[Qgis-user] Adding points as seperate layers
ERT - Mike Breiding
epicroadtrips at gmail.com
Wed Feb 11 13:35:32 PST 2026
> In your categorization in the symbology tab, you appear to have
> deleted the "all others" category.
I added it back in. Thanks for the tip.
WV-Mike
On 2/11/2026 2:26 PM, David Strip wrote:
> On 2/11/2026 10:46 AM, ERT - Mike Breiding via QGIS-User wrote:
>> I changed the import CSV settings and that solved the problem.
>> Please take a look and let me know if there is anything else I should
>> pay attention to. I was not sure what to select in the "Geometry CRS"
>> option.
>> https://photos.app.goo.gl/xQBqLq9QX3fSJ43C8
> deleted the "all others" category. This means that if you add points
> with a category not already in the list the points won't appear,
> leaving you totally baffled as to where they went. This only really
> matters if you save the styling from this layer and attempt to apply
> it to another set of points in this or another map.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260211/504c32d1/attachment.htm>
More information about the QGIS-User
