[Qgis-user] Custom attribute form
Müller, Jannik J.Mueller at kreis-olpe.de
Mon Feb 2 03:07:08 PST 2026
Hello everyone,
I'm trying to create a custom attribute form for a project with the Qt-Designer. I'm able to load the .ui-file and load all the required fields. However, the project contains a few 1:N relations which I'm unable to get working with the custom UI. These relations work correctly in the autogenerated form.
I have a relation with the following name and id:
[cid:image003.png at 01DC943B.3E799910]
In the Qt-Designer I created a QgsRelationEditorWidget and set the objectName to the id of the relation:
        [cid:image004.png at 01DC943C.72E4FB30]
Am I missing something, or are there some other points i need to consider when setting up a custom relation like this?
Additionally, it seems the form i created is not "connected" to the dialog. If I change the size of the dialog, the form is not responsive. I would expect it to have like a srcollbar or something. Is there some specific configuration I need to apply to get this working?
Best regards,
Jannik
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260202/f7726f1a/attachment-0001.htm>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260202/f7726f1a/attachment-0003.png>
Type: image/png
Desc: image003.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260202/f7726f1a/attachment-0004.png>
Type: image/png
Desc: image004.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260202/f7726f1a/attachment-0005.png>
More information about the QGIS-User mailing list
