[Qgis-user] Reproject from WGS84 (EPSG: 4326) to ETRS89/UTM32N (EPSG: 25832) considering the epoch
Jochem Kail jochem.kail at uni-due.de
Fri Jun 12 05:25:54 PDT 2026
I think the fog is lifting
Am 11.06.2026 um 19:18 schrieb Greg Troxel via QGIS-User:
> Jochem Kail via QGIS-User <qgis-user at lists.osgeo.org> writes:
>>>     Does your data have an epoch associated with each data point?  If no,
>>>     does it have an epoch associated with the whole dataset?
>> The data were all mapped in one month, i.e. one epoch, but several
>> years ago (2011).
> ok, makes sense.
>> I would now like to compare these river cross-sections with data
>> recently measured using a DGPS receiver using ETRS89/UTM32N as CRS in
>> the settings.
> sure, I can understand that sort of goal.
>>>     Why do you believe that your data is in WGS84 (the ensemble)?
>> The colleagues used a DGPS receiver and the setting for the CRS was
>> "WGS84".
> That is almost certainly confused.   When you use differential GPS, then
> the coordinates that come out of the GPS receiver (GNSS?) are not in
> WGS84, but they are in the CRS of the reference station.
> Your statement is vague, in that "DGPS" implies pseudorange corrections
> but *does not specify the kind of reference station or what its CRS is*.
>>>     Why do you believe that your data is accurate to on the order of a
>>>     mater?
>> ...because it was taken with a DGPS receiver
> To realize that accuracy you have to get the CRS right, and you have to
> avoid the ensemble.
>>>     Do the people who managed/prepared this data understand that 4326 is
>>>     an ensemble and that it contains WGS84(TRANSIT)?
>> No, nor did I. Up to now I thought that WGS84 is non-plate fixed and
>> therefore a single-fixed geodatic datum, with a plate-fixed geodatic
>> datum like ETRS89 "moving" relative to WGS84 with the European plate.
> WGS84 (specifically EPSG:4326) is an ensemble of a number of datums, all
> intended to realize a definition of a system.  In this respect it is
> like ETRS89 and the various ETRF realizations.  The various ensemble
> members have names like WGS84(TRANSIT) and WGS84(G2296), the most recent
> member.   The system definition is more or less congruent with ITRS, and
> WGS84 realizations are each very similar to the corresponding (in time)
> ITRFxxxx.
> You are correct that WGS84 is a global frame with a no-net-rotation
> constraint, as opposed to plate-fixed datums.
> So, the next step is to say that DGGPS is still vague, what reference
> station, and what frame are the reference station coordinates in.  Then,
> label that data as being in the right frame, and you will likely get a
> good transformation.
> I believe that it is extremely unlikely that the reference station
> coordinates are in any WGS84 realization.  There is simply no method to
> get accurate coordinates in that frame because carrier phase data from
> the GPS reference stations are not published.  Every differential system
> I have seen or heard about uses either a national/regional datum (e.g. a
> NAD83 realization, some ETRF, etc.), or some realization of ITRS,
> e.g. ITRF2008.
> It is a major problem in GIS that data are mislabeled as being in WGS84
> and that it is treated as an interchange format.  Both practices are
> errors, but also the standard approach.
In summary, I now do suspect, that the data from 2011 were mislabeled as
being WGS84. Based on what I do understand so far, the ITRF reference
frame in 2011 was ITRF2000, which corresponds to the WGS 84 (G1150)
realization. However, most likely the RTK network has been used as
reference stations. Therefore, the geographic coordinates are most
likely based on the ETRS89 reference system (not WGS84) and given that
the data have been mapped in 2011, based on the ETRF realization ETRF2000.
No I am still struggeling to find a way to do a time-dependent
transformation in QGIS from ETRS89/ETRF2000 to the recent ETRS89/ETRF2020.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
sent from my R2 unit
Jochem Kail
Dr. rer. nat.
University of Duisburg-Essen
Faculty of Biology
Department of Aquatic Ecology
Universitätsstrasse 5
D-45141 Essen
Germany
Room S05T03B08
Tel: +49.201.183.3046
Tel: +49.160.96228374
Fax: +49.201.183.2179
https://www.uni-due.de/aquatische_oekologie/mitarbeiter/jochem_kail.php
Important note: The university server does not accept old Microsoft Office files (e.g. *.doc) but only the recent version (e.g. *.docx)!
More information about the QGIS-User mailing list
