[Qgis-user] Coordinate transformations
Antonio Valanzano anvalanz at gmail.com
Sun Feb 22 09:01:32 PST 2026
Hi David,
the sql script that have used in DB Manager and has produced one of the
results listed in the table is the following one:
SELECT AsEWKT ( ST_Transform( MakePoint( 541000 , 4516000 , 23033 ) , 25833
As you can see I am not using any grid file to increase the precision of
the transformation, so I expected the same results of the "export layer"
method.
There should be something in the way the Prog lib is called by QGIS in the
two different contexts.
I hope this helps to better understand the question.
Antonio
Il giorno sab 21 feb 2026 alle ore 16:43 Antonio Valanzano <
anvalanz at gmail.com> ha scritto:
> I have tried to transform the coordinates of a single point (541000,
> 4516000) with epsg:23033 into 2 other coordinate systems (epsg:25833 e
> 6708).
> I have done these transformations using 2 different methods: DB Manager
> (with an sql script)  and export layer.
> However the results of these transformations are different.
> I know that DB Manager uses the Spatialite engine for processing the sql
> script and the results are the same as those obtained using Spatialite or
> PostGIS (both based on Proj lib).
> I do not know how the export layer method produces the results.
> I expected the same results but this is not true.
> Does someone know more detailed information about this subject ?
> Here the details of the transformations
>  Punto di partenza ED50/UTM zone 33N (epsg:23033)
> X Y
> 541000 4516000
> da 23033 a 25833 (ETRS89/UTM zone 33N)
> X_Spatialite 540998,138333   Y_Spatialite 4515921,565375
> X_PostGIS 540998,138333   Y_PostGIS 4515921,565375
> X_QGIS_DB_Manager 540998,138333   Y_QGIS_DB_Manager 4515921,565375
> X_QGIS_export_layer 540931,341497   Y_QGIS_export_layer 4515810,597826
> da 23033 a 3065  (IGM95/UTM zone 33N)
> X_Spatialite 540927,563731   Y_Spatialite 4515811,141068
> X_PostGIS 540927,563731   Y_PostGIS 4515811,141068
> X_QGIS_DB_Manager 540927,563731   Y_QGIS_DB_Manager 4515811,141068
> X_QGIS_export_layer 540998,138333   Y_QGIS_export_layer 4515921,565375
> da 23033 a 6708  (RDN2008/UTM zone 33N)
> Thanks in advance
> Antonio Valanzano
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260222/aedfd79f/attachment-0001.htm>
More information about the QGIS-User mailing list
