[Qgis-user] Not able to open qt designer after installing qgis via OSGeo4W
Jochem Kail
jochem.kail at uni-due.de
Mon Feb 16 01:17:47 PST 2026
Dear Andrea,
The following Windows version is installed on my computer: Microsoft
Visual C++ 2015-2022 Redistributable (x64) - 14.36.32532
The workaround you suggested solved the problem! On my computer
msvcp140.dll was located in OSGeo4W\bin and I copied it to
OSGeo4W\apps\Qt5\bin.
As an alternative, Thomas Nogatz suggested the following, which also
worked: Start the OSGeo4W shell (type "OSGeo..." in Windows search). In
the shell, enter "designer and press enter.
Many thanks!
Jochem
Am 16.02.2026 um 09:17 schrieb Andrea Giudiceandrea via QGIS-User:
> Hi Jochem,
> it looks like the issue may be related to the Microsoft Visual C++
> Redistributable version installed in your (and my) Windows system.
> Could you please indicate the version of the latest Microsoft Visual
> C++ Redistributable installed in your system?
> To workaround the issue, you could copy the file msvcp140.dll from
> apps\bin to apps\qt5\bin.
> Then you should launch the Qt Designer normally from the shortcut link
> icon "Qt Designer with QGIS ... custom widgets".
> Regards.
> Andrea
> Il 16/02/2026 07:27, Jochem Kail ha scritto:
>> Dear Andrea,
>> many thanks for replying. Yes, there is a report stating that
>> designer.exe resulted in an error.
>> Error code 0xc0000005, error offset 0x0000000000012f58, error
>> process-ID, 0x204C, error path ...\OSGeo4W\apps\qt5\bin\designer.exe,
>> error module C:\WINDOWS\SYSTEM32\MSVCP140.dll
>> Best regards
>> Jochem
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
sent from my R2 unit
Jochem Kail
Dr. rer. nat.
University of Duisburg-Essen
Faculty of Biology
Department of Aquatic Ecology
Universitätsstrasse 5
D-45141 Essen
Germany
Room S05T03B08
Tel: +49.201.183.3046
Tel: +49.228.44636.33
Fax: +49.201.183.2179
http://www.uni-due.de/aquatic_ecology/staff/kail.shtml
Important note: The university server does not accept old Microsoft Office files (e.g. *.doc) but only the recent version (e.g. *.docx)!
More information about the QGIS-User
