[Qgis-user] 16 bit greyscale map gives stepping artifacts
Greg Troxel gdt at lexort.com
Fri Mar 13 11:26:56 PDT 2026
wout zweers via QGIS-User <qgis-user at lists.osgeo.org> writes:
> My basic maps are 32 bit geotiff (Netherlands  AHN, downloaded
> directly from the AHN Server. I make a layer with this map and then
> process it:
You did not describe what the resolution of the DEM is, or the range of
values over the area you are processing.   If the DEM has 1 meter
resolution and the values range from -3 to 12 meters (from where I am my
impression is that your country is pretty flat :-), then you'll have
quantization artifacts, even if the DEM's data representation could go
from -32768 to 32767 meters.
More information about the QGIS-User mailing list
