[Qgis-user] QGIS modeler error message : "Unable to evaluate the expression for the extra parameter : no root node!"
celati Laurent
laurent.celati at gmail.com
Wed Jan 14 01:28:09 PST 2026
Dear all,
I'm working with QGIS 3.4. This is my first QGIS model. I'm facing to an
error message during the running of the modeler. If I understand the error
message, the error seems to occur during the step "D" on my little
screenshot (below) showing the modeler. For information, I've defined a
conditional branch. In addition to the screenshot of the modeler, I paste
also the error message.
Modeler explanation :
- The output of the algorithm A is a raster clipped with a polygon (an
area of interest)
- For the algorithm B (difference vector processing between 2 input
layers), I've setted a dependency so that it only triggers if a condition
is met (we can see the conditional branch 'C' on the screenshot).
- Algorithm D (clip raster with a polygon) takes as input the raster
output/result of the algorithm A. And as a mask layer, the vector result of
algorithm B (difference). For this algorithm D, I've still enable the same
dependency setted for the algorithm B.
- For algorithm E (raster polygonization),we can see there are 2
possible raster inputs. The output of the algorithm A and the output of the
algorithm D. Thus, as input to algorithm E, I set the following expression
(pre-calculated value):
if (@exclude_forest_zones ,
@cut_raster_segmentation_by_mask_vector_NO_foret_OUTPUT ,
@cut_raster_segmentation_by_study_area_vector_OUTPUT)
[image: image.png]
When I run the modeler, I get an error message that seems to be related to
algorithm D. Below is the error message:
"Unable to evaluate the expression for the extra parameter to clip the
raster segmentation by the NO forest mask: no root node! Execution
failed after 8 seconds."
[image: image.png]
For information, I paste below the overview of the algorithm D :
[image: image.png]
And I paste below for information the overview of the algorithm E : As you
can see on the screenshot, I haven't defined any dependencies for algorithm
this algo E.
[image: image.png]
Thanks so much for your valuable help.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260114/4614ab94/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260114/4614ab94/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260114/4614ab94/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260114/4614ab94/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260114/4614ab94/attachment-0007.png>
More information about the QGIS-User
