[Qgis-user] Adding points as seperate layers
ERT - Mike Breiding epicroadtrips at gmail.com
Wed Feb 11 06:50:54 PST 2026
Greetings, David.
I followed your instructions and I am making some progress. I now have
two categories with individual symbologies for the Mile Marker point layer.
However, there seems to be a problem with my CSV file or something else.
The layer is not displaying the first Mile Marker point and I cannot see
why.
The first point displayed is M2, not M1.
Here are the beginning entries in the CSV file
Lat                 Long               Mile    Style
-79.92445    39.70958         M 1    1
-79.936296    39.698546    M 2    1
-79.939802    39.68499      M 3    1
-79.958298    39.683171     M 4    2
The layer does not display M1. The first point displayed is M2.
I verified M1 coordinates are correct.
There are screen shots here:
https://photos.app.goo.gl/UuBvw1Y6XNNahb5aA
Any idea of what the problem might be.
Thanks,
WV-Mike
On 2/10/2026 10:31 PM, David Strip wrote:
> You can style markers differently, even if they are in the same layer.
> I would add a new integer column to the CSV file "style". Points that
> are to receive the same styling get the same integer value. For
> example, red markers are 1, blue are 2, etc. Or square are 1, round
> are 2, etc. Then in the properties->symbolize tab, select
> "Categorized" for the styling method, and select the new style field
> for value. Then set the style for each category.
> I think this approach has two advantages:
> 1. Easier import of the point
> 2. Better control over grouping points with similar styling.
> There are probably other, perhaps more powerful ways that someone else
> can suggest.
> On 2/10/2026 5:58 AM, ERT - Mike Breiding wrote:
>> On 2/9/2026 8:44 PM, David Strip wrote:
>>> placing each point on a separate layer seems unusual. Can you tell
>>> us why you want to do this?
>> Hello Dave,
>> There are 29 points representing mile markers on a local Rail-Trail.
>> I would like to be able to style some markers differently from the
>> others.
>> Thanks,
>> -Mike
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260211/111e60fc/attachment-0001.htm>
More information about the QGIS-User mailing list
