[Qgis-user] Visualizing 3D Drillhole Data
Andrea Giudiceandrea andreaerdna at libero.it
Sun Jun 14 05:42:32 PDT 2026
Hi Abel,
firstly I suggest you to try to solve one problem at a time: have you
already fixed the issue you have recently reported about the
"Coordinates Reprojection"? If not, it would be useful if you clarified
some details of your problem as requested in my previous message.
> Abel Chikoore achikoore at gmail.com
> Fri Jun 12 07:48:55 PDT 2026
> *The current web view QtWebKit cannot display 3D objects. Please use the Qt
> WebEngine view instead*
> When i use the Qt WebEngine the error is *PyQt - WebEngine is not
> installed. WebEngine modules are unavailable*
BTW, the error message also says that: << You can find instructions on
how to do this in the plugin wiki
https://github.com/minorua/Qgis2threejs/wiki/How-to-use-Qt-WebEngine-view-with-Qgis2threejs
Have you followed such suggestion and the instructions in the wiki page?
What plugin's version are you using?
Regards.
Andrea
More information about the QGIS-User mailing list
