[Qgis-user] Coordinates Reprojection
Andrea Giudiceandrea
andreaerdna at libero.it
Thu Jun 11 17:35:39 PDT 2026
Il 11/06/2026 19:41, Abel Chikoore ha scritto:
> 3) For projection: i go to the LAYERS PANEL and right click on the CSV
> Collars Layer. The i chose EXPORT- the SAVE FEATURES AS.....please
> attachments for what i get.
> 4) The Save Error i get is for the First Row of my Cordinates.
Hi Abel,
I understand that you have eventually managed to find the "WGS 84 / UTM
zone 35S" CRS that you didn't find before. Is it correct?
Anyway, I suppose you have imported a CSV file as a vector layer using
the Data Source Manager -> Delimited Text dialog window, selecting the X
field and the Y field of you CSV file containing the points' coordinates
and then the CRS of such coordinates. Could you confirm?
If it is so, what are the coordinates of a sample point contained in
your CSV file? What CRS have you selected in the Data Source Manager ->
Delimited Text when you have imported the CSV file as a vector layer?
The error message states that the coordinates of a point contained in
the vector layer that you want export to a GeoPackage file are
291235.14000, -260651.250000 and that such vector layer has been set to
CRS EPSG:4326.
If it is so, then I guess you have wrongly set the CRS of the vector
layer, imported from a CSV file, to EPSG:4326: such coordinates are
obviously not referred to the EPSG:4326, which is a geographic
coordinate system in degrees corresponding to Longitude and Latitude,
whereas the above-mentioned coordinates doesn't correspond to Longitude
and Latitude in degree.
Regards.
Andrea
More information about the QGIS-User
