[Qgis-user] no visible layers when consuming WFS service from QGIS Server
Abel Gonzalez
abel.gonzalez.c at gmail.com
Fri Jan 30 07:23:25 PST 2026
Hi Sebastian,
One possible issue is that your MapStore is running on HTTPS while your
QGIS Server is running on HTTP, as shown in your capabilities URL:
http://qgis.lan/qgis_mapserv.fcgi
If both MapStore and QGIS Server are installed on the same server, you
could try using localhost:port instead of domain names. If that works, the
issue may be related to IIS or Apache HTTPD, where DNS and rewrite rules
are configured.
I hope you’re able to resolve the issue.
BR,
Abel
Den fre 30 jan. 2026 kl 15:08 skrev Sebastián Meyer via QGIS-User <
qgis-user at lists.osgeo.org>:
> Hi,
> I configured a context in Mapstore2 to connect to my QGIS Server project
> through WMS and could select layers without any trouble.
> For other projects, I need to use WFS. Mapstore2 seems to work, but this
> time I can't see any layers in the catalog.
> I tried connecting to public WFS services and it works like a charm.
> In my QGIS projects, WFS is enabled (in read-only mode)
> Any idea how may I debug this problem? I attached the QGIS Server's WFS
> answer to this message.
> TIA,
> seb
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260130/ba9874aa/attachment.htm>
More information about the QGIS-User
