[Qgis-user] Adding points as seperate layers
chris hermansen clhermansen at gmail.com
Tue Feb 10 16:48:11 PST 2026
Mike and list;
On Tue, Feb 10, 2026 at 4:59 AM ERT - Mike Breiding via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> On 2/9/2026 8:44 PM, David Strip wrote:
> placing each point on a separate layer seems unusual. Can you tell us why
> you want to do this?
> Hello Dave,
> There are 29 points representing mile markers on a local Rail-Trail.
> I would like to be able to style some markers differently from the others.
Mike, you can style points (lines, polygons) according to an attribute
value, no need for separating them by layers.
In Layer Properties > Symbology screen three is a drop-down at the top that
lets you do all kinds of selective symbolization.
Probably in your case you want to use Categorized.  Then you would select
an attribute value in the Value field.  You can classify as well, for
instance if you have a continuous attribute that you want to turn into
discrete classes.
Chris Hermansen · clhermansen "at" gmail "dot" com
C'est ma façon de parler.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260210/b2b732f2/attachment.htm>
More information about the QGIS-User mailing list
