[Qgis-user] QGIS Modeler: Automatic Deletion/Overwriting of output files (precalculated value)?
Karlo no Dabas maajas karlo at latnet.lv
Mon Jan 26 01:00:09 PST 2026
Hi!
Create an appropriate custom script and add it to the Toolbox. As an
input, the directory name should be used.
The python command could be:
import shutil
shutil.rmtree("path_to_dir")
Any tool from the Toolbox can be used in modeler.
Best regards,
Kārlis
23.01.26 17:48, celati Laurent via QGIS-User rakstīja:
> , it seems that all the contents of the 'intermediate' folder aren't
> really being deleted. This is causing problems when re-running the
> modeler (new settings aren't always being applied to the new version). I
> can't find a tool within the modele that would delete files/folders.So,
> unless I'm mistaken, it seems the only solution would be to add a small
> script at the beginning of the modeler's process that would force the
> deletion of all the folder's contents for the 'intermediate folder: all
> existing files and all folders as well. Does anyone think they could
> point me towards such a script? Many thanks.
More information about the QGIS-User mailing list
