[Qgis-user] QGIS 3.44.11. - GRASS tools not available in processing toolbox, SAGA plugin not available.
Andrea Giudiceandrea andreaerdna at libero.it
Tue Jun 30 12:35:37 PDT 2026
Hi Jochem,
> Jochem Kail jochem.kail at uni-due.de
> Tue Jun 30 09:12:24 PDT 2026
>   * GRASS tools are not available in the processing toolbox. Of course I
>     did the following
In order to fix such issue, you could either:
- modify the line 132 of the file grass_utils.py (in
\apps\qgis-ltr\python\plugins\grassprovider\)
from
                     if "GRASS GIS " in line:
to
                     if "GRASS " in line:
- or downgrade the installed OSGeo4W grass package from 8.5.0-1 to
8.4.2-3 and the installed qgis-ltr* packages from 3.44.1-2 to 3.44.11-1.
- or install QGIS LTR 3.44.11 using the OSGeo4W "offline" standalone
.msi installer, instead of the OSGeo4W "online" installer
>   * SAGA plugin Processing SAGA NextGen Provider is not available.
The "Processing SAGA NextGen Provider" plugin is no longer available on
the official QGIS plugins' repository.
You can find a copy of the last version that was once available on the
QGIS plugins' repository at
https://github.com/agiudiceandrea/qgis-processing-saga-nextgen/releases/tag/1.1.0
You could download the zip file
https://github.com/agiudiceandrea/qgis-processing-saga-nextgen/releases/download/1.1.0/processing_saga_nextgen-1.1.0.zip
and install it in QGIS using the Plugin Manager.
Regards.
Andrea
More information about the QGIS-User mailing list
