[Qgis-user] Issue with installing SAGA plugin in QGIS 3.44 version software
Nagachaitra N nagachaitra at pemsconsultants.com
Tue Jun 2 23:36:23 PDT 2026
Dear QGIS Community,
I hope this email finds you well.
I am writing to seek assistance with an issue I am encountering while trying to use SAGA (System for Automated Geoscientific Analyses) tools within QGIS.
Specifically, I am using QGIS version 3.44, and I am having trouble getting the SAGA plugin/provider to install and function correctly within the Processing Toolbox.
issue:
  *   Operating System:  Windows 11
  *   QGIS Version: 3.44
  *   SAGA Version: 9.12.4
  *   Error Message / Behavior: while trying to add zip file, it is showing Zip file is not valid QGIS python plugin. No root folder was found inside.
Steps I have already tried:
  *   Checking the Processing options paths under Settings -> Options -> Processing -> Providers.
  *   Looking for the "Processing SAGA NextGen Provider" plugin in the Plugin Manager.
Tried inserting in zip file.
Since SAGA’s terrain analysis tools are critical for my current workflow, any guidance on how to properly configure SAGA with QGIS 3.44—or advice on the current recommended workaround plugin—would be greatly appreciated.
Thanks and regards,
            Nagachaitra N
            PEMS Engineering Consultants Pvt Ltd
            Bengaluru, Karnataka - 560043
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260603/10ce8d8e/attachment.htm>
More information about the QGIS-User mailing list
