[Qgis-user] Georeferencer says "Could not create destination file"
Andrea Giudiceandrea
andreaerdna at libero.it
Sun Jun 28 11:32:58 PDT 2026
Hi Adrian,
If I understand correctly, you are experiencing two issues:
1) if you try to georeference the provided JPG file with a JGW sidecar
file, then the the georefence file is not created the error "Transform
Failed: Could not create destination file" is displayed
I can confirm the issue occurs on Windows running either QGIS 4.0.3 or
QGIS LTR 3.44.11.
I suggest you to report the issue to https://github.com/qgis/QGIS/issues
providing all the requested info, the layer's file and detailed
step-by-step instruction in order to reproduce the issue
2) if you try to georeference the provided JPG file without the JGW
sidecar file, then the georeference file is created but it is in your
opinion not correctly georeferenced
It is not clear to me how to reproduce the issue. I've tried to
georeference the provided JPG file with various random GCPs and
georeferencing methods, and it seems to me the JPG file is correctly
georeferenced depending on the GCPs and georeferencing method used.
Please provide the GCPs file and all the georeferencing parameters and
settings used in your case and a reproducible way to verify why the
resulting georeferenced is not correctly georeferenced in your opinion.
Best regards.
Andrea
More information about the QGIS-User
