[Qgis-user] Adding points as seperate layers
Ludwig Kniprath ludwig at kni-online.de
Mon Feb 9 14:18:39 PST 2026
Hi Mike,
there are probably several solutions for your problem. Below a script,
which uses the imported csv-layer and creates a memory layer for each
feature.
# active-layer = csv-import-layer
vl = iface.activeLayer()
# the group for the single-point layers in Layer-Panel
target_group = QgsProject.instance().layerTreeRoot().addGroup('group_1')
# iterate through the csv-import-layer
for f in vl.getFeatures():
     # create a clone of this layer with only one feature
     vl_clone = vl.materialize(QgsFeatureRequest().setFilterFids([f.id()]))
     # set the name for the new layer, here using the attribute 'name'
of the csv-import-layer
     # adapt if necessary or create another name
     vl_clone.setName(f['name'])
     # parameter 2 False => dont't add to layerTreeRoot...
     QgsProject.instance().addMapLayer(vl_clone,False)
     # ...but to the above created group
     target_group.insertLayer(-1, vl_clone)
Note: the script creates temporary memory-layers, which you must convert
to permanent layers (context-menu > Make Permament)
hth
Ludwig
Am 09.02.26 um 21:37 schrieb ERT - Mike Breiding via QGIS-User:
> Greetings,
> I was successful in adding lat/long points to my project from a .cvs
> file:
> Lat,Long,Mile
> -79.924454,39.709589,M 1
> -79.936296,39.698546,M 2
> -79.939802,39.68499,M 3
> etc.
> When the points are added to my project all the of them are in one
> layer that contains all the points.
> I wish to have all the points as separate layers contained in a Group.
> How can I accomplish this?
> Thanks,
> WV-Mike
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
More information about the QGIS-User mailing list
