[Qgis-user] Help : QGIS LTR on Fedora 43 Workstation
Etienne Lerch etienne.lerch at gmail.com
Tue Mar 10 03:46:54 PDT 2026
Hi Richard,
Thanks for the quick reply.
Well I'm relatively new on linux. All I know is that the "sudo dnf
install qgis" (as mentionned on the QGIS website) installs the QGIS
3.44.7 which is not a LTR. And on Flathub i have two choices : 3.28.9
LTS and 3.44.7 that i already use. But since flathub only ships stable
versions, I guess the next one will be QGIS 4.0 and as much as I am
excited to try it out, I'd like to work on a LTR version, which is not
available through these repos currently (apparently).
As the image shows below, the repos for Fedora 40 and 41 apparently ship
the LTR but from Fedora 42 and upwards it seems like it's QGIS 4.0. And
i'm running Fedora 43. Is there a way to download QGIS from the fedora
41 repo even if i'm using fedora 43 ? Or is it not how it works ?
Le 10/03/2026 à 11:03, Richard Duivenvoorde a écrit :
> Isn't QGIS packaged in the epel repo?
> (or is the RHEL/EPEL GDAL issue still a going on?)
> For what I know you get 3.44.7 from flatpak
> https://github.com/flathub/org.qgis.qgis/blob/master/org.qgis.qgis.json#L44
> 3.44 is current LTR isn't it?
> It can/will probably be updated to 3.44.8.
> In the issue I see there has been discussion about packaging 2
> branches. But the discussion seems not very fruitfull.
> Regards,
> Richard
> On 2026-03-10 09:59, Etienne Lerch via QGIS-User wrote:
>> Hi, I'd like to use the QGIS LTR version on Fedora 43 Workstation but
>> I can't find anyway to install it, neither as a rpm package nor a
>> flatpak. How to proceed ?
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260310/fdc40aa8/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260310/fdc40aa8/attachment-0001.png>
More information about the QGIS-User mailing list
