[Qgis-user] GRASS Tools give error message using the GRASS GIS Processing Provider
Andrea Giudiceandrea
andreaerdna at libero.it
Tue Feb 17 05:23:43 PST 2026
Ah... you can obviously also fix the issue coping the file msvcp140.dll
from
bin\ to apps\grass\grass84\bin, similarly to the way you've fixed the Qt
Designer issue.
Regards.
Andrea
> Andrea Giudiceandrea andreaerdna at libero.it
> Tue Feb 17 04:47:12 PST 2026
> Hi Jochem,
> the issue is due to the same root cause of the issue about Qt Designer
> you previously reported.
> In fact, you will find the report of v.external.exe and v.out.ogr.exe crash
> related to MSVCP140.dll in the Windows tool "Event Viewer" -> "Windows
> Logs" -> "Application".
> You should be able to fix both the issues on your system just updating
> the Microsoft Visual C++ Redistributable to the latest version provided
> by Microsoft Windows.
More information about the QGIS-User
