[Qgis-user] Cannot find the QT designer in MacOS.
jacob chaar jacobchaar at live.ca
Tue Feb 24 07:34:57 PST 2026
Hello everyone,
I am currently maintaining a QGIS plugin and would like to add a new Qt dialogue to it.
I have been reading some Stack Overflow questions about how to enable the Qt Designer in QGIS. Most of them are saying that you can open the Designer app via /Applications/QGIS.app/Contents/MacOS/bin
However, after installing the QGIS app (master and latest official version 3.44), the bin directory does not exist. If I type the ls command:
-rwxr-xr-x@ 1 jacobchaar  admin   243744 Feb 21 07:13 crssync
lrwxr-xr-x  1 jacobchaar  admin       30 Feb 21 07:14 gdal_calc -> ../Resources/scripts/gdal_calc
lrwxr-xr-x  1 jacobchaar  admin       33 Feb 21 07:14 gdal_calc.py -> ../Resources/scripts/gdal_calc.py
-rwxr-xr-x@ 1 jacobchaar  admin   528768 Feb 21 07:13 gdal_contour
-rwxr-xr-x@ 1 jacobchaar  admin   632416 Feb 21 07:13 gdal_create
lrwxr-xr-x  1 jacobchaar  admin       30 Feb 21 07:14 gdal_edit -> ../Resources/scripts/gdal_edit
lrwxr-xr-x  1 jacobchaar  admin       33 Feb 21 07:14 gdal_edit.py -> ../Resources/scripts/gdal_edit.py
lrwxr-xr-x  1 jacobchaar  admin       36 Feb 21 07:14 gdal_fillnodata -> ../Resources/scripts/gdal_fillnodata
lrwxr-xr-x  1 jacobchaar  admin       39 Feb 21 07:14 gdal_fillnodata.py -> ../Resources/scripts/gdal_fillnodata.py
-rwxr-xr-x@ 1 jacobchaar  admin   529792 Feb 21 07:13 gdal_footprint
-rwxr-xr-x@ 1 jacobchaar  admin   528768 Feb 21 07:13 gdal_grid
lrwxr-xr-x  1 jacobchaar  admin       31 Feb 21 07:14 gdal_merge -> ../Resources/scripts/gdal_merge
lrwxr-xr-x  1 jacobchaar  admin       34 Feb 21 07:14 gdal_merge.py -> ../Resources/scripts/gdal_merge.py
lrwxr-xr-x  1 jacobchaar  admin       36 Feb 21 07:14 gdal_pansharpen -> ../Resources/scripts/gdal_pansharpen
lrwxr-xr-x  1 jacobchaar  admin       39 Feb 21 07:14 gdal_pansharpen.py -> ../Resources/scripts/gdal_pansharpen.py
lrwxr-xr-x  1 jacobchaar  admin       36 Feb 21 07:14 gdal_polygonize -> ../Resources/scripts/gdal_polygonize
lrwxr-xr-x  1 jacobchaar  admin       39 Feb 21 07:14 gdal_polygonize.py -> ../Resources/scripts/gdal_polygonize.py
lrwxr-xr-x  1 jacobchaar  admin       35 Feb 21 07:14 gdal_proximity -> ../Resources/scripts/gdal_proximity
lrwxr-xr-x  1 jacobchaar  admin       38 Feb 21 07:14 gdal_proximity.py -> ../Resources/scripts/gdal_proximity.py
-rwxr-xr-x@ 1 jacobchaar  admin   529584 Feb 21 07:13 gdal_rasterize
lrwxr-xr-x  1 jacobchaar  admin       32 Feb 21 07:14 gdal_retile -> ../Resources/scripts/gdal_retile
lrwxr-xr-x  1 jacobchaar  admin       35 Feb 21 07:14 gdal_retile.py -> ../Resources/scripts/gdal_retile.py
lrwxr-xr-x  1 jacobchaar  admin       31 Feb 21 07:14 gdal_sieve -> ../Resources/scripts/gdal_sieve
lrwxr-xr-x  1 jacobchaar  admin       34 Feb 21 07:14 gdal_sieve.py -> ../Resources/scripts/gdal_sieve.py
-rwxr-xr-x@ 1 jacobchaar  admin   531200 Feb 21 07:13 gdal_translate
-rwxr-xr-x@ 1 jacobchaar  admin   593872 Feb 21 07:13 gdal_viewshed
lrwxr-xr-x  1 jacobchaar  admin       31 Feb 21 07:14 gdal2tiles -> ../Resources/scripts/gdal2tiles
lrwxr-xr-x  1 jacobchaar  admin       34 Feb 21 07:14 gdal2tiles.py -> ../Resources/scripts/gdal2tiles.py
lrwxr-xr-x  1 jacobchaar  admin       29 Feb 21 07:14 gdal2xyz -> ../Resources/scripts/gdal2xyz
lrwxr-xr-x  1 jacobchaar  admin       32 Feb 21 07:14 gdal2xyz.py -> ../Resources/scripts/gdal2xyz.py
-rwxr-xr-x@ 1 jacobchaar  admin   629728 Feb 21 07:13 gdaladdo
lrwxr-xr-x  1 jacobchaar  admin       34 Feb 21 07:14 gdalattachpct -> ../Resources/scripts/gdalattachpct
lrwxr-xr-x  1 jacobchaar  admin       37 Feb 21 07:14 gdalattachpct.py -> ../Resources/scripts/gdalattachpct.py
-rwxr-xr-x@ 1 jacobchaar  admin   529232 Feb 21 07:13 gdalbuildvrt
lrwxr-xr-x  1 jacobchaar  admin       32 Feb 21 07:14 gdalcompare -> ../Resources/scripts/gdalcompare
lrwxr-xr-x  1 jacobchaar  admin       35 Feb 21 07:14 gdalcompare.py -> ../Resources/scripts/gdalcompare.py
-rwxr-xr-x@ 1 jacobchaar  admin   529136 Feb 21 07:13 gdaldem
-rwxr-xr-x@ 1 jacobchaar  admin   548576 Feb 21 07:13 gdalenhance
-rwxr-xr-x@ 1 jacobchaar  admin   529936 Feb 21 07:13 gdalinfo
-rwxr-xr-x@ 1 jacobchaar  admin   613264 Feb 21 07:13 gdallocationinfo
-rwxr-xr-x@ 1 jacobchaar  admin   550368 Feb 21 07:13 gdalmanage
-rwxr-xr-x@ 1 jacobchaar  admin   528656 Feb 21 07:13 gdalmdiminfo
-rwxr-xr-x@ 1 jacobchaar  admin   529056 Feb 21 07:13 gdalmdimtranslate
lrwxr-xr-x  1 jacobchaar  admin       29 Feb 21 07:14 gdalmove -> ../Resources/scripts/gdalmove
lrwxr-xr-x  1 jacobchaar  admin       32 Feb 21 07:14 gdalmove.py -> ../Resources/scripts/gdalmove.py
-rwxr-xr-x@ 1 jacobchaar  admin   547600 Feb 21 07:13 gdalsrsinfo
-rwxr-xr-x@ 1 jacobchaar  admin   528928 Feb 21 07:13 gdaltindex
-rwxr-xr-x@ 1 jacobchaar  admin   547200 Feb 21 07:13 gdaltransform
-rwxr-xr-x@ 1 jacobchaar  admin   530928 Feb 21 07:13 gdalwarp
-rwxr-xr-x@ 1 jacobchaar  admin   547712 Feb 21 07:13 gnmanalyse
-rwxr-xr-x@ 1 jacobchaar  admin   563920 Feb 21 07:13 gnmmanage
-rwxr-xr-x@ 1 jacobchaar  admin   528896 Feb 21 07:13 nearblack
lrwxr-xr-x  1 jacobchaar  admin       38 Feb 21 07:14 ogr_layer_algebra -> ../Resources/scripts/ogr_layer_algebra
lrwxr-xr-x  1 jacobchaar  admin       41 Feb 21 07:14 ogr_layer_algebra.py -> ../Resources/scripts/ogr_layer_algebra.py
-rwxr-xr-x@ 1 jacobchaar  admin   529680 Feb 21 07:13 ogr2ogr
-rwxr-xr-x@ 1 jacobchaar  admin   529552 Feb 21 07:13 ogrinfo
-rwxr-xr-x@ 1 jacobchaar  admin   626512 Feb 21 07:13 ogrlineref
lrwxr-xr-x  1 jacobchaar  admin       29 Feb 21 07:14 ogrmerge -> ../Resources/scripts/ogrmerge
lrwxr-xr-x  1 jacobchaar  admin       32 Feb 21 07:14 ogrmerge.py -> ../Resources/scripts/ogrmerge.py
-rwxr-xr-x@ 1 jacobchaar  admin   608848 Feb 21 07:13 ogrtindex
lrwxr-xr-x  1 jacobchaar  admin       28 Feb 21 07:14 pct2rgb -> ../Resources/scripts/pct2rgb
lrwxr-xr-x  1 jacobchaar  admin       31 Feb 21 07:14 pct2rgb.py -> ../Resources/scripts/pct2rgb.py
-rwxr-xr-x@ 1 jacobchaar  admin  5531984 Feb 21 07:13 pdal_wrench
lrwxr-xr-x  1 jacobchaar  admin       27 Feb 21 07:14 python -> ../Resources/scripts/python
-rwxr-xr-x@ 1 jacobchaar  admin   117744 Feb 21 07:13 python3.12
-rwxr-xr-x@ 1 jacobchaar  admin  1268240 Feb 21 07:14 QGIS
-rwxr-xr-x@ 1 jacobchaar  admin  1281920 Feb 21 07:13 qgis_process
lrwxr-xr-x  1 jacobchaar  admin       28 Feb 21 07:14 rgb2pct -> ../Resources/scripts/rgb2pct
lrwxr-xr-x  1 jacobchaar  admin       31 Feb 21 07:14 rgb2pct.py -> ../Resources/scripts/rgb2pct.py
-rwxr-xr-x@ 1 jacobchaar  admin   591968 Feb 21 07:13 sozip
-rwxr-xr-x@ 1 jacobchaar  admin  5607696 Feb 21 07:13 untwine
Does someone know where to get the Qt Designer app from QGIS? Or should I install it from the Qt website? (How can I add the QGIS widgets?)
Thanks,
Jacob Chaar.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260224/67ab01c9/attachment-0001.htm>
More information about the QGIS-User mailing list
