossible.  Thus, I advise you to
> forget the concept of non-TLS cross-machine database access.
> > * We want to avoid transmitting login / password information between
> > users of the same project.
> I can't understand this.
> I think you are blurring granting database access to particular people,
> and granting database access to QGIS projects.  Standard security
> practice is concerned about people (or some machine notion of principal,
> also), and QGIS projects are data files.  You further should be
> controlling access to the QGIS project in its own right, and embedding
> credentials in projects and then relying on project control sounds
> unreasonably risky.
> Once you decide to control access by people, you can either create a
> database account for each authorized user and assign them separate
> passwords, or you can create a group account with one username/password
> and give that to all the authorized people.  I think you said that you
> don't want shared credentials.
> If you have obligations to anyone else about the data -- non-disclosure
> agreements, information subject to GDPR, a requirement that data only be
> modified by authorized persons, etc., then I don't see shared
> credentials as responsible.  (Yes, I know doing it right is harder; that
> doesn't change the analysis of what is ok.)
> > * we are keeping a few Arcgis licences, and they should have access to
> the DB
> The licenses, or people who are using Arggis?  Surely arcgis can access
> postgis and the user can have a username/password.
> > I've seen that Qgis can store PG login and password in it's own local
> > storage and in the case we define a common authcfg ID for all our
> > users it's possible for several users to share the same project
> > without transferring any information/ rights.
> I'm having trouble following.  If you mean that qgis can separate the
> config of "where is the datbase" keeping that in the project, while
> using other means (OS credentials storage) to store "for this databsae,
> use this username and that password", that makes sense.
> But the first thing to be clear on is whether you are using individual
> username/password, and if you have a security or integrity requirement
> to avoid group credentials.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260817/c6d817e7/attachment.htm>
More information about the QGIS-User mailing list
