[Qgis-user] QGIS 4.0.2 / 4.0.3 macOS: UI language switch broken + menu icons missing (regression from 3.44-Solothurn)
DelazJ
delazj at gmail.com
Tue Jun 2 09:12:16 PDT 2026
Hello,
>--- Menu icons are missing ---
>No icons appear next to items in the menu bar (Project, Layer, Plugins,
>etc.). The menu items themselves work fine, and toolbar icons render
>normally - it's limited to the menu. Again, 3.44.10 is unaffected.
See https://github.com/qgis/QGIS/issues/64829
Regards,
Harrissou
>--- Environment ---
>OS: macOS Sequoia 15.7.7 (24G720)
>QGIS: 4.0.2 and 4.0.3 (both affected)
>Ref: 3.44.10-Solothurn (8f54b795) - not affected
>Install: qgis.org .dmg and Homebrew (both tested, identical result)
>Profile: fresh install, no existing profile reused
>Does anyone know what changed between 3.44 and 4.0 on the macOS packaging
>side that might explain either of these?
More information about the QGIS-User
