[Qgis-user] reduce number of open files in pyqgis script
Martin Landa
landa.martin at gmail.com
Fri Jan 2 11:20:50 PST 2026
Dear Greg,
pá 26. 12. 2025 v 16:48 odesílatel Greg Troxel via QGIS-User <
qgis-user at lists.osgeo.org> napsal:
> Looking at your code above, I wonder if the layer returned by clip_layer
> holds a reference to the first argument. (This should be easy to
> understand from code reading).
Yes, it's strange. The number of open files is not increasing when the clip
function is not called:
for sublayer in layers:
name = sublayer.name()
layer = QgsVectorLayer(sublayer.uri(), 'ogr')
del layer
print(name, open_files_count())
In this case only 2 files are open:
ZeleznicniStaniceZastavka 2
ZeleznicniPrejezd_b 2
ZdrojPodzemnichVod 2
I tried to replace clip function:
def clip_layer(layer: QgsVectorLayer, extent: QgsRectangle, layer_name:
str) -> QgsVectorLayer:
extent_geom = QgsGeometry.fromRect(extent)
clipped_layer = QgsVectorLayer(
f"{QgsWkbTypes.displayString(layer.wkbType())}?crs={layer.crs().authid()}",
layer_name,
"memory"
clipped_layer.dataProvider().addAttributes(layer.fields())
clipped_layer.updateFields()
for feature in
layer.getFeatures(QgsFeatureRequest().setFilterRect(extent)):
geom = feature.geometry()
if geom.intersects(extent_geom):
clipped_feature = QgsFeature()
clipped_feature.setGeometry(geom.intersection(extent_geom))
clipped_feature.setAttributes(feature.attributes())
clipped_layer.dataProvider().addFeature(clipped_feature)
clipped_feature = None
clipped_layer.commitChanges()
return clipped_layer
By processing:
clipped_layers = []
# clipped_layer = clip_layer(layer, extent, layer.name())
clipped_layer = processing.run("native:extractbyextent", {
'INPUT': layer,
'EXTENT': extent,
'CLIP': True,
'OUTPUT': 'memory:'
})['OUTPUT']
del layer
if clipped_layer.featureCount() == 0:
del clipped_layer
continue
clipped_layers.append(clipped_layer)
The result is an increasing number of open files again.
ZeleznicniStaniceZastavka 3
ZeleznicniPrejezd_b 4
ZdrojPodzemnichVod 5
I tried to pass the layer name without creating instance of QgsVectorLayer
explicitly:
'INPUT': sublayer.uri(),
'EXTENT': extent,
'CLIP': True,
'OUTPUT': 'memory:'
})['OUTPUT']
But the result is the same - increasing number of open files.
I wonder how it's possible? Thanks for feedback in advance, Martin
Martin Landa
https://geomatics.fsv.cvut.cz/en/employees/martin-landa/
https://gismentors.cz/mentors/landa
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260102/313019d7/attachment.htm>
More information about the QGIS-User
