[Qgis-user] Merge feature toll
Richard Greenwood richard.greenwood at gmail.com
Sat Feb 14 05:13:59 PST 2026
You need to have two or more features *on the same layer* selected.
On Fri, Feb 13, 2026 at 3:28 PM ERT - Mike Breiding <epicroadtrips at gmail.com>
wrote:
> I thought I would give the "Merge Selected Features" tool a try.
> But, when I selected the two layers, and toggle editing, the "Merge
> Selected Features" icon is greyed out.
> Screenshot:
> https://photos.app.goo.gl/jZGYruUHm1JkcgTz6
> Thanks,
> WV-Mike
> qgis merge two lines - Google Search
> <https://www.google.com/search?q=qgis+merge+two+lines&oq=qgis+merge+two+lines&gs_lcrp=EgRlZGdlKgYIABBFGDkyBggAEEUYOTIICAEQABgWGB4yCAgCEAAYFhgeMggIAxAAGBYYHjIHCAQQABjvBTIHCAUQABjvBdIBCDU2MjJqMGo0qAIAsAIB&sourceid=chrome&ie=UTF-8>
> On 2/13/2026 9:37 AM, Richard Greenwood wrote:
> The "Merge Selected Features" tool does not alter the geometries. I takes
> two or more geometries and combines them into a new single "multi"
> geometry. For example of you have two features in your layer that are two
> separate records and you merge them you'll now have just one record for
> that feature. Maybe you have a highway with two separated lanes and
> you want to both lanes show as separate lines but in the data you only want
> one record, then you would use the "Merge Selected Features" tool.
> On Fri, Feb 13, 2026 at 8:00 AM ERT - Mike Breiding via QGIS-User <
> qgis-user at lists.osgeo.org> wrote:
>> Greetings,
>> I am trying to merge/connect two lines.
>> When I select the lines, I choose the Merge tool and choose OK.
>> But, the lines do not connect.
>> Screenshot:
>> https://photos.app.goo.gl/wh7MuSSTBvjb1eyd7
>> Am I going about this the correct way?
>> Thanks,
>> WV-Mike
>> QGIS version 3.28.4-Firenze
>> WIN 11
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Richard W. Greenwood
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260214/39e40df0/attachment-0001.htm>
More information about the QGIS-User mailing list
