[Qgis-user] Please help me
Nigel Berjak - General nigel at s3.co.za
Wed Mar 18 22:32:39 PDT 2026
Good morning
Have you tried setting the symbology to 'No symbol' rather than setting
a transparency? I am not sure that this will work though. I usually use
a polygon label to output the labels, rather than a point.
Regards,
Nigel Berjak
Please consider the environment before printing this email.
On 2026-03-18 17:54, 平田亜沙代 via QGIS-User wrote:
> I have a question. I loaded cadastral data into QGIS from a website (in
> this case from Hesse as a shapefile and Rhineland-Palatinate as an HTML
> document) and exported it as a DXF file.
> For the cadastral parcels (polygons), I changed the symbology to
> "simple line" so that in the DXF file they appear as polygon outlines
> without any fill.
> I would like to do the same for parcel numbers and district numbers --
> meaning I only want the labels to be shown, without any circle around
> them.
> In the layer properties, I set the circle's opacity to 0 and made its
> color transparent, but in the DXF file I still see the color.
> What am I doing wrong, and is there a solution?
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260319/bda119ae/attachment-0001.htm>
Name: in Qgis looks.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260319/bda119ae/attachment-0004.png>
Name: in Qgis looks 3.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260319/bda119ae/attachment-0005.png>
Name: in Qgis looks 2.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260319/bda119ae/attachment-0006.png>
Name: Problem in DXFdate.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260319/bda119ae/attachment-0007.png>
More information about the QGIS-User mailing list
