[Qgis-user] WMS-Time with QGIS Server
Thekla Wirkus
thekla.wirkus at wheregroup.com
Tue Mar 17 02:39:46 PDT 2026
Hello,
I want to use QGIS to create a QGIS Server WMS-Time that displays a time
period.
- The PostGIS table for the layer contains a 'time' column stored as a
date, with annual values such as 2019-01-01, 2020-01-01, 2021-01-01 ...
- In the layer 'properties -temporal' I have set:
- Configuration: Fixed period
- Start inclusive, End exclusive
- Start date: 2017-01-01 00:00:00
- End date: 2024-01-01 00:00:00
The following appears in the getCapabilities document:
<Dimension multipleValues="1" units="ISO8601" name="time"
nearestValue="0" default="2017-01-01">
2017-01-01, 2018-01-01, 2019-01-01, 2020-01-01, 2021-01-01, 2022-01-01,
2023-01-01
</Dimension>
However, I would like to obtain a time range that should look like this
<Dimension name="time" units="ISO8601" default="2004"
nearestValue="0">2017/2023/P2Y</Dimension>
Is it possible to get this information in the getCapabilities document?
What settings do I need to configure?
Best regards
Thekla
More information about the QGIS-User
