[Qgis-user] Unable to open QGIS 4.0.0 on MacOS Intel
jacob chaar
jacobchaar at live.ca
Mon Mar 23 05:52:00 PDT 2026
Hello everyone,
For some unknown reason, when I try to open QGIS 4.0.0 on my Intel Mac, it always crashes. do you guys think that the latest version of QGIS is not compatible with MacOS Intel.
here the error output:
Translated Report (Full Report Below)
Process: QGIS-final-4_0_0 [10161]
Path: /Applications/QGIS-final-4_0_0.app/Contents/MacOS/QGIS-final-4_0_0
Identifier: org.qgis.qgis3
Version: 4.0.0 (4.0.0)
Code Type: X86-64 (Native)
Role: Foreground
Parent Process: launchd [1]
Coalition: org.qgis.qgis3 [2116]
User ID: 501
Date/Time: 2026-03-23 08:47:00.8343 -0400
Launch Time: 2026-03-23 08:46:46.2202 -0400
Hardware Model: MacBookPro16,1
OS Version: macOS 26.3.1 (25D771280a)
Release Type: User
Bridge OS Version: 10.3 (23P3120)
Crash Reporter Key: CC0F037F-16B6-6F72-672B-5CD939A1E087
Incident Identifier: 5D263B81-277F-49A8-91F5-5EE51F34178A
Time Awake Since Boot: 3700 seconds
System Integrity Protection: enabled
Triggered by Thread: 0, Dispatch Queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Subtype: UNKNOWN_0xD at 0x0000000000000000
Exception Codes: 0x000000000000000d, 0x0000000000000000
Termination Reason: Namespace SIGNAL, Code 11, Segmentation fault: 11
Terminating Process: exc handler [10161]
VM Region Info: 0 is not in any region. Bytes before following region: 4435431424
REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
UNUSED SPACE AT START
__TEXT 1085f5000-108671000 [ 496K] r-x/r-x SM=COW /Applications/QGIS-final-4_0_0.app/Contents/MacOS/QGIS-final-4_0_0
Kernel Triage:
VM - (arg = 0x3) mach_vm_allocate_kernel failed within call to vm_map_enter
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_platform.dylib 0x7ff81c065af8 _longjmp + 44
1 libqjpeg.dylib 0x14c2a2965 my_error_exit(jpeg_common_struct*) + 37
Thread 1:
Thread 2:: Dispatch queue: com.apple.root.user-interactive-qos
0 libsystem_kernel.dylib 0x7ff81c017b4e mach_msg2_trap + 10
1 libsystem_kernel.dylib 0x7ff81c025f4c mach_msg2_internal + 83
2 libsystem_kernel.dylib 0x7ff81c01eba3 mach_msg_overwrite + 574
3 libsystem_kernel.dylib 0x7ff81c017e47 mach_msg + 19
4 CoreFoundation 0x7ff81c0fa6cf __CFRunLoopServiceMachPort + 145
5 CoreFoundation 0x7ff81c0f91b6 __CFRunLoopRun + 1354
6 CoreFoundation 0x7ff81c1ab8f0 _CFRunLoopRunSpecificWithOptions + 496
7 Foundation 0x7ff81de11ea7 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 216
8 AppKit 0x7ff820499ca6 -[NSAnimation _runBlocking] + 522
9 libdispatch.dylib 0x7ff81bea06b9 _dispatch_call_block_and_release + 12
10 libdispatch.dylib 0x7ff81beb6bee _dispatch_client_callout + 6
11 libdispatch.dylib 0x7ff81bed1973 _dispatch_root_queue_drain.cold.3 + 788
12 libdispatch.dylib 0x7ff81beafb90 _dispatch_root_queue_drain + 98
13 libdispatch.dylib 0x7ff81beb002a _dispatch_worker_thread2 + 174
14 libsystem_pthread.dylib 0x7ff81c057828 _pthread_wqthread + 233
15 libsystem_pthread.dylib 0x7ff81c056843 start_wqthread + 15
Thread 3:: com.apple.NSEventThread
7 AppKit 0x7ff81fff0121 _NSEventThread + 158
8 libsystem_pthread.dylib 0x7ff81c05ae4d _pthread_start + 115
9 libsystem_pthread.dylib 0x7ff81c056857 thread_start + 15
Thread 4:: Thread (pooled)
0 libsystem_kernel.dylib 0x7ff81c01a6fa __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x7ff81c05b2f6 _pthread_cond_wait + 988
2 libQt6Core.6.dylib 0x114734cfa QWaitConditionPrivate::wait(QDeadlineTimer) + 266
3 libQt6Core.6.dylib 0x114734b98 QWaitCondition::wait(QMutex*, QDeadlineTimer) + 88
4 libQt6Core.6.dylib 0x11472f1aa QThreadPoolThread::run() + 1002
5 libQt6Core.6.dylib 0x1147265a3 QThreadPrivate::start(void*) + 371
6 libsystem_pthread.dylib 0x7ff81c05ae4d _pthread_start + 115
7 libsystem_pthread.dylib 0x7ff81c056857 thread_start + 15
Thread 5:: Thread (pooled)
Thread 6:: Thread (pooled)
Thread 7:: Thread (pooled)
Thread 8:: Thread (pooled)
Thread 9:: Thread (pooled)
Thread 10:: QCA::KeyStoreThread
0 libsystem_kernel.dylib 0x7ff81c01e8da poll + 10
1 libQt6Core.6.dylib 0x114724abf qt_safe_poll(pollfd*, unsigned int, QDeadlineTimer) + 79
2 libQt6Core.6.dylib 0x114728f2b QEventDispatcherUNIX::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 1131
3 libQt6Core.6.dylib 0x11457ada6 QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 550
4 libqca.2.3.7.dylib 0x1113cc7d4 QCA::SyncThread::run() + 484
Thread 11:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x7ff81c0209ce __select + 10
1 CoreFoundation 0x7ff81c11124c __CFSocketManager + 671
2 libsystem_pthread.dylib 0x7ff81c05ae4d _pthread_start + 115
3 libsystem_pthread.dylib 0x7ff81c056857 thread_start + 15
Thread 12:
Thread 13:: Thread (pooled)
Thread 14:: QQmlThread
4 libQt6Core.6.dylib 0x11467f3a7 QThread::exec() + 343
Thread 15:: QNetworkAccessManager thread
Thread 16:: Thread (pooled)
Thread 17:: Thread (pooled)
0 libsystem_kernel.dylib 0x7ff81c01830a access + 10
1 libQt6Core.6.dylib 0x11471c1e0 QFileSystemEngine::fillMetaData(QFileSystemEntry const&, QFileSystemMetaData&, QFlags<QFileSystemMetaData::MetaDataFlag>) + 1584
2 libQt6Core.6.dylib 0x114526fa5 QFileInfo::exists() const + 149
3 libQt6Core.6.dylib 0x11479a0cd QConfFileSettingsPrivate::syncConfFile(QConfFile*) + 541
4 libQt6Core.6.dylib 0x114799e5f QConfFileSettingsPrivate::sync() + 127
5 libQt6Core.6.dylib 0x11479740e QConfFileSettingsPrivate::QConfFileSettingsPrivate(QSettings::Format, QSettings::Scope, QString const&, QString const&) + 1390
6 libQt6Core.6.dylib 0x1147ad7b9 QSettingsPrivate::create(QSettings::Format, QSettings::Scope, QString const&, QString const&) + 233
7 libQt6Core.6.dylib 0x11479d3b1 QSettings::QSettings(QSettings::Scope, QObject*) + 113
8 libqgis_core.4.0.0.dylib 0x11c8eaefb std::__1::unique_ptr<QSettings, std::__1::default_delete<QSettings>> std::__1::make_unique[abi:ne200100]<QSettings, QObject*&, 0>(QObject*&) + 59
9 libqgis_core.4.0.0.dylib 0x11c8eae52 QgsSettings::QgsSettings(QObject*) + 98
10 libqgis_core.4.0.0.dylib 0x11c8eaf5d QgsSettings::QgsSettings(QObject*) + 29
11 libqgis_core.4.0.0.dylib 0x11dfa8640 QgsNetworkAccessManager::setupDefaultProxyAndCache(Qt::ConnectionType) + 2832
12 libqgis_core.4.0.0.dylib 0x11dfa0e80 QgsNetworkAccessManager::instance(Qt::ConnectionType) + 208
13 libqgis_core.4.0.0.dylib 0x11dfb1576 QgsNetworkContentFetcher::fetchContent(QNetworkRequest const&, QString const&) + 454
14 libqgis_core.4.0.0.dylib 0x11df70a89 QgsNetworkContentFetcherTask::run() + 505
15 libqgis_core.4.0.0.dylib 0x11d52e124 QgsTask::start() + 196
16 libqgis_core.4.0.0.dylib 0x11d53b629 QgsTaskRunnableWrapper::run() + 25
17 libQt6Core.6.dylib 0x11472eea7 QThreadPoolThread::run() + 231
18 libQt6Core.6.dylib 0x1147265a3 QThreadPrivate::start(void*) + 371
19 libsystem_pthread.dylib 0x7ff81c05ae4d _pthread_start + 115
20 libsystem_pthread.dylib 0x7ff81c056857 thread_start + 15
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000001 rbx: 0x0000600000f29ca0 rcx: 0x00007ff81c02119a rdx: 0x0000000000000000
rdi: 0x00007fa7794577e8 rsi: 0x0ccaec8bbc3b568f rbp: 0x0cdfe08bbc3b568f rsp: 0x00007ff7b79015e8
r8: 0x0000000089a1c007 r9: 0x000000000000003f r10: 0x00007ff81c01a652 r11: 0x0000000000000246
r12: 0x00007ff7b7901ac0 r13: 0x0000000000000000 r14: 0x0000000000000290 r15: 0x00007fa77952a400
rip: 0x00007ff81c065af8 rfl: 0x0000000000010202 cr2: 0x0000000000000000
Logical CPU: 6
Error Code: 0x00000000
Trap Number: 13
Binary Images:
0x1085f5000 - 0x108670fff org.qgis.qgis3 (4.0.0) <b4ac657c-b39b-3017-a936-9895008feacb> /Applications/QGIS-final-4_0_0.app/Contents/MacOS/QGIS-final-4_0_0
0x10c5d5000 - 0x10d666fff libqgis_app.4.0.0.dylib (*) <7f07a6a1-a01f-30ee-a060-b6fca3349407> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libqgis_app.4.0.0.dylib
0x1086fd000 - 0x108710fff libQt6QuickControls2.6.dylib (*) <b3da0e16-8b70-3edb-9bd5-9013ab26d2c8> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libQt6QuickControls2.6.dylib
0x108880000 - 0x1088edfff libQt6UiTools.6.dylib (*) <0513182f-cbce-3939-b8a7-decf6c1f4d30> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libQt6UiTools.6.dylib
0x1086e0000 - 0x1086e8fff libQt6OpenGLWidgets.dylib (*) <b4042821-486c-3167-aed2-40179610b7c9> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libQt6OpenGLWidgets.dylib
0x108932000 - 0x10a4d2fff libqgis_gui.4.0.0.dylib (*) <559a5fe9-eab9-3838-bbba-bf84e0f37fdf> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libqgis_gui.4.0.0.dylib
0x108727000 - 0x10872dfff libqgis_native.4.0.0.dylib (*) <cbd649d2-bbeb-30ed-9162-e2ff6bedfdfb> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libqgis_native.4.0.0.dylib
0x10e5a4000 - 0x10e694fff libqwt.dylib (*) <aecf5daf-ca5c-3972-b712-cfa73c872a86> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libqwt.dylib
0x10c160000 - 0x10c406fff libqscintilla2_qt6.15.dylib (*) <bc7df440-8e46-3a5d-a203-193c9907eadb> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libqscintilla2_qt6.15.dylib
0x1086a3000 - 0x1086b7fff libQt6QuickWidgets.dylib (*) <0b513c99-24e6-3017-9c9d-5f7b78738967> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libQt6QuickWidgets.dylib
0x10f6ef000 - 0x10fbd2fff libQt6Quick.dylib (*) <fe6669d5-5832-3e74-a55d-e54a2f96703e> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libQt6Quick.dylib
0x1087a7000 - 0x1087bdfff libQt6QmlMeta.dylib (*) <f844dea7-22e1-3d1b-b096-f3e748e7f90a> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libQt6QmlMeta.dylib
0x10877e000 - 0x108789fff libQt6QmlWorkerScript.6.dylib (*) <3c9a7d7c-a275-39c5-8ae9-25835acf4f0f> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libQt6QmlWorkerScript.6.dylib
0x10c469000 - 0x10c501fff libQt6QmlModels.dylib (*) <3bd13606-c025-395a-a574-f021f5d23108> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libQt6QmlModels.dylib
0x1087d8000 - 0x1087dffff libQt6MultimediaWidgets.6.9.3.dylib (*) <360a8b76-5a98-398d-bffc-2a5deca8721d> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libQt6MultimediaWidgets.6.9.3.dylib
0x10ea5c000 - 0x10eb3ffff libQt6Multimedia.6.dylib (*) <9e1ac14d-592d-380d-b7ec-0eec0504c650> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libQt6Multimedia.6.dylib
0x1087ee000 - 0x1087f4fff libQt6SvgWidgets.6.dylib (*) <9c07fbea-98b0-3b6b-bf2b-1d0f4c2d1690> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libQt6SvgWidgets.6.dylib
0x10ff14000 - 0x110738fff libqgis_analysis.4.0.0.dylib (*) <7a05ba24-d8c0-3d1a-9ac9-c5792c1c08ef> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libqgis_analysis.4.0.0.dylib
0x10e72d000 - 0x10e9c3fff libgsl.dylib (*) <aeb1c663-79f0-367d-ace3-889bb7b6cffd> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libgsl.dylib
0x108803000 - 0x108859fff libgslcblas.dylib (*) <65f68cfe-92f2-34a5-97bf-93a6c2f9dfc8> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libgslcblas.dylib
0x10c578000 - 0x10c59ffff libqgispython.4.0.0.dylib (*) <cb969f69-f1ec-3b12-a6ea-df586a06b745> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libqgispython.4.0.0.dylib
0x10ebf5000 - 0x10ef2bfff libpython3.12.dylib (*) <94ae4fce-fb17-38bd-bb8b-feb5d1ccb115> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libpython3.12.dylib
0x111ca5000 - 0x111f58fff libqgis_3d.4.0.0.dylib (*) <368db744-03a3-3d7c-be2e-5d063d163a20> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libqgis_3d.4.0.0.dylib
0x11c304000 - 0x11eda4fff libqgis_core.4.0.0.dylib (*) <13ea7970-17ea-3ffc-8771-446e03ed6edb> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libqgis_core.4.0.0.dylib
0x10f313000 - 0x10f348fff libQt6Sql.dylib (*) <abbad552-65aa-37ee-8266-ca253435f743> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libQt6Sql.dylib
0x10873c000 - 0x108762fff libmeshoptimizer.dylib (*) <261a0f9c-28a2-3f1b-bbe9-7be461babf86> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libmeshoptimizer.dylib
0x108864000 - 0x10886cfff libpoly2tri.dylib (*) <55f4d6ac-f6e6-38df-aed7-ee6c210622db> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libpoly2tri.dylib
0x10ea3f000 - 0x10ea45fff libOpenCL.1.dylib (*) <824b37f0-6e43-3dca-b52c-e9a492d88eca> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libOpenCL.1.dylib
0x10f297000 - 0x10f2a7fff libtasn1.6.dylib (*) <88e6e4e7-7c53-3bfe-95ab-7d27242f3912> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libtasn1.6.dylib
0x10f256000 - 0x10f274fff libQt6Xml.dylib (*) <9e560636-6879-3ab1-bbc2-63de05f01d9c> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libQt6Xml.dylib
0x10f4b4000 - 0x10f51ffff libQt6Svg.6.dylib (*) <5dc63f63-a2b9-3af2-a6f4-413975938a7e> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libQt6Svg.6.dylib
0x10f2b6000 - 0x10f2dcfff libexpat.dylib (*) <90275629-7645-3cf7-9031-30e8720dc1c1> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libexpat.dylib
0x10f559000 - 0x10f682fff libsqlite3.dylib (*) <dbf89b73-78e2-3936-9b3d-b1cd58744ddb> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libsqlite3.dylib
0x10f2ec000 - 0x10f301fff libzip.5.dylib (*) <98a695a2-f159-3894-91d0-a582a152bdcb> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libzip.5.dylib
0x10f370000 - 0x10f42bfff libprotobuf-lite.dylib (*) <d4b7cf84-df1a-3fb8-9d7f-4649675a91db> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libprotobuf-lite.dylib
0x110e56000 - 0x110ec5fff libQt6Positioning.dylib (*) <52688365-d461-3e0e-b605-579efce4d52f> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libQt6Positioning.dylib
0x1116c0000 - 0x111896fff libexiv2.dylib (*) <c9d8e46e-a633-3acc-a43e-fd313cc72a3d> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libexiv2.dylib
0x11134f000 - 0x1113f3fff libqca.2.3.7.dylib (*) <814dad16-4c16-3152-946f-3bc6149eb518> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libqca.2.3.7.dylib
0x111490000 - 0x111521fff libspatialindex.dylib (*) <43f31212-0ed8-3f88-bbfc-dbc33e46308c> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libspatialindex.dylib
0x110f0f000 - 0x110f17fff libqt6keychain.0.14.3.dylib (*) <2159693f-b62e-3d50-86f5-5874f8a0dce5> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libqt6keychain.0.14.3.dylib
0x1111f3000 - 0x111242fff libQt6PrintSupport.6.dylib (*) <fdcbd1a3-6e02-3eff-8dac-8f6a87eeabb1> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libQt6PrintSupport.6.dylib
0x113188000 - 0x1136cffff libQt6Widgets.dylib (*) <6854aa5e-bde5-30b5-8371-b9c89627247f> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libQt6Widgets.dylib
0x112288000 - 0x112359fff libdraco.dylib (*) <3353b77f-d568-340b-b258-cf945e649a35> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libdraco.dylib
0x112401000 - 0x112aa3fff libspatialite.dylib (*) <465fad2d-caf2-35b2-9789-582d700a6623> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libspatialite.dylib
0x110f2a000 - 0x110f60fff libgeos_c.dylib (*) <df4f5118-9e3d-3352-8df5-dd60eaa02f3f> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libgeos_c.dylib
0x112ae4000 - 0x112dd2fff libproj.25.9.7.1.dylib (*) <be0e231d-0488-31b5-84a7-8abc64c53e0d> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libproj.25.9.7.1.dylib
0x10f6d8000 - 0x10f6e3fff libfreexl.dylib (*) <e374e845-2998-3ade-9a20-9002b0b974d9> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libfreexl.dylib
0x10f6a6000 - 0x10f6bbfff libz.dylib (*) <0e493d9f-12e5-3732-8348-ca2b7edfc7f7> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libz.dylib
0x111568000 - 0x11166bfff libxml2.2.13.8.dylib (*) <0360c221-956b-3894-966d-19ee899433ad> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libxml2.2.13.8.dylib
0x111285000 - 0x1112d1fff libQt6Core5Compat.6.9.3.dylib (*) <cbe4a884-2260-3d0e-b540-31cdc3f8a152> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libQt6Core5Compat.6.9.3.dylib
0x1110cb000 - 0x1111a4fff libzstd.1.dylib (*) <9c2faecf-2882-368a-b6ce-3a08323a8e59> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libzstd.1.dylib
0x115a97000 - 0x116301fff libSFCGAL.2.dylib (*) <3e71aac8-9561-3274-8f83-38c98ce983b9> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libSFCGAL.2.dylib
0x1111bf000 - 0x1111d2fff libQt6SerialPort.6.9.3.dylib (*) <89089ec6-c224-3679-bf19-827801abe04b> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libQt6SerialPort.6.9.3.dylib
0x111b8f000 - 0x111c15fff libQt63DExtras.6.dylib (*) <667ade92-d44b-3e7b-b61c-e2881827b6be> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libQt63DExtras.6.dylib
0x113f73000 - 0x114134fff libQt63DRender.dylib (*) <df7fbb58-94e3-363e-8a06-3d0566e6fec3> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libQt63DRender.dylib
0x112f14000 - 0x112f86fff libQt6OpenGL.6.dylib (*) <6a5d3169-a812-344a-9f56-8a9352e66033> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libQt6OpenGL.6.dylib
0x111aee000 - 0x111b3bfff libQt63DInput.6.dylib (*) <328b17de-a13c-36a5-a7f9-14272fae718b> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libQt63DInput.6.dylib
0x110f87000 - 0x110f92fff libQt63DLogic.dylib (*) <cf5c8bad-8aec-3cb4-b965-570ce637f62c> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libQt63DLogic.dylib
0x1119bf000 - 0x111a18fff libQt63DCore.6.dylib (*) <e996e2a2-ba9e-3993-831e-50073e28130d> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libQt63DCore.6.dylib
0x116c74000 - 0x11727bfff libQt6Gui.dylib (*) <5edf94ff-25c1-3547-8b9b-543e57ce93e0> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libQt6Gui.dylib
0x1086d2000 - 0x1086d5fff libQt6Concurrent.dylib (*) <ff6e7282-28f8-351e-8326-492308da1afa> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libQt6Concurrent.dylib
0x1174f9000 - 0x117a89fff libpdalcpp.dylib (*) <582a65f7-7f94-3f89-9ca6-bec1e6cc8bf1> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libpdalcpp.dylib
0x1212ea000 - 0x12283efff libgdal.dylib (*) <dd892fc3-cd54-3df7-bc47-2e501e67ed74> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libgdal.dylib
0x114ff0000 - 0x11546cfff libQt6Qml.dylib (*) <3f45a4ad-e16f-3c1b-8833-3ae4e9f5e1f5> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libQt6Qml.dylib
0x11429b000 - 0x1143f8fff libQt6Network.6.dylib (*) <0af03fb6-2fb7-390f-b5d3-35d73b9f7f18> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libQt6Network.6.dylib
0x1144d3000 - 0x114980fff libQt6Core.6.dylib (*) <7ddfa30e-2d78-32bd-bfa8-2871dc1ad2f8> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libQt6Core.6.dylib
0x112fcb000 - 0x113061fff libQt6DBus.6.dylib (*) <63e838a9-f612-3ec3-a7cf-8195f6d85505> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libQt6DBus.6.dylib
0x1112f7000 - 0x111327fff libpng16.16.53.0.dylib (*) <f1c0d9ef-bc9a-3e7d-807c-13f11b6abf5b> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libpng16.16.53.0.dylib
0x113bdf000 - 0x113cdefff libharfbuzz.0.dylib (*) <be59cf91-d50b-3ea6-a376-89e7f9b67c5d> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libharfbuzz.0.dylib
0x113ae4000 - 0x113b8cfff libfreetype.dylib (*) <89f0f940-cba4-37b2-af64-ca742dc20fca> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libfreetype.dylib
0x114b99000 - 0x114dcbfff libicui18n.dylib (*) <b311ff4a-ebcf-331e-ba11-0d39008e221b> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libicui18n.dylib
0x113d25000 - 0x113eb2fff libicuuc.dylib (*) <bee40ce3-52e6-306b-9558-79bc9937b364> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libicuuc.dylib
0x122f42000 - 0x124ed5fff libicudata.dylib (*) <1222327b-5bb3-3079-a616-9ac7aa05aa31> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libicudata.dylib
0x111336000 - 0x111343fff libdouble-conversion.dylib (*) <3ac91636-7977-3dea-8f14-51a956ba6d57> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libdouble-conversion.dylib
0x10876d000 - 0x108773fff libb2.dylib (*) <bff992d7-b571-3d77-8eb4-4cecbe4cf8d7> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libb2.dylib
0x114f20000 - 0x114fdafff libpcre2-16.0.dylib (*) <fbae0af0-f3ab-3dd3-bda0-4282c61e0a4d> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libpcre2-16.0.dylib
0x1116a2000 - 0x1116b4fff libbz2.dylib (*) <5b7bf33e-f8b4-312f-9471-b1327e28f63d> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libbz2.dylib
0x111aa3000 - 0x111aaefff libbrotlidec.1.dylib (*) <4ee8c5a2-621e-335e-bd29-bd85acd65e7e> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libbrotlidec.1.dylib
0x111a71000 - 0x111a91fff libbrotlicommon.1.dylib (*) <f2a61865-6975-3740-8b57-cd0544382352> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libbrotlicommon.1.dylib
0x1156f1000 - 0x115845fff libQt6QuickTemplates2.dylib (*) <ed742d1a-f99d-3790-9724-e1eec6809b00> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libQt6QuickTemplates2.dylib
0x11394f000 - 0x113a08fff libssl.dylib (*) <0f160680-c506-38a1-ab9a-42d6dfd8107f> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libssl.dylib
0x11891d000 - 0x118d23fff libcrypto.dylib (*) <bb6162ba-b6ac-3c1d-ad97-03eb0424e550> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libcrypto.dylib
0x111ab9000 - 0x111ad2fff libgeotiff.dylib (*) <d901a636-b982-3c88-ad1f-9884828c2162> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libgeotiff.dylib
0x1130d8000 - 0x113133fff libnlohmann_json_schema_validator.2.4.0.dylib (*) <681def50-e1a1-384c-b7de-acb5c5db41e9> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libnlohmann_json_schema_validator.2.4.0.dylib
0x115999000 - 0x115a11fff libtiff.6.2.0.dylib (*) <37f81a85-d322-3f68-9e72-86d53ee56e31> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libtiff.6.2.0.dylib
0x117fdf000 - 0x11807afff libcurl.4.8.0.dylib (*) <807ddd30-9d06-3650-9a50-1d711177eccb> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libcurl.4.8.0.dylib
0x115a2b000 - 0x115a52fff liblzma.5.8.2.dylib (*) <860459e9-9fc7-38d1-828b-dfa024aa8be1> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/liblzma.5.8.2.dylib
0x113a53000 - 0x113abafff libqhull_r.dylib (*) <5934b8ca-387e-33d8-a080-7782f581ef7c> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libqhull_r.dylib
0x11809d000 - 0x118129fff libLerc.dylib (*) <c40fcdb9-1140-3ece-bede-ae549f2f00a0> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libLerc.dylib
0x117e5c000 - 0x117f1bfff libjpeg.62.4.0.dylib (*) <a4b74f10-4af8-3f96-bd34-fdba17cfb225> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libjpeg.62.4.0.dylib
0x10c5c2000 - 0x10c5c9fff libgif.dylib (*) <ac7bb6b1-73cf-3644-8720-2cf63edae045> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libgif.dylib
0x118448000 - 0x118590fff libnetcdf.dylib (*) <805147c8-0709-31dd-8c32-48f3a03edd02> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libnetcdf.dylib
0x11826a000 - 0x1182f8fff libwebp.7.2.0.dylib (*) <911ac1c8-33ac-3a2e-b134-17066427bfd7> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libwebp.7.2.0.dylib
0x117f3e000 - 0x117f7dfff libpq.dylib (*) <1824c637-174f-3a66-a04b-fab4edf1095f> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libpq.dylib
0x111c7b000 - 0x111c89fff libadbc_driver_manager.104.0.0.dylib (*) <d2317295-baf4-352a-880a-46c56b10ad80> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libadbc_driver_manager.104.0.0.dylib
0x11316b000 - 0x113173fff libminizip.dylib (*) <53b3dd20-670c-34fb-b269-807a362e0414> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libminizip.dylib
0x113bb1000 - 0x113bccfff liburiparser.1.1.0.dylib (*) <8bbf5050-147c-3f30-a984-6a2171663ce5> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/liburiparser.1.1.0.dylib
0x118140000 - 0x11820cfff libpcre2-8.0.dylib (*) <fca5fb06-a1f3-3a41-bb21-6a67f4e323a1> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libpcre2-8.0.dylib
0x1185e0000 - 0x1186fcfff libarrow_dataset.2200.dylib (*) <23bc442d-a444-3bd6-8337-3b3032319b53> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libarrow_dataset.2200.dylib
0x113ac9000 - 0x113ad3fff libjson-c.5.4.0.dylib (*) <4b448acb-836e-3603-bc10-1ca2bbf1caaf> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libjson-c.5.4.0.dylib
0x1195ee000 - 0x119895fff libpoppler.151.0.0.dylib (*) <7f4db302-a4fa-346a-a332-e667a0db8fc1> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libpoppler.151.0.0.dylib
0x10f6c6000 - 0x10f6ccfff libsharpyuv.0.dylib (*) <78d806f9-c0f7-373d-b051-43962862b190> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libsharpyuv.0.dylib
0x118880000 - 0x1188d8fff libkea.dylib (*) <6037dc22-96cd-3150-a704-dac0b578892b> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libkea.dylib
0x118ec0000 - 0x118ef7fff libhdf5_cpp.dylib (*) <b9976745-0977-3a89-9f7d-6665ad193e2b> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libhdf5_cpp.dylib
0x118f30000 - 0x119279fff libhdf5.310.5.1.dylib (*) <c5649ec9-c987-3538-80b7-005ff7ebad73> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libhdf5.310.5.1.dylib
0x1183e0000 - 0x118439fff libopenjp2.7.dylib (*) <957ed397-0cea-3afd-bcf3-7a68d85e26cf> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libopenjp2.7.dylib
0x117f92000 - 0x117fabfff libkmlengine.dylib (*) <c549d267-5547-3b8c-a349-e66903e50b16> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libkmlengine.dylib
0x118310000 - 0x118352fff libkmldom.dylib (*) <1359536b-083e-32ef-84ce-9c2da5cd2375> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libkmldom.dylib
0x113f3f000 - 0x113f51fff libkmlbase.1.dylib (*) <85206f1a-8c1b-3571-9d23-27840de33353> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libkmlbase.1.dylib
0x11a1ea000 - 0x11a42ffff libparquet.dylib (*) <93f7ddc8-6967-30a3-9425-454bb00781fe> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libparquet.dylib
0x119310000 - 0x11942dfff libarrow_acero.dylib (*) <4bd159b3-1dfa-34bb-94e9-26c14e7f619b> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libarrow_acero.dylib
0x11a634000 - 0x11b12cfff libarrow_compute.2200.dylib (*) <68a25030-b3e5-30b9-9826-da7fab627c7b> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libarrow_compute.2200.dylib
0x126c05000 - 0x1274ddfff libarrow.2200.dylib (*) <eaaf0af6-5ba9-36ed-b287-7d8b80addf23> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libarrow.2200.dylib
0x115a61000 - 0x115a79fff libhdf5_hl.dylib (*) <78cc7b7b-26c2-35a7-a420-0f5836f83aae> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libhdf5_hl.dylib
0x1183a3000 - 0x1183b0fff libtinyxml2.11.dylib (*) <9e881696-d53f-3800-8d04-977f6daea00e> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libtinyxml2.11.dylib
0x117fce000 - 0x117fd4fff libsz.2.dylib (*) <bcc7affc-7cc5-3185-8280-0825ca4d5cad> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libsz.2.dylib
0x118245000 - 0x11824bfff libaec.0.1.3.dylib (*) <02e2ff78-f5db-3eb4-9ddb-9913b710af20> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libaec.0.1.3.dylib
0x119539000 - 0x119580fff libthrift.dylib (*) <834852ad-7abe-36c1-9a76-7b1536a0ea89> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libthrift.dylib
0x119b24000 - 0x119bdbfff libbrotlienc.dylib (*) <f3677fa5-67e2-3de4-9764-61254282a5f6> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libbrotlienc.dylib
0x119a10000 - 0x119a37fff liblz4.1.10.0.dylib (*) <643c3e31-0e0d-3356-83ae-baaf8e218fc0> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/liblz4.1.10.0.dylib
0x11821b000 - 0x118221fff libsnappy.1.2.2.dylib (*) <e01cbf7f-b7b2-302a-9e24-01a98d5f9c75> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libsnappy.1.2.2.dylib
0x119dde000 - 0x119e77fff libre2.dylib (*) <a0cf995f-2e07-36d9-be45-3de99485c9c4> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libre2.dylib
0x1199a3000 - 0x1199f7fff libutf8proc.3.2.2.dylib (*) <d61ec68e-c909-3727-b627-afe7d69bb8be> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libutf8proc.3.2.2.dylib
0x11bbd1000 - 0x11bdb3fff libgeos.dylib (*) <4cbe2274-a738-3423-af73-fa1bf2fb48cc> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libgeos.dylib
0x119bea000 - 0x119c2afff libfontconfig.dylib (*) <a73cf83b-4379-3cec-b9dc-4727e73f9d4d> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libfontconfig.dylib
0x119c3e000 - 0x119c61fff libboost_serialization.dylib (*) <4730521e-e6ad-32a7-8f84-df852416b2e0> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libboost_serialization.dylib
0x10f28b000 - 0x10f28cfff libgmpxx.dylib (*) <066344f3-ee7f-3cb7-9d9f-8fc79d733360> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libgmpxx.dylib
0x119a42000 - 0x119aacfff libmpfr.dylib (*) <d1080611-284d-3aa3-b9ad-eb964b9db007> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libmpfr.dylib
0x119ed9000 - 0x119f40fff libgmp.dylib (*) <0185e13a-d1ba-3052-91ba-5bc7ad663dfe> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libgmp.dylib
0x1183bf000 - 0x1183cafff libboost_thread.dylib (*) <edb0b72a-0270-3a3f-a2e4-11a4b9e864db> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libboost_thread.dylib
0x11822c000 - 0x11822dfff libboost_atomic.1.90.0.dylib (*) <2a2dc9d0-d335-322f-b29e-fcf616d2ad25> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libboost_atomic.1.90.0.dylib
0x115a89000 - 0x115a8cfff libboost_chrono.1.90.0.dylib (*) <fc0dcdc8-3072-3089-8a54-461c5a73d3f9> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libboost_chrono.1.90.0.dylib
0x10879c000 - 0x10879dfff libboost_date_time.dylib (*) <8c0fa030-c162-326d-a8e3-9c972ff609c8> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libboost_date_time.dylib
0x1188f8000 - 0x118903fff libboost_container.dylib (*) <f1053081-e18a-3049-b0f1-fe84c12a6d0d> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libboost_container.dylib
0x119ca5000 - 0x119cc0fff libintl.dylib (*) <a2b94785-9706-36e9-9b74-5808505f97f7> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libintl.dylib
0x119d75000 - 0x119d8bfff com.apple.security.csparser (3.0) <804fc5d6-3660-3422-b95a-5ab53b1928ea> /System/Library/Frameworks/Security.framework/Versions/A/PlugIns/csparser.bundle/Contents/MacOS/csparser
0x11b91f000 - 0x11b9d6fff libqcocoa.dylib (*) <9e96e627-faf1-3d48-aebd-c335d5198c9c> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/platforms/libqcocoa.dylib
0x11a0fa000 - 0x11a106fff libobjc-trampolines.dylib (*) <0a35bc69-660d-3bc0-8ab4-3fa8d922eecb> /usr/lib/libobjc-trampolines.dylib
0x11c0b8000 - 0x11c205fff com.apple.AMDRadeonX6000GLDriver (7.1.6) <e99a64d9-86ab-3741-85a6-89850aaaabfb> /System/Library/Extensions/AMDRadeonX6000GLDriver.bundle/Contents/MacOS/AMDRadeonX6000GLDriver
0x11a153000 - 0x11a17cfff libqmacstyle.dylib (*) <b40595e4-0d60-34bb-bde4-e12eca88f7fa> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/styles/libqmacstyle.dylib
0x11b85f000 - 0x11b86afff libqsvgicon.dylib (*) <ac15a16a-405b-3f94-bb48-6be66ec7eb7e> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/iconengines/libqsvgicon.dylib
0x13504f000 - 0x1350f1fff libplugin_geometrychecker.so (*) <46857134-9323-30ce-ab41-70ec8efb263e> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/qgis/libplugin_geometrychecker.so
0x1351a6000 - 0x1351cefff libplugin_offlineediting.so (*) <a60c5b3f-91cf-3de1-b990-5644030d51ff> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/qgis/libplugin_offlineediting.so
0x1353e3000 - 0x13544bfff libplugin_topology.so (*) <1b374ce8-c2e6-3bd8-8f47-2de58abba98d> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/qgis/libplugin_topology.so
0x135229000 - 0x1352defff libprovider_arcgisfeatureserver.so (*) <45d84c66-3e34-3447-b321-c8ca1eeddc2b> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/qgis/libprovider_arcgisfeatureserver.so
0x1356a8000 - 0x135713fff libprovider_arcgismapserver.so (*) <af18e065-efc6-30b0-bacd-7700632bbe58> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/qgis/libprovider_arcgismapserver.so
0x1354bb000 - 0x135545fff libprovider_delimitedtext.so (*) <459ad96f-efd3-3a91-aa27-ef3d52cb06ba> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/qgis/libprovider_delimitedtext.so
0x1355ca000 - 0x135619fff libprovider_gpx.so (*) <43e8bbc9-d77c-3ff6-bc80-a2a13dba6518> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/qgis/libprovider_gpx.so
0x13615e000 - 0x13636dfff libprovider_mdal.so (*) <a19df391-9347-3547-b4be-87e6a5261ba1> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/qgis/libprovider_mdal.so
0x135c59000 - 0x135d82fff libprovider_mssql.so (*) <61a2b206-80ab-32ae-aa03-5636d25f509b> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/qgis/libprovider_mssql.so
0x13579b000 - 0x1358effff libprovider_oracle.so (*) <08615275-417b-3c32-af1d-e391eef36e03> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/qgis/libprovider_oracle.so
0x135b33000 - 0x135b68fff libprovider_pdal.so (*) <cc6db03b-1021-33ba-ac52-2382007c6943> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/qgis/libprovider_pdal.so
0x136e9c000 - 0x1370bafff libprovider_postgres.so (*) <40145a27-aa44-33e9-aa46-18066ef07f4e> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/qgis/libprovider_postgres.so
0x135eb6000 - 0x135fdcfff libprovider_postgresraster.so (*) <be124590-22c9-35d1-9017-4e7776501351> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/qgis/libprovider_postgresraster.so
0x136acf000 - 0x136bd8fff libprovider_spatialite.so (*) <7a354891-6250-3ba4-ae11-788c85a6c0fb> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/qgis/libprovider_spatialite.so
0x136867000 - 0x1368e6fff libprovider_virtuallayer.so (*) <2954c809-f389-3c77-b28b-f723337b5f1b> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/qgis/libprovider_virtuallayer.so
0x135bab000 - 0x135bd2fff libprovider_virtualraster.so (*) <d60607fc-a891-3a4b-a361-3aaca73b093c> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/qgis/libprovider_virtualraster.so
0x136638000 - 0x1366d8fff libprovider_wcs.so (*) <98737d96-f479-3578-867e-a6b6d4b41abe> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/qgis/libprovider_wcs.so
0x137b51000 - 0x137d3cfff libprovider_wfs.so (*) <f0b430c1-aaa9-34ae-8311-34cc66e96109> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/qgis/libprovider_wfs.so
0x137f91000 - 0x138154fff libprovider_wms.so (*) <377b1b76-eb7e-3d3d-abba-d6361ee2e0da> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/qgis/libprovider_wms.so
0x135675000 - 0x135683fff libpdal_plugin_reader_draco.19.dylib (*) <74a4c322-fee7-3796-bb75-738f2440fa1f> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libpdal_plugin_reader_draco.19.dylib
0x135a33000 - 0x135ab3fff libpdal_plugin_reader_e57.19.dylib (*) <b615f701-4a98-38c0-9c39-2cca40e9b97f> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libpdal_plugin_reader_e57.19.dylib
0x13833b000 - 0x138541fff libxerces-c.dylib (*) <c89cd56e-365a-3773-9bc1-ed2823432507> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libxerces-c.dylib
0x135afc000 - 0x135b09fff libpdal_plugin_reader_pgpointcloud.dylib (*) <df3ca7f1-6c69-3ad3-b64f-4bd36c0a2f29> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libpdal_plugin_reader_pgpointcloud.dylib
0x135c09000 - 0x135c2dfff libpdal_plugin_writer_draco.19.dylib (*) <638e7869-8aeb-356f-bb10-d8b299736f20> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libpdal_plugin_writer_draco.19.dylib
0x13678e000 - 0x136811fff libpdal_plugin_writer_e57.19.dylib (*) <25b47128-90f2-328a-aa84-fdd6d99b6e7d> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libpdal_plugin_writer_e57.19.dylib
0x13611d000 - 0x13612efff libpdal_plugin_writer_pgpointcloud.19.dylib (*) <13086f92-26b0-344f-8791-4f0cb86780d6> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libpdal_plugin_writer_pgpointcloud.19.dylib
0x14bd95000 - 0x14bdbefff libqca-gnupg.dylib (*) <cc42b9ec-9507-3632-9dd7-0f068ffdc088> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/crypto/libqca-gnupg.dylib
0x1351f5000 - 0x1351fafff libqca-logger.dylib (*) <3a60869c-d95c-3b50-8914-00d66e6e5696> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/crypto/libqca-logger.dylib
0x137a8b000 - 0x137abafff libqca-ossl.dylib (*) <e5d8b764-b25b-353c-a5df-27a02b8b1b0d> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/crypto/libqca-ossl.dylib
0x14bec6000 - 0x14bef2fff libauthmethod_apiheader.so (*) <041f70ff-e8e8-3588-ae36-700ddd8a247a> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/qgis/libauthmethod_apiheader.so
0x14bdea000 - 0x14be1afff libauthmethod_awss3.so (*) <7d4cb1ab-dd69-3853-bb14-f9a1a76e99dd> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/qgis/libauthmethod_awss3.so
0x14c021000 - 0x14c053fff libauthmethod_basic.so (*) <3c34a1cb-434e-30ce-b27a-2f4e3df6d921> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/qgis/libauthmethod_basic.so
0x14be5d000 - 0x14be86fff libauthmethod_esritoken.so (*) <13e91afd-2cda-3e25-85ce-ece389cd9a4a> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/qgis/libauthmethod_esritoken.so
0x14c092000 - 0x14c0c0fff libauthmethod_identcert.so (*) <28b53e46-2a61-3c31-9bd9-6a8079d6a082> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/qgis/libauthmethod_identcert.so
0x14c0ff000 - 0x14c12bfff libauthmethod_maptilerhmacsha256.so (*) <ee0f2457-4d45-37df-a66e-14cdb08d6790> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/qgis/libauthmethod_maptilerhmacsha256.so
0x14c4f1000 - 0x14c5c5fff libauthmethod_oauth2.so (*) <ab2bafa9-a575-335d-ad5b-247ceec81cc9> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/qgis/libauthmethod_oauth2.so
0x14bf2d000 - 0x14bf62fff libauthmethod_pkcs12.so (*) <a1377d40-51b7-3a7f-bb82-2bc4eb92556e> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/qgis/libauthmethod_pkcs12.so
0x14bfa9000 - 0x14bfddfff libauthmethod_pkipaths.so (*) <d4277b33-d0a7-319d-a0c5-93c4d2a29104> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/qgis/libauthmethod_pkipaths.so
0x14c16a000 - 0x14c1c2fff libauthmethod_planetary_computer.so (*) <9fda9338-4ade-303e-87ce-51593df6d7e0> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/qgis/libauthmethod_planetary_computer.so
0x136e67000 - 0x136e76fff libqsqlite.dylib (*) <0c5dfb18-7b16-3baa-ace2-e76fbfe8b50d> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/sqldrivers/libqsqlite.dylib
0x137af4000 - 0x137b22fff libqopensslbackend.dylib (*) <4628053c-73b5-335f-bdd0-1a03518b6422> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/tls/libqopensslbackend.dylib
0x14c255000 - 0x14c265fff libqcertonlybackend.dylib (*) <c4045e7e-d6d7-3449-b293-db308649961b> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/tls/libqcertonlybackend.dylib
0x135696000 - 0x13569bfff libqsvg.dylib (*) <be32e0ac-556c-35f6-8ae8-0812d9c39c5e> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/imageformats/libqsvg.dylib
0x135b1c000 - 0x135b23fff libqgif.dylib (*) <a4d6249c-ecfc-3f13-abed-59ab2f6e4ab1> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/imageformats/libqgif.dylib
0x136146000 - 0x13614afff libqwbmp.dylib (*) <29a9284b-b61d-388f-a424-fa7c736ddf85> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/imageformats/libqwbmp.dylib
0x136ab5000 - 0x136abbfff libqwebp.dylib (*) <12a2c575-7ce5-3335-b09f-c36779218ada> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/imageformats/libqwebp.dylib
0x11c0aa000 - 0x11c0adfff libwebpdemux.2.0.17.dylib (*) <0c1da85e-076d-3ed1-af4f-651d910023d3> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libwebpdemux.2.0.17.dylib
0x14c2d0000 - 0x14c2d9fff libwebpmux.dylib (*) <75ee4a9c-0df3-311b-b2b9-516afea936b8> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libwebpmux.dylib
0x136e89000 - 0x136e90fff libqico.dylib (*) <88d8032d-bcde-3e50-adcb-7816ff539ab5> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/imageformats/libqico.dylib
0x14c2e4000 - 0x14c2eafff libqmacheif.dylib (*) <5b2db613-81a4-3898-93bf-26b936349597> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/imageformats/libqmacheif.dylib
0x14c29e000 - 0x14c2a7fff libqjpeg.dylib (*) <e6df73db-e956-3418-9c2a-bc5243ca8510> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/imageformats/libqjpeg.dylib
0x14c2b6000 - 0x14c2befff libqtiff.dylib (*) <7f6952d3-ea0a-3ae5-839e-1af989461861> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/imageformats/libqtiff.dylib
0x14c34a000 - 0x14c351fff libqjp2.dylib (*) <4906a718-51b8-36a3-af19-e9e408122267> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/imageformats/libqjp2.dylib
0x14c35c000 - 0x14c3a9fff libjasper.7.dylib (*) <c19348be-5607-385c-a421-d0167b49c8eb> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libjasper.7.dylib
0x14c3c0000 - 0x14c3c8fff libqicns.dylib (*) <04298c04-0829-3c35-a84e-7568f7a20f6e> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/imageformats/libqicns.dylib
0x14c3f6000 - 0x14c3fafff libqtga.dylib (*) <b53731b9-6250-3222-b515-bed2178e3da2> /Applications/QGIS-final-4_0_0.app/Contents/PlugIns/imageformats/libqtga.dylib
0x14c2f5000 - 0x14c300fff math.cpython-312-darwin.so (*) <f337dff4-3ec1-35f0-8ba8-5a85f28ba32e> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/lib-dynload/math.cpython-312-darwin.so
0x14d910000 - 0x14dab7fff QtCore.abi3.so (*) <4698fdc3-c677-3f83-9882-14b85df9029d> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/PyQt6/QtCore.abi3.so
0x14c461000 - 0x14c476fff sip.cpython-312-darwin.so (*) <aaef7cdf-0b41-3540-9147-c4b8d8bdf3a3> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/PyQt6/sip.cpython-312-darwin.so
0x154f3a000 - 0x157329fff _gui.so (*) <d42ac355-bf47-31c8-ae32-de33814b8350> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/qgis/_gui.so
0x14c405000 - 0x14c418fff QtXml.abi3.so (*) <e22ea863-69cf-3a7e-9f01-ba9f932fd442> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/PyQt6/QtXml.abi3.so
0x14d725000 - 0x14d7a8fff QtNetwork.abi3.so (*) <981c0265-f402-35e1-b247-890272221791> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/PyQt6/QtNetwork.abi3.so
0x14e365000 - 0x14e4ecfff QtGui.abi3.so (*) <3f8d7dc8-a2e1-32d5-bb85-e4afa29d558a> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/PyQt6/QtGui.abi3.so
0x14dcbd000 - 0x14df58fff QtWidgets.abi3.so (*) <bc51fdf4-e1ea-3171-94a8-bcf0da3c6f43> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/PyQt6/QtWidgets.abi3.so
0x14c90c000 - 0x14c93bfff QtSql.abi3.so (*) <060a730d-d780-3659-a122-89af1ee98878> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/PyQt6/QtSql.abi3.so
0x14c48e000 - 0x14c4aefff QtPrintSupport.abi3.so (*) <3a5f9bd8-cb8f-3782-86eb-0eed882a7164> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/PyQt6/QtPrintSupport.abi3.so
0x14d538000 - 0x14d55afff QtPositioning.abi3.so (*) <ba392c78-7b56-31d1-ad3b-d7c84f316570> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/PyQt6/QtPositioning.abi3.so
0x14d85a000 - 0x14d89efff QtMultimedia.abi3.so (*) <68de7e0e-4482-34f8-af55-cc207e73aebe> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/PyQt6/QtMultimedia.abi3.so
0x14c436000 - 0x14c443fff QtSerialPort.abi3.so (*) <00f755a0-eb99-3986-8b42-22473ef1cd5c> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/PyQt6/QtSerialPort.abi3.so
0x14e6af000 - 0x150eb9fff _core.so (*) <e6e52339-c6d3-39f1-b8ef-54699eff9e69> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/qgis/_core.so
0x15363d000 - 0x1536fefff Qsci.abi3.so (*) <019ac44e-fe32-37da-9d8e-bc05f55e7589> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/PyQt6/Qsci.abi3.so
0x119cee000 - 0x119ceefff _opcode.cpython-312-darwin.so (*) <6c84c184-fab2-34b5-a94c-19ac9c362277> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/lib-dynload/_opcode.cpython-312-darwin.so
0x154531000 - 0x1549fafff _multiarray_umath.cpython-312-darwin.so (*) <d0c364ea-9334-30ce-b03f-f592c0da5f4e> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/numpy/core/_multiarray_umath.cpython-312-darwin.so
0x119ccc000 - 0x119cdbfff _datetime.cpython-312-darwin.so (*) <8b73b75c-5eec-3d51-8a5b-fb7dd4cb141d> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/lib-dynload/_datetime.cpython-312-darwin.so
0x119f53000 - 0x119f58fff _struct.cpython-312-darwin.so (*) <1c9cb245-6f85-3791-8590-6983edda6ad0> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/lib-dynload/_struct.cpython-312-darwin.so
0x14c6d0000 - 0x14c6e5fff _pickle.cpython-312-darwin.so (*) <57ff2784-bb32-3329-b8c8-56c7b58db805> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/lib-dynload/_pickle.cpython-312-darwin.so
0x119cf9000 - 0x119cf9fff _contextvars.cpython-312-darwin.so (*) <94ace964-bfe9-3013-8f47-91cf43433f9b> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/lib-dynload/_contextvars.cpython-312-darwin.so
0x14c714000 - 0x14c725fff _multiarray_tests.cpython-312-darwin.so (*) <4aaff1a0-bba3-392a-b8ac-b042ca739635> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/numpy/core/_multiarray_tests.cpython-312-darwin.so
0x14c9b8000 - 0x14c9cafff _ctypes.cpython-312-darwin.so (*) <2e2baf4b-50ef-3096-89d8-83179b03cdf0> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/lib-dynload/_ctypes.cpython-312-darwin.so
0x11a029000 - 0x11a02ffff libffi.8.dylib (*) <e13f0e60-2b23-3f5d-a45b-4f12e89d871d> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libffi.8.dylib
0x119ff3000 - 0x11a014fff _umath_linalg.cpython-312-darwin.so (*) <30b4c21a-dc7a-3494-bf7a-442816921f6d> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/numpy/linalg/_umath_linalg.cpython-312-darwin.so
0x14c735000 - 0x14c746fff _pocketfft_internal.cpython-312-darwin.so (*) <080d2ee6-2f58-3427-a4c4-0f21ed005daf> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/numpy/fft/_pocketfft_internal.cpython-312-darwin.so
0x154370000 - 0x1543defff mtrand.cpython-312-darwin.so (*) <c02194a4-01ae-3cfe-b723-ea433fbcdd15> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/numpy/random/mtrand.cpython-312-darwin.so
0x11a03a000 - 0x11a041fff zlib.cpython-312-darwin.so (*) <d2806c88-0c26-3f86-95ba-f5996545e7b8> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/lib-dynload/zlib.cpython-312-darwin.so
0x14d1e8000 - 0x14d208fff bit_generator.cpython-312-darwin.so (*) <3a20363f-26d4-3b65-8c37-16490c275168> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/numpy/random/bit_generator.cpython-312-darwin.so
0x14e28a000 - 0x14e2b0fff _common.cpython-312-darwin.so (*) <eebcc736-e9af-3b56-8529-94c9bff7b792> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/numpy/random/_common.cpython-312-darwin.so
0x14c30f000 - 0x14c313fff binascii.cpython-312-darwin.so (*) <fd672db8-c3dc-3adb-a3d8-b716058761ea> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/lib-dynload/binascii.cpython-312-darwin.so
0x14c77c000 - 0x14c782fff _hashlib.cpython-312-darwin.so (*) <97abba04-e4ba-3339-aeb9-3844cc30783c> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/lib-dynload/_hashlib.cpython-312-darwin.so
0x14c4dc000 - 0x14c4e3fff _blake2.cpython-312-darwin.so (*) <f4b7ef2d-1bcd-368e-87bb-5dd4d1edc262> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/lib-dynload/_blake2.cpython-312-darwin.so
0x13685a000 - 0x13685cfff _bisect.cpython-312-darwin.so (*) <46db0c6f-61c6-3b47-a13f-1786d99840ce> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/lib-dynload/_bisect.cpython-312-darwin.so
0x119f67000 - 0x119f68fff _random.cpython-312-darwin.so (*) <b58986e5-529f-38d7-bb5c-af78a501868e> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/lib-dynload/_random.cpython-312-darwin.so
0x14c864000 - 0x14c86efff _sha2.cpython-312-darwin.so (*) <cf6579f3-5b5f-3035-a608-f2bee66f9111> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/lib-dynload/_sha2.cpython-312-darwin.so
0x14e316000 - 0x14e350fff _bounded_integers.cpython-312-darwin.so (*) <ab188de3-c7d9-31a0-9c4f-45a86c359505> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/numpy/random/_bounded_integers.cpython-312-darwin.so
0x14c8a8000 - 0x14c8b6fff _mt19937.cpython-312-darwin.so (*) <c350585d-5298-3a7e-8492-8baec25575b5> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/numpy/random/_mt19937.cpython-312-darwin.so
0x14c978000 - 0x14c984fff _philox.cpython-312-darwin.so (*) <fa6b6389-f780-3e61-8f69-6786b0ad07f4> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/numpy/random/_philox.cpython-312-darwin.so
0x14c9e0000 - 0x14c9effff _pcg64.cpython-312-darwin.so (*) <7d0d9681-19ba-3c3b-946e-996862aa4026> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/numpy/random/_pcg64.cpython-312-darwin.so
0x14d1a4000 - 0x14d1acfff _sfc64.cpython-312-darwin.so (*) <7b05be7f-34eb-3319-b026-5559674376e7> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/numpy/random/_sfc64.cpython-312-darwin.so
0x154d97000 - 0x154e22fff _generator.cpython-312-darwin.so (*) <e29b6324-f1bf-3e5b-b570-8a657cc4739f> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/numpy/random/_generator.cpython-312-darwin.so
0x14e2c0000 - 0x14e2ddfff lib.cpython-312-darwin.so (*) <1807537d-6258-3f8c-acc0-bb6981bf7a7b> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/shapely/lib.cpython-312-darwin.so
0x154ee3000 - 0x154f17fff _geometry_helpers.cpython-312-darwin.so (*) <6ddb458e-8b4d-3f76-9001-841feddc5f8d> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/shapely/_geometry_helpers.cpython-312-darwin.so
0x14d470000 - 0x14d477fff _geos.cpython-312-darwin.so (*) <afb1d75f-3a0b-339d-9b55-7e8b9dafcdb6> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/shapely/_geos.cpython-312-darwin.so
0x14d4b4000 - 0x14d4bcfff array.cpython-312-darwin.so (*) <fc904bd4-dea9-376d-8c8e-c7e23e932e0d> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/lib-dynload/array.cpython-312-darwin.so
0x14d1b7000 - 0x14d1bcfff _json.cpython-312-darwin.so (*) <0bd91055-81d6-30bf-82ff-94b91ca410ed> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/lib-dynload/_json.cpython-312-darwin.so
0x14c792000 - 0x14c794fff _bz2.cpython-312-darwin.so (*) <7b1708ac-bc7e-3207-bc27-97290d42a50e> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/lib-dynload/_bz2.cpython-312-darwin.so
0x14d21c000 - 0x14d221fff _lzma.cpython-312-darwin.so (*) <ad03f0e2-2086-37ca-ab90-966d06d18a24> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/lib-dynload/_lzma.cpython-312-darwin.so
0x14d58e000 - 0x14d593fff pandas_parser.cpython-312-darwin.so (*) <7a90fca0-1b20-3a76-a27a-d733bf61e91f> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pandas/_libs/pandas_parser.cpython-312-darwin.so
0x14d5e4000 - 0x14d5e9fff pandas_datetime.cpython-312-darwin.so (*) <6d3795cb-e65c-3a7d-9d14-b108bcd88820> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pandas/_libs/pandas_datetime.cpython-312-darwin.so
0x158c17000 - 0x158ce3fff interval.cpython-312-darwin.so (*) <bd8d62d7-bd40-328c-9460-c74168fed639> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pandas/_libs/interval.cpython-312-darwin.so
0x1590e2000 - 0x15926dfff hashtable.cpython-312-darwin.so (*) <a687beb5-4111-3e52-8540-d71b4788924d> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pandas/_libs/hashtable.cpython-312-darwin.so
0x153f70000 - 0x153f8ffff missing.cpython-312-darwin.so (*) <c77a3ce8-f508-382c-81ee-108d25f5b372> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pandas/_libs/missing.cpython-312-darwin.so
0x1542c4000 - 0x1542e0fff dtypes.cpython-312-darwin.so (*) <911c7dc8-50cb-3536-9e13-eccfd98e0f8d> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pandas/_libs/tslibs/dtypes.cpython-312-darwin.so
0x14d650000 - 0x14d65cfff ccalendar.cpython-312-darwin.so (*) <3e85a777-6391-39d5-b017-1be0884c2c52> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pandas/_libs/tslibs/ccalendar.cpython-312-darwin.so
0x1544fe000 - 0x154514fff np_datetime.cpython-312-darwin.so (*) <b1e8f779-19e2-303d-bbab-aa420e7ff0fd> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pandas/_libs/tslibs/np_datetime.cpython-312-darwin.so
0x154ad2000 - 0x154afefff conversion.cpython-312-darwin.so (*) <f3771e88-07d8-352c-acc1-93e441f97c2f> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pandas/_libs/tslibs/conversion.cpython-312-darwin.so
0x153dc8000 - 0x153dcffff base.cpython-312-darwin.so (*) <e87e7730-e69f-3509-b48f-229a002040b6> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pandas/_libs/tslibs/base.cpython-312-darwin.so
0x1592d8000 - 0x15938efff offsets.cpython-312-darwin.so (*) <fbe781a1-9f01-33aa-8628-a48142560af3> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pandas/_libs/tslibs/offsets.cpython-312-darwin.so
0x158fd2000 - 0x159039fff timestamps.cpython-312-darwin.so (*) <7dc49fcf-59f2-3efc-a75e-54b49948c0b3> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pandas/_libs/tslibs/timestamps.cpython-312-darwin.so
0x154e3b000 - 0x154e5cfff nattype.cpython-312-darwin.so (*) <c9cdf597-38f1-3307-ac2f-c7ae675c9fbc> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pandas/_libs/tslibs/nattype.cpython-312-darwin.so
0x158f4a000 - 0x158facfff timedeltas.cpython-312-darwin.so (*) <5901643a-9e46-3b37-88f8-977c009ca21a> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pandas/_libs/tslibs/timedeltas.cpython-312-darwin.so
0x158b87000 - 0x158bb2fff timezones.cpython-312-darwin.so (*) <616cc984-b56c-3189-946e-b57768418e99> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pandas/_libs/tslibs/timezones.cpython-312-darwin.so
0x14d5f4000 - 0x14d5f9fff _zoneinfo.cpython-312-darwin.so (*) <5272dd8e-91c3-3751-99e4-dcf57340d635> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/lib-dynload/_zoneinfo.cpython-312-darwin.so
0x15907c000 - 0x1590b2fff fields.cpython-312-darwin.so (*) <d178f8c9-5ad9-36f0-8f4a-3041ddbf3630> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pandas/_libs/tslibs/fields.cpython-312-darwin.so
0x14c879000 - 0x14c87bfff fcntl.cpython-312-darwin.so (*) <fcab796d-afab-3340-8038-a732cb72c577> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/lib-dynload/fcntl.cpython-312-darwin.so
0x14d486000 - 0x14d488fff _posixsubprocess.cpython-312-darwin.so (*) <b920c2cb-27b1-3a7d-b322-5c277f263dfe> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/lib-dynload/_posixsubprocess.cpython-312-darwin.so
0x15362e000 - 0x153632fff select.cpython-312-darwin.so (*) <687c1fc4-3355-3a3c-a0e0-32de3f8522c8> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/lib-dynload/select.cpython-312-darwin.so
0x158df6000 - 0x158e27fff tzconversion.cpython-312-darwin.so (*) <212070a9-8558-3ab6-815b-5bd830976637> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pandas/_libs/tslibs/tzconversion.cpython-312-darwin.so
0x153f2c000 - 0x153f37fff properties.cpython-312-darwin.so (*) <4b6bb29c-699b-31af-8e70-fdcd092d1301> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pandas/_libs/properties.cpython-312-darwin.so
0x159509000 - 0x15954ffff parsing.cpython-312-darwin.so (*) <10f1909e-904c-3787-9d65-43c7a8f0f70b> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pandas/_libs/tslibs/parsing.cpython-312-darwin.so
0x1596a1000 - 0x1596e2fff _decimal.cpython-312-darwin.so (*) <0c66e329-0bd6-3c88-be1b-cc305dd5887e> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/lib-dynload/_decimal.cpython-312-darwin.so
0x15972d000 - 0x159768fff strptime.cpython-312-darwin.so (*) <9af8b2de-8dd8-3868-bcd7-726fa6f5a7e6> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pandas/_libs/tslibs/strptime.cpython-312-darwin.so
0x159923000 - 0x159974fff period.cpython-312-darwin.so (*) <d04d66fb-371c-3e86-bd5e-eed400e398a5> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pandas/_libs/tslibs/period.cpython-312-darwin.so
0x1595f5000 - 0x159619fff vectorized.cpython-312-darwin.so (*) <07bf7bb1-f40b-3b81-9c0a-dec95f689b90> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pandas/_libs/tslibs/vectorized.cpython-312-darwin.so
0x153fa3000 - 0x153faafff ops_dispatch.cpython-312-darwin.so (*) <51350661-c6c2-3534-bff8-d9c7227766b7> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pandas/_libs/ops_dispatch.cpython-312-darwin.so
0x159cee000 - 0x159e6bfff algos.cpython-312-darwin.so (*) <a623d911-f11e-35ee-90f8-e671dacdf504> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pandas/_libs/algos.cpython-312-darwin.so
0x159bf7000 - 0x159c84fff lib.cpython-312-darwin.so (*) <ad029bdb-f0c5-39d0-a5a4-ed554f0b19ec> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pandas/_libs/lib.cpython-312-darwin.so
0x15a0ed000 - 0x15a1fcfff unicodedata.cpython-312-darwin.so (*) <3acc9282-67aa-384d-a1b6-55412bc5dfe1> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/lib-dynload/unicodedata.cpython-312-darwin.so
0x1597b9000 - 0x1597e0fff ops.cpython-312-darwin.so (*) <1f8bee9a-8626-351c-a84d-0c6b2618dc98> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pandas/_libs/ops.cpython-312-darwin.so
0x159865000 - 0x159883fff hashing.cpython-312-darwin.so (*) <117d54e1-f59c-3377-9e09-4d1555440120> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pandas/_libs/hashing.cpython-312-darwin.so
0x153fd8000 - 0x153fe9fff arrays.cpython-312-darwin.so (*) <f14bc99c-dc98-3360-9ff6-ea64e2e290cf> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pandas/_libs/arrays.cpython-312-darwin.so
0x15411c000 - 0x154121fff _csv.cpython-312-darwin.so (*) <dc6c304a-ff13-3ed6-9966-a865a3fea6dc> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/lib-dynload/_csv.cpython-312-darwin.so
0x15a09c000 - 0x15a0d1fff tslib.cpython-312-darwin.so (*) <a504465b-610b-3d01-9258-b12c83db555c> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pandas/_libs/tslib.cpython-312-darwin.so
0x15a4d3000 - 0x15a584fff sparse.cpython-312-darwin.so (*) <bcd0b4a3-14f2-3227-9e4a-4c53cec0d5f0> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pandas/_libs/sparse.cpython-312-darwin.so
0x15a408000 - 0x15a447fff internals.cpython-312-darwin.so (*) <b2e6a767-d297-3026-a6bb-2986286410df> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pandas/_libs/internals.cpython-312-darwin.so
0x154280000 - 0x154288fff indexing.cpython-312-darwin.so (*) <22e45744-c3ab-376a-a91f-e8e0ce804bbb> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pandas/_libs/indexing.cpython-312-darwin.so
0x15a83e000 - 0x15a8d6fff index.cpython-312-darwin.so (*) <117dd40f-6c63-30dc-a6a7-dbfd996660fb> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pandas/_libs/index.cpython-312-darwin.so
0x159ecc000 - 0x159eeffff writers.cpython-312-darwin.so (*) <e4a77009-53b1-33c5-bc24-2ffb6609da5d> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pandas/_libs/writers.cpython-312-darwin.so
0x15a6ae000 - 0x15a797fff join.cpython-312-darwin.so (*) <3e5b0b1a-e6ff-360a-8aab-21a46a44dda6> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pandas/_libs/join.cpython-312-darwin.so
0x153dde000 - 0x153de1fff mmap.cpython-312-darwin.so (*) <cf65d791-7070-39c9-a244-ea7a52da3006> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/lib-dynload/mmap.cpython-312-darwin.so
0x14c31e000 - 0x14c31ffff grp.cpython-312-darwin.so (*) <d7f6e3b5-88b0-3a39-97a3-83f6c143beaf> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/lib-dynload/grp.cpython-312-darwin.so
0x15abcb000 - 0x15ac0dfff aggregations.cpython-312-darwin.so (*) <3c7546dd-f43d-3cd2-82c7-54827f87bc36> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pandas/_libs/window/aggregations.cpython-312-darwin.so
0x15a034000 - 0x15a052fff indexers.cpython-312-darwin.so (*) <29d9162c-1047-3931-bdde-a8784a1c4e58> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pandas/_libs/window/indexers.cpython-312-darwin.so
0x15a36b000 - 0x15a39bfff reshape.cpython-312-darwin.so (*) <a4e3a51b-f9b9-37da-993b-2ef93adc3e86> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pandas/_libs/reshape.cpython-312-darwin.so
0x15b190000 - 0x15b362fff groupby.cpython-312-darwin.so (*) <df4b62c2-5c0b-3cd8-b71c-5a23f0369b6f> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pandas/_libs/groupby.cpython-312-darwin.so
0x14c751000 - 0x14c751fff _uuid.cpython-312-darwin.so (*) <2f639e6f-e1d7-3c3f-9f4f-7fe2e848bf71> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/lib-dynload/_uuid.cpython-312-darwin.so
0x1542f5000 - 0x1542fffff json.cpython-312-darwin.so (*) <4156c2c3-aebe-3093-91aa-9d7a84f8546b> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pandas/_libs/json.cpython-312-darwin.so
0x15b0bf000 - 0x15b11cfff parsers.cpython-312-darwin.so (*) <426a5517-e3ab-3c97-a35a-571d3172a407> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pandas/_libs/parsers.cpython-312-darwin.so
0x154436000 - 0x154446fff testing.cpython-312-darwin.so (*) <c613b5ed-8fb1-3d22-8213-a10e4dc21cfe> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pandas/_libs/testing.cpython-312-darwin.so
0x15412c000 - 0x154132fff cmath.cpython-312-darwin.so (*) <b0083006-e6a0-34bb-9bed-1c3f3b88e6ad> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/lib-dynload/cmath.cpython-312-darwin.so
0x15447a000 - 0x154488fff _context.cpython-312-darwin.so (*) <14bba4c0-26a7-31c9-936c-941c22cadf86> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pyproj/_context.cpython-312-darwin.so
0x154b3a000 - 0x154b40fff _compat.cpython-312-darwin.so (*) <2be3bb77-212c-31d8-acad-8a6793284ed5> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pyproj/_compat.cpython-312-darwin.so
0x154b7e000 - 0x154b84fff _network.cpython-312-darwin.so (*) <a4a3c3b0-4248-3450-96bd-d90945cf3675> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pyproj/_network.cpython-312-darwin.so
0x154bc2000 - 0x154bd0fff _socket.cpython-312-darwin.so (*) <4520903a-8964-3c38-a400-bbf2d0b1d9ab> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/lib-dynload/_socket.cpython-312-darwin.so
0x154b4f000 - 0x154b52fff _version.cpython-312-darwin.so (*) <a9b3d661-5ee8-34cf-be14-9fecd2ced5f6> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pyproj/_version.cpython-312-darwin.so
0x15afce000 - 0x15b01dfff _crs.cpython-312-darwin.so (*) <32928b0d-9151-38fc-b297-de477226559d> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pyproj/_crs.cpython-312-darwin.so
0x158bef000 - 0x158c03fff _geod.cpython-312-darwin.so (*) <ef51a174-2773-3e9a-95f1-d02603bad255> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pyproj/_geod.cpython-312-darwin.so
0x154d4a000 - 0x154d50fff list.cpython-312-darwin.so (*) <85715a9c-c361-3ee6-882d-acc09244555c> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pyproj/list.cpython-312-darwin.so
0x158817000 - 0x158828fff database.cpython-312-darwin.so (*) <d130b818-6abc-325e-ab60-14bda0a69da2> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pyproj/database.cpython-312-darwin.so
0x15a466000 - 0x15a486fff _transformer.cpython-312-darwin.so (*) <7af0b667-cb2b-3e7d-a8f5-03062b3b6daf> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pyproj/_transformer.cpython-312-darwin.so
0x15ab2f000 - 0x15ab46fff _ssl.cpython-312-darwin.so (*) <e60662b5-4dcb-3906-bd80-4d1f8a19e7da> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/lib-dynload/_ssl.cpython-312-darwin.so
0x14d4cb000 - 0x14d4cbfff _scproxy.cpython-312-darwin.so (*) <7d26d5a2-6bad-37fc-a60d-f42dcbc690b8> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/lib-dynload/_scproxy.cpython-312-darwin.so
0x154ea3000 - 0x154ea7fff _sync.cpython-312-darwin.so (*) <13b0ac14-43b2-322c-b384-c18256149b83> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/pyproj/_sync.cpython-312-darwin.so
0x154297000 - 0x154297fff _statistics.cpython-312-darwin.so (*) <fdd4c7c6-ee1d-3c03-a625-8592cd2e1b0d> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/lib-dynload/_statistics.cpython-312-darwin.so
0x15c2fc000 - 0x15c421fff _gdal.cpython-312-darwin.so (*) <40274ff1-32a6-352a-aed1-d2ea67cd0415> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/osgeo/_gdal.cpython-312-darwin.so
0x15899b000 - 0x1589a3fff _gdalconst.cpython-312-darwin.so (*) <e44f7fdf-20c4-3adb-a5a8-f6b42baf0854> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/osgeo/_gdalconst.cpython-312-darwin.so
0x15c64c000 - 0x15c6fefff _ogr.cpython-312-darwin.so (*) <cae2d849-3c68-337b-a08e-0665120ea9c9> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/osgeo/_ogr.cpython-312-darwin.so
0x15b5a9000 - 0x15b60cfff _osr.cpython-312-darwin.so (*) <45fa9714-9d8b-3111-b9d1-eace31c860b4> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/osgeo/_osr.cpython-312-darwin.so
0x1597f5000 - 0x159807fff _gdal_array.cpython-312-darwin.so (*) <504e7002-d3a4-3167-8492-9b284461fb1c> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/osgeo/_gdal_array.cpython-312-darwin.so
0x1589ff000 - 0x158a0ffff _gnm.cpython-312-darwin.so (*) <5fa8178d-8279-37a7-902c-bea2a972b595> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/osgeo/_gnm.cpython-312-darwin.so
0x154b93000 - 0x154b96fff _heapq.cpython-312-darwin.so (*) <1e27bccc-348a-3674-aa4d-da8b986cb95a> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/lib-dynload/_heapq.cpython-312-darwin.so
0x154524000 - 0x154525fff _queue.cpython-312-darwin.so (*) <ee75f576-3510-3e90-9a1c-307bf8042801> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/lib-dynload/_queue.cpython-312-darwin.so
0x158a43000 - 0x158a48fff _multibytecodec.cpython-312-darwin.so (*) <4c5d37ae-de89-3152-b9c9-dbf68ffa5aab> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/lib-dynload/_multibytecodec.cpython-312-darwin.so
0x15cd2a000 - 0x15cec4fff etree.cpython-312-darwin.so (*) <44d0c9b3-e25c-3fba-8750-f969bfe20eb4> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/lxml/etree.cpython-312-darwin.so
0x15b8ad000 - 0x15b8d9fff libxslt.1.dylib (*) <f8c6c10b-3d2a-3be7-a070-0d0a8d9d0fb7> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libxslt.1.dylib
0x158d2a000 - 0x158d39fff libexslt.0.dylib (*) <10dc4d10-d4ea-394e-a9f4-4a30dbb1e60f> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libexslt.0.dylib
0x15b8ec000 - 0x15b90dfff _elementpath.cpython-312-darwin.so (*) <6458ee24-a234-3340-9d0a-14aa00b2a49c> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/lxml/_elementpath.cpython-312-darwin.so
0x158d6e000 - 0x158d78fff _elementtree.cpython-312-darwin.so (*) <8353f890-fef3-312a-a6e9-36a036e00625> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/lib-dynload/_elementtree.cpython-312-darwin.so
0x158db2000 - 0x158dbbfff pyexpat.cpython-312-darwin.so (*) <d9be030f-2155-30a0-87b6-12cbd98ecd5c> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/lib-dynload/pyexpat.cpython-312-darwin.so
0x154d5f000 - 0x154d5ffff _speedups.cpython-312-darwin.so (*) <42e50ab3-1598-3d05-8b09-ca0f4e745616> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/markupsafe/_speedups.cpython-312-darwin.so
0x15d676000 - 0x15d774fff _analysis.so (*) <b218d2d6-966e-3fec-8f6d-c0c116f48aca> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/qgis/_analysis.so
0x15b801000 - 0x15b82afff _psycopg.cpython-312-darwin.so (*) <e38ec342-2e42-3c1b-9666-388faaf7b1b9> /Applications/QGIS-final-4_0_0.app/Contents/Resources/python3.11/site-packages/psycopg2/_psycopg.cpython-312-darwin.so
0x14bc7f000 - 0x14bc84fff libqquicklayoutsplugin.dylib (*) <0ebd3e43-e518-311b-91c1-43f0301a4af0> /Applications/QGIS-final-4_0_0.app/Contents/Qt6/qml/QtQuick/Layouts/libqquicklayoutsplugin.dylib
0x15c59d000 - 0x15c5c2fff libQt6QuickLayouts.6.dylib (*) <42802061-14d3-3438-9704-eb261261b99d> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libQt6QuickLayouts.6.dylib
0x14bc55000 - 0x14bc5efff libqtquickcontrols2plugin.dylib (*) <bfe8fd4f-0d6c-3ce5-b886-40a64e76395e> /Applications/QGIS-final-4_0_0.app/Contents/Qt6/qml/QtQuick/Controls/libqtquickcontrols2plugin.dylib
0x15c853000 - 0x15c881fff libQt6QuickControls2Impl.dylib (*) <dc490a77-16bc-3df4-b852-3e4f28117af0> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libQt6QuickControls2Impl.dylib
0x14bc69000 - 0x14bc6ffff libqtquickcontrols2materialstyleplugin.dylib (*) <5331d70a-95c6-3263-afae-5eeab09e32d6> /Applications/QGIS-final-4_0_0.app/Contents/Qt6/qml/QtQuick/Controls/Material/libqtquickcontrols2materialstyleplugin.dylib
0x15f476000 - 0x15f5f1fff libQt6QuickControls2Material.6.dylib (*) <77bc973f-16b5-3c2b-b7ec-87d883c221cc> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libQt6QuickControls2Material.6.dylib
0x14bcaf000 - 0x14bce8fff libQt6QuickControls2MaterialStyleImpl.dylib (*) <63722365-80dc-3d3d-b28b-91e39cb46703> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libQt6QuickControls2MaterialStyleImpl.dylib
0x14bd66000 - 0x14bd6cfff libqtquickcontrols2basicstyleplugin.dylib (*) <c4a21fca-d2e3-3b1f-a0eb-e90049c4f622> /Applications/QGIS-final-4_0_0.app/Contents/Qt6/qml/QtQuick/Controls/Basic/libqtquickcontrols2basicstyleplugin.dylib
0x15ee5d000 - 0x15efd4fff libQt6QuickControls2Basic.6.dylib (*) <f92cdfbe-c3f6-3dca-a419-c1381b522291> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libQt6QuickControls2Basic.6.dylib
0x14bd3b000 - 0x14bd46fff libQt6QuickControls2BasicStyleImpl.dylib (*) <32b4986a-836c-3917-aab9-f1e353c88ecd> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libQt6QuickControls2BasicStyleImpl.dylib
0x14bd77000 - 0x14bd7cfff libeffectsplugin.dylib (*) <5968d74f-a1eb-37f1-b279-b4b34672061a> /Applications/QGIS-final-4_0_0.app/Contents/Qt6/qml/QtQuick/Effects/libeffectsplugin.dylib
0x15cbab000 - 0x15cbf2fff libQt6QuickEffects.dylib (*) <86341ac8-020d-3f13-b51e-f76ce09b86d4> /Applications/QGIS-final-4_0_0.app/Contents/Frameworks/libQt6QuickEffects.dylib
0x154e71000 - 0x154e76fff libqtquicktemplates2plugin.dylib (*) <1427e88f-d28f-3430-bfdf-d94b8f98168c> /Applications/QGIS-final-4_0_0.app/Contents/Qt6/qml/QtQuick/Templates/libqtquicktemplates2plugin.dylib
0x14bd87000 - 0x14bd8afff libquickwindowplugin.dylib (*) <da7bfb52-f07a-3a80-98c3-29b092463012> /Applications/QGIS-final-4_0_0.app/Contents/Qt6/qml/QtQuick/Window/libquickwindowplugin.dylib
0x7ff81c062000 - 0x7ff81c06bc4f libsystem_platform.dylib (*) <fc0c42b2-0b55-370b-8fc7-17bac96bb458> /usr/lib/system/libsystem_platform.dylib
0x0 - 0xffffffffffffffff ??? (*) <00000000-0000-0000-0000-000000000000> ???
0x7ff81c017000 - 0x7ff81c054917 libsystem_kernel.dylib (*) <2a7e104e-0d59-34a8-83d9-cc70154464eb> /usr/lib/system/libsystem_kernel.dylib
0x7ff81c09b000 - 0x7ff81c556e02 com.apple.CoreFoundation (6.9) <513bef17-6379-3bb8-897b-69a7999d5abf> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7ff81d32f000 - 0x7ff81e321d62 com.apple.Foundation (6.9) <ec8bb14d-3fce-346e-9b31-29429579e895> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7ff81ff29000 - 0x7ff8217230fa com.apple.AppKit (6.9) <2bd11255-89ea-38b5-b640-4dac3f1ae380> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7ff81be9f000 - 0x7ff81bee6921 libdispatch.dylib (*) <22d4457f-c2ab-36da-a743-e92bef816167> /usr/lib/system/libdispatch.dylib
0x7ff81c055000 - 0x7ff81c061027 libsystem_pthread.dylib (*) <f9c81fc7-1abf-3b5e-a6b3-3113dad29577> /usr/lib/system/libsystem_pthread.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=2.1G resident=0K(0%) swapped_out_or_unallocated=2.1G(100%)
Writable regions: Total=837.1M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=837.1M(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 128K 1
Activity Tracing 256K 1
AttributeGraph Data 1024K 1
ColorSync 8K 1
CoreAnimation 808K 71
CoreGraphics 24K 4
CoreUI image data 568K 5
Foundation 16K 1
JS VM Gigacage 4096K 1
JS VM Isolated Heap 4368K 4
JS VM Isolated Heap (reserved) 2048K 1 reserved VM address space (unallocated)
Kernel Alloc Once 12K 2
MALLOC 738.6M 220
MALLOC guard page 64K 16
MALLOC_LARGE (reserved) 384K 1 reserved VM address space (unallocated)
STACK GUARD 56.1M 18
Stack 24.1M 19
VM_ALLOCATE 57.1M 77
__CTF 824 1
__DATA 54.2M 1411
__DATA_CONST 141.6M 1369
__DATA_DIRTY 7905K 867
__FONT_DATA 2352 1
__GLSLBUILTINS 5174K 1
__INFO_FILTER 8 1
__LINKEDIT 413.1M 347
__OBJC_RO 64.4M 1
__OBJC_RW 2570K 2
__TEXT 1.7G 1384
__TEXT (graphics) 16.8M 6
__TPRO_CONST 4K 1
dyld private memory 23.5M 165
mapped file 557.7M 85
shared memory 1324K 22
TOTAL 3.8G 6108
TOTAL, minus reserved VM space 3.8G 6108
Full Report
{"app_name":"QGIS-final-4_0_0","timestamp":"2026-03-23 08:47:15.00 -0400","app_version":"4.0.0","slice_uuid":"b4ac657c-b39b-3017-a936-9895008feacb","build_version":"4.0.0","platform":1,"bundleID":"org.qgis.qgis3","share_with_app_devs":1,"is_first_party":0,"bug_type":"309","os_version":"macOS 26.3.1 (25D771280a)","roots_installed":0,"name":"QGIS-final-4_0_0","incident_id":"5D263B81-277F-49A8-91F5-5EE51F34178A"}
"uptime" : 3700,
"procRole" : "Foreground",
"version" : 2,
"userID" : 501,
"deployVersion" : 210,
"modelCode" : "MacBookPro16,1",
"coalitionID" : 2116,
"osVersion" : {
"train" : "macOS 26.3.1",
"build" : "25D771280a",
"releaseType" : "User"
"captureTime" : "2026-03-23 08:47:00.8343 -0400",
"codeSigningMonitor" : 0,
"incident" : "5D263B81-277F-49A8-91F5-5EE51F34178A",
"pid" : 10161,
"cpuType" : "X86-64",
"procLaunch" : "2026-03-23 08:46:46.2202 -0400",
"procStartAbsTime" : 3698631679989,
"procExitAbsTime" : 3713241447911,
"procName" : "QGIS-final-4_0_0",
"procPath" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/MacOS\/QGIS-final-4_0_0",
"bundleInfo" : {"CFBundleShortVersionString":"4.0.0","CFBundleVersion":"4.0.0","CFBundleIdentifier":"org.qgis.qgis3"},
"storeInfo" : {"deviceIdentifierForVendor":"2399044C-3160-5A5F-AD17-20090AFDB104","thirdParty":true},
"parentProc" : "launchd",
"parentPid" : 1,
"coalitionName" : "org.qgis.qgis3",
"crashReporterKey" : "CC0F037F-16B6-6F72-672B-5CD939A1E087",
"appleIntelligenceStatus" : {"state":"unavailable","reasons":["deviceNotCapable"]},
"developerMode" : 1,
"codeSigningID" : "org.qgis.qgis3",
"codeSigningTeamID" : "4F7N4UDA22",
"codeSigningFlags" : 570495745,
"codeSigningValidationCategory" : 6,
"codeSigningTrustLevel" : 4294967295,
"codeSigningAuxiliaryInfo" : 0,
"bootSessionUUID" : "2EC78C2B-B0A0-41A2-8155-8ED45EDF8222",
"bridgeVersion" : {"build":"23P3120","train":"10.3"},
"sip" : "enabled",
"vmRegionInfo" : "0 is not in any region. Bytes before following region: 4435431424\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n UNUSED SPACE AT START\n---> \n __TEXT 1085f5000-108671000 [ 496K] r-x\/r-x SM=COW \/Applications\/QGIS-final-4_0_0.app\/Contents\/MacOS\/QGIS-final-4_0_0",
"exception" : {"codes":"0x000000000000000d, 0x0000000000000000","rawCodes":[13,0],"type":"EXC_BAD_ACCESS","signal":"SIGSEGV","subtype":"UNKNOWN_0xD at 0x0000000000000000"},
"termination" : {"flags":0,"code":11,"namespace":"SIGNAL","indicator":"Segmentation fault: 11","byProc":"exc handler","byPid":10161},
"ktriageinfo" : "VM - (arg = 0x3) mach_vm_allocate_kernel failed within call to vm_map_enter\nVM - (arg = 0x3) mach_vm_allocate_kernel failed within call to vm_map_enter\nVM - (arg = 0x3) mach_vm_allocate_kernel failed within call to vm_map_enter\nVM - (arg = 0x3) mach_vm_allocate_kernel failed within call to vm_map_enter\nVM - (arg = 0x3) mach_vm_allocate_kernel failed within call to vm_map_enter\n",
"vmregioninfo" : "0 is not in any region. Bytes before following region: 4435431424\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n UNUSED SPACE AT START\n---> \n __TEXT 1085f5000-108671000 [ 496K] r-x\/r-x SM=COW \/Applications\/QGIS-final-4_0_0.app\/Contents\/MacOS\/QGIS-final-4_0_0",
"extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
"faultingThread" : 0,
"threads" : [{"triggered":true,"id":99745,"instructionState":{"instructionStream":{"bytes":[137,119,40,76,137,127,48,72,139,4,36,101,72,51,4,37,56,0,0,0,72,137,71,56,72,141,68,36,8,101,72,51,4,37,56,0,0,0,72,137,71,16,217,127,76,15,174,95,72,49,192,195,219,227,133,246,184,1,0,0,0,15,69,198,72,139,31,72,139,119,8,101,72,51,52,37,56,0,0,0,72,137,245,72,139,119,16,101,72,51,52,37,56,0,0,0,76,15,190,38,72,137,244,76,139,103,24,76,139,111,32,76,139,119,40,76,139,127,48,72,139,119,56,101,72,51,52,37,56,0,0,0,217,111,76,15,174,87,72,252,255,230,64,246,199,1,184,0,0,0,128,190,0,0,0,64,15,68,240,49,255,49,210,233,160,66,0,0,0,85,72,137,229,232,4,0,0,0,49,192,93,195,85,72,137,229,65,87,65,86,65,85],"offset":96}},"threadState":{"r13":{"value":0},"rax":{"value":1},"rflags":{"value":66050},"cpu":{"value":6},"r14":{"value":656},"rsi":{"value":921809158653302415},"r8":{"value":2309079047},"cr2":{"value":0},"rdx":{"value":0},"r10":{"value":140703598487122,"symbolLocation":10,"symbol":"sigprocmask"},"r9":{"value":63},"r15":{"value":140357271725056},"rbx":{"value":105553132166304},"trap":{"value":13},"err":{"value":0},"r11":{"value":582},"rip":{"value":140703598795512,"matchesCrashFrame":1},"rbp":{"value":927706939024692879},"rsp":{"value":140701913322984},"r12":{"value":140701913324224},"rcx":{"value":140703598514586,"symbolLocation":10,"symbol":"__sigreturn"},"flavor":"x86_THREAD_STATE","rdi":{"value":140357270861800}},"queue":"com.apple.main-thread","frames":[{"imageOffset":15096,"symbol":"_longjmp","symbolLocation":44,"imageIndex":345},{"imageOffset":18789,"symbol":"my_error_exit(jpeg_common_struct*)","symbolLocation":37,"imageIndex":191}]},{"id":99779,"frames":[],"threadState":{"r13":{"value":0},"rax":{"value":33554800},"rflags":{"value":512},"cpu":{"value":0},"r14":{"value":1},"rsi":{"value":9987},"r8":{"value":409604},"cr2":{"value":0},"rdx":{"value":123145520488448},"r10":{"value":0},"r9":{"value":18446744073709551615},"r15":{"value":123145521011576},"rbx":{"value":123145521012736},"trap":{"value":133},"err":{"value":33554800},"r11":{"value":582},"rip":{"value":140703598733364},"rbp":{"value":0},"rsp":{"value":123145521012736},"r12":{"value":5128198},"rcx":{"value":0},"flavor":"x86_THREAD_STATE","rdi":{"value":123145521012736}}},{"id":99907,"threadState":{"r13":{"value":21592279046},"rax":{"value":268451845},"rflags":{"value":518},"cpu":{"value":0},"r14":{"value":371682174828544},"rsi":{"value":21592279046},"r8":{"value":0},"cr2":{"value":0},"rdx":{"value":8589934592},"r10":{"value":371682174828544},"r9":{"value":371682174828544},"r15":{"value":2},"rbx":{"value":123145521545008},"trap":{"value":133},"err":{"value":16777263},"r11":{"value":518},"rip":{"value":140703598476110},"rbp":{"value":123145521544848},"rsp":{"value":123145521544744},"r12":{"value":371682174828544},"rcx":{"value":123145521544744},"flavor":"x86_THREAD_STATE","rdi":{"value":123145521545008}},"queue":"com.apple.root.user-interactive-qos","frames":[{"imageOffset":2894,"symbol":"mach_msg2_trap","symbolLocation":10,"imageIndex":347},{"imageOffset":61260,"symbol":"mach_msg2_internal","symbolLocation":83,"imageIndex":347},{"imageOffset":31651,"symbol":"mach_msg_overwrite","symbolLocation":574,"imageIndex":347},{"imageOffset":3655,"symbol":"mach_msg","symbolLocation":19,"imageIndex":347},{"imageOffset":390863,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":145,"imageIndex":348},{"imageOffset":385462,"symbol":"__CFRunLoopRun","symbolLocation":1354,"imageIndex":348},{"imageOffset":1116400,"symbol":"_CFRunLoopRunSpecificWithOptions","symbolLocation":496,"imageIndex":348},{"imageOffset":11415207,"symbol":"-[NSRunLoop(NSRunLoop) runMode:beforeDate:]","symbolLocation":216,"imageIndex":349},{"imageOffset":5704870,"symbol":"-[NSAnimation _runBlocking]","symbolLocation":522,"imageIndex":350},{"imageOffset":5817,"symbol":"_dispatch_call_block_and_release","symbolLocation":12,"imageIndex":351},{"imageOffset":97262,"symbol":"_dispatch_client_callout","symbolLocation":6,"imageIndex":351},{"imageOffset":207219,"symbol":"_dispatch_root_queue_drain.cold.3","symbolLocation":788,"imageIndex":351},{"imageOffset":68496,"symbol":"_dispatch_root_queue_drain","symbolLocation":98,"imageIndex":351},{"imageOffset":69674,"symbol":"_dispatch_worker_thread2","symbolLocation":174,"imageIndex":351},{"imageOffset":10280,"symbol":"_pthread_wqthread","symbolLocation":233,"imageIndex":352},{"imageOffset":6211,"symbol":"start_wqthread","symbolLocation":15,"imageIndex":352}]},{"id":99923,"name":"com.apple.NSEventThread","threadState":{"r13":{"value":21592279046},"rax":{"value":268451845},"rflags":{"value":518},"cpu":{"value":0},"r14":{"value":102267466285056},"rsi":{"value":21592279046},"r8":{"value":0},"cr2":{"value":0},"rdx":{"value":8589934592},"r10":{"value":102267466285056},"r9":{"value":102267466285056},"r15":{"value":2},"rbx":{"value":123145522618512},"trap":{"value":133},"err":{"value":16777263},"r11":{"value":518},"rip":{"value":140703598476110},"rbp":{"value":123145522618352},"rsp":{"value":123145522618248},"r12":{"value":102267466285056},"rcx":{"value":123145522618248},"flavor":"x86_THREAD_STATE","rdi":{"value":123145522618512}},"frames":[{"imageOffset":2894,"symbol":"mach_msg2_trap","symbolLocation":10,"imageIndex":347},{"imageOffset":61260,"symbol":"mach_msg2_internal","symbolLocation":83,"imageIndex":347},{"imageOffset":31651,"symbol":"mach_msg_overwrite","symbolLocation":574,"imageIndex":347},{"imageOffset":3655,"symbol":"mach_msg","symbolLocation":19,"imageIndex":347},{"imageOffset":390863,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":145,"imageIndex":348},{"imageOffset":385462,"symbol":"__CFRunLoopRun","symbolLocation":1354,"imageIndex":348},{"imageOffset":1116400,"symbol":"_CFRunLoopRunSpecificWithOptions","symbolLocation":496,"imageIndex":348},{"imageOffset":815393,"symbol":"_NSEventThread","symbolLocation":158,"imageIndex":350},{"imageOffset":24141,"symbol":"_pthread_start","symbolLocation":115,"imageIndex":352},{"imageOffset":6231,"symbol":"thread_start","symbolLocation":15,"imageIndex":352}]},{"id":99963,"name":"Thread (pooled)","threadState":{"r13":{"value":93462783350272},"rax":{"value":260},"rflags":{"value":583},"cpu":{"value":0},"r14":{"value":105553151699776},"rsi":{"value":93462783350272},"r8":{"value":0},"cr2":{"value":0},"rdx":{"value":21760},"r10":{"value":0},"r9":{"value":160},"r15":{"value":21760},"rbx":{"value":123145523159040},"trap":{"value":133},"err":{"value":33554737},"r11":{"value":582},"rip":{"value":140703598487290},"rbp":{"value":123145523158576},"rsp":{"value":123145523158424},"r12":{"value":123145523158448},"rcx":{"value":123145523158424},"flavor":"x86_THREAD_STATE","rdi":{"value":105553151699776}},"frames":[{"imageOffset":14074,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":347},{"imageOffset":25334,"symbol":"_pthread_cond_wait","symbolLocation":988,"imageIndex":352},{"imageOffset":2497786,"symbol":"QWaitConditionPrivate::wait(QDeadlineTimer)","symbolLocation":266,"imageIndex":65},{"imageOffset":2497432,"symbol":"QWaitCondition::wait(QMutex*, QDeadlineTimer)","symbolLocation":88,"imageIndex":65},{"imageOffset":2474410,"symbol":"QThreadPoolThread::run()","symbolLocation":1002,"imageIndex":65},{"imageOffset":2438563,"symbol":"QThreadPrivate::start(void*)","symbolLocation":371,"imageIndex":65},{"imageOffset":24141,"symbol":"_pthread_start","symbolLocation":115,"imageIndex":352},{"imageOffset":6231,"symbol":"thread_start","symbolLocation":15,"imageIndex":352}]},{"id":99964,"name":"Thread (pooled)","threadState":{"r13":{"value":92363271722240},"rax":{"value":260},"rflags":{"value":583},"cpu":{"value":0},"r14":{"value":105553151700160},"rsi":{"value":92363271722240},"r8":{"value":0},"cr2":{"value":0},"rdx":{"value":21504},"r10":{"value":0},"r9":{"value":160},"r15":{"value":21504},"rbx":{"value":123145523695616},"trap":{"value":133},"err":{"value":33554737},"r11":{"value":582},"rip":{"value":140703598487290},"rbp":{"value":123145523695152},"rsp":{"value":123145523695000},"r12":{"value":123145523695024},"rcx":{"value":123145523695000},"flavor":"x86_THREAD_STATE","rdi":{"value":105553151700160}},"frames":[{"imageOffset":14074,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":347},{"imageOffset":25334,"symbol":"_pthread_cond_wait","symbolLocation":988,"imageIndex":352},{"imageOffset":2497786,"symbol":"QWaitConditionPrivate::wait(QDeadlineTimer)","symbolLocation":266,"imageIndex":65},{"imageOffset":2497432,"symbol":"QWaitCondition::wait(QMutex*, QDeadlineTimer)","symbolLocation":88,"imageIndex":65},{"imageOffset":2474410,"symbol":"QThreadPoolThread::run()","symbolLocation":1002,"imageIndex":65},{"imageOffset":2438563,"symbol":"QThreadPrivate::start(void*)","symbolLocation":371,"imageIndex":65},{"imageOffset":24141,"symbol":"_pthread_start","symbolLocation":115,"imageIndex":352},{"imageOffset":6231,"symbol":"thread_start","symbolLocation":15,"imageIndex":352}]},{"id":99965,"name":"Thread (pooled)","threadState":{"r13":{"value":94562294978304},"rax":{"value":260},"rflags":{"value":583},"cpu":{"value":0},"r14":{"value":105553151700544},"rsi":{"value":94562294978304},"r8":{"value":0},"cr2":{"value":0},"rdx":{"value":22016},"r10":{"value":0},"r9":{"value":160},"r15":{"value":22016},"rbx":{"value":123145524232192},"trap":{"value":133},"err":{"value":33554737},"r11":{"value":582},"rip":{"value":140703598487290},"rbp":{"value":123145524231728},"rsp":{"value":123145524231576},"r12":{"value":123145524231600},"rcx":{"value":123145524231576},"flavor":"x86_THREAD_STATE","rdi":{"value":105553151700544}},"frames":[{"imageOffset":14074,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":347},{"imageOffset":25334,"symbol":"_pthread_cond_wait","symbolLocation":988,"imageIndex":352},{"imageOffset":2497786,"symbol":"QWaitConditionPrivate::wait(QDeadlineTimer)","symbolLocation":266,"imageIndex":65},{"imageOffset":2497432,"symbol":"QWaitCondition::wait(QMutex*, QDeadlineTimer)","symbolLocation":88,"imageIndex":65},{"imageOffset":2474410,"symbol":"QThreadPoolThread::run()","symbolLocation":1002,"imageIndex":65},{"imageOffset":2438563,"symbol":"QThreadPrivate::start(void*)","symbolLocation":371,"imageIndex":65},{"imageOffset":24141,"symbol":"_pthread_start","symbolLocation":115,"imageIndex":352},{"imageOffset":6231,"symbol":"thread_start","symbolLocation":15,"imageIndex":352}]},{"id":99966,"name":"Thread (pooled)","threadState":{"r13":{"value":90164248466176},"rax":{"value":260},"rflags":{"value":583},"cpu":{"value":0},"r14":{"value":105553151700928},"rsi":{"value":90164248466176},"r8":{"value":0},"cr2":{"value":0},"rdx":{"value":20992},"r10":{"value":0},"r9":{"value":160},"r15":{"value":20992},"rbx":{"value":123145524768768},"trap":{"value":133},"err":{"value":33554737},"r11":{"value":582},"rip":{"value":140703598487290},"rbp":{"value":123145524768304},"rsp":{"value":123145524768152},"r12":{"value":123145524768176},"rcx":{"value":123145524768152},"flavor":"x86_THREAD_STATE","rdi":{"value":105553151700928}},"frames":[{"imageOffset":14074,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":347},{"imageOffset":25334,"symbol":"_pthread_cond_wait","symbolLocation":988,"imageIndex":352},{"imageOffset":2497786,"symbol":"QWaitConditionPrivate::wait(QDeadlineTimer)","symbolLocation":266,"imageIndex":65},{"imageOffset":2497432,"symbol":"QWaitCondition::wait(QMutex*, QDeadlineTimer)","symbolLocation":88,"imageIndex":65},{"imageOffset":2474410,"symbol":"QThreadPoolThread::run()","symbolLocation":1002,"imageIndex":65},{"imageOffset":2438563,"symbol":"QThreadPrivate::start(void*)","symbolLocation":371,"imageIndex":65},{"imageOffset":24141,"symbol":"_pthread_start","symbolLocation":115,"imageIndex":352},{"imageOffset":6231,"symbol":"thread_start","symbolLocation":15,"imageIndex":352}]},{"id":99967,"name":"Thread (pooled)","threadState":{"r13":{"value":94562294978304},"rax":{"value":260},"rflags":{"value":583},"cpu":{"value":0},"r14":{"value":105553151701312},"rsi":{"value":94562294978304},"r8":{"value":0},"cr2":{"value":0},"rdx":{"value":22016},"r10":{"value":0},"r9":{"value":160},"r15":{"value":22016},"rbx":{"value":123145525305344},"trap":{"value":133},"err":{"value":33554737},"r11":{"value":582},"rip":{"value":140703598487290},"rbp":{"value":123145525304880},"rsp":{"value":123145525304728},"r12":{"value":123145525304752},"rcx":{"value":123145525304728},"flavor":"x86_THREAD_STATE","rdi":{"value":105553151701312}},"frames":[{"imageOffset":14074,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":347},{"imageOffset":25334,"symbol":"_pthread_cond_wait","symbolLocation":988,"imageIndex":352},{"imageOffset":2497786,"symbol":"QWaitConditionPrivate::wait(QDeadlineTimer)","symbolLocation":266,"imageIndex":65},{"imageOffset":2497432,"symbol":"QWaitCondition::wait(QMutex*, QDeadlineTimer)","symbolLocation":88,"imageIndex":65},{"imageOffset":2474410,"symbol":"QThreadPoolThread::run()","symbolLocation":1002,"imageIndex":65},{"imageOffset":2438563,"symbol":"QThreadPrivate::start(void*)","symbolLocation":371,"imageIndex":65},{"imageOffset":24141,"symbol":"_pthread_start","symbolLocation":115,"imageIndex":352},{"imageOffset":6231,"symbol":"thread_start","symbolLocation":15,"imageIndex":352}]},{"id":99968,"name":"Thread (pooled)","threadState":{"r13":{"value":95661806606336},"rax":{"value":260},"rflags":{"value":583},"cpu":{"value":0},"r14":{"value":105553151701696},"rsi":{"value":95661806606336},"r8":{"value":0},"cr2":{"value":0},"rdx":{"value":22272},"r10":{"value":0},"r9":{"value":160},"r15":{"value":22272},"rbx":{"value":123145525841920},"trap":{"value":133},"err":{"value":33554737},"r11":{"value":582},"rip":{"value":140703598487290},"rbp":{"value":123145525841456},"rsp":{"value":123145525841304},"r12":{"value":123145525841328},"rcx":{"value":123145525841304},"flavor":"x86_THREAD_STATE","rdi":{"value":105553151701696}},"frames":[{"imageOffset":14074,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":347},{"imageOffset":25334,"symbol":"_pthread_cond_wait","symbolLocation":988,"imageIndex":352},{"imageOffset":2497786,"symbol":"QWaitConditionPrivate::wait(QDeadlineTimer)","symbolLocation":266,"imageIndex":65},{"imageOffset":2497432,"symbol":"QWaitCondition::wait(QMutex*, QDeadlineTimer)","symbolLocation":88,"imageIndex":65},{"imageOffset":2474410,"symbol":"QThreadPoolThread::run()","symbolLocation":1002,"imageIndex":65},{"imageOffset":2438563,"symbol":"QThreadPrivate::start(void*)","symbolLocation":371,"imageIndex":65},{"imageOffset":24141,"symbol":"_pthread_start","symbolLocation":115,"imageIndex":352},{"imageOffset":6231,"symbol":"thread_start","symbolLocation":15,"imageIndex":352}]},{"id":100023,"name":"QCA::KeyStoreThread","threadState":{"r13":{"value":4294967296},"rax":{"value":4},"rflags":{"value":583},"cpu":{"value":0},"r14":{"value":105553132197680},"rsi":{"value":1},"r8":{"value":1},"cr2":{"value":0},"rdx":{"value":4294967295},"r10":{"value":4294967296},"r9":{"value":0},"r15":{"value":0},"rbx":{"value":1},"trap":{"value":133},"err":{"value":33554662},"r11":{"value":582},"rip":{"value":140703598504154},"rbp":{"value":123145526377920},"rsp":{"value":123145526377848},"r12":{"value":9223372036854775807},"rcx":{"value":123145526377848},"flavor":"x86_THREAD_STATE","rdi":{"value":105553132197680}},"frames":[{"imageOffset":30938,"symbol":"poll","symbolLocation":10,"imageIndex":347},{"imageOffset":2431679,"symbol":"qt_safe_poll(pollfd*, unsigned int, QDeadlineTimer)","symbolLocation":79,"imageIndex":65},{"imageOffset":2449195,"symbol":"QEventDispatcherUNIX::processEvents(QFlags<QEventLoop::ProcessEventsFlag>)","symbolLocation":1131,"imageIndex":65},{"imageOffset":687526,"symbol":"QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>)","symbolLocation":550,"imageIndex":65},{"imageOffset":514004,"symbol":"QCA::SyncThread::run()","symbolLocation":484,"imageIndex":37},{"imageOffset":2438563,"symbol":"QThreadPrivate::start(void*)","symbolLocation":371,"imageIndex":65},{"imageOffset":24141,"symbol":"_pthread_start","symbolLocation":115,"imageIndex":352},{"imageOffset":6231,"symbol":"thread_start","symbolLocation":15,"imageIndex":352}]},{"id":100041,"name":"com.apple.CFSocket.private","threadState":{"r13":{"value":105553116393712},"rax":{"value":4},"rflags":{"value":583},"cpu":{"value":0},"r14":{"value":105553130622624},"rsi":{"value":105553130622624},"r8":{"value":0},"cr2":{"value":0},"rdx":{"value":105553130622640},"r10":{"value":0},"r9":{"value":3510741244},"r15":{"value":0},"rbx":{"value":140704686811120,"symbolLocation":0,"symbol":"__CFActiveSocketsLock"},"trap":{"value":133},"err":{"value":33554525},"r11":{"value":582},"rip":{"value":140703598512590},"rbp":{"value":123145526914992},"rsp":{"value":123145526881240},"r12":{"value":105553130622640},"rcx":{"value":123145526881240},"flavor":"x86_THREAD_STATE","rdi":{"value":32}},"frames":[{"imageOffset":39374,"symbol":"__select","symbolLocation":10,"imageIndex":347},{"imageOffset":483916,"symbol":"__CFSocketManager","symbolLocation":671,"imageIndex":348},{"imageOffset":24141,"symbol":"_pthread_start","symbolLocation":115,"imageIndex":352},{"imageOffset":6231,"symbol":"thread_start","symbolLocation":15,"imageIndex":352}]},{"id":100134,"frames":[],"threadState":{"r13":{"value":0},"rax":{"value":33554800},"rflags":{"value":512},"cpu":{"value":0},"r14":{"value":1},"rsi":{"value":4619},"r8":{"value":409604},"cr2":{"value":0},"rdx":{"value":123145519951872},"r10":{"value":0},"r9":{"value":18446744073709551615},"r15":{"value":123145520475000},"rbx":{"value":123145520476160},"trap":{"value":133},"err":{"value":33554800},"r11":{"value":582},"rip":{"value":140703598733364},"rbp":{"value":0},"rsp":{"value":123145520476160},"r12":{"value":5128198},"rcx":{"value":0},"flavor":"x86_THREAD_STATE","rdi":{"value":123145520476160}}},{"id":100198,"name":"Thread (pooled)","threadState":{"r13":{"value":1103806595584},"rax":{"value":260},"rflags":{"value":583},"cpu":{"value":0},"r14":{"value":105553153805248},"rsi":{"value":1103806595584},"r8":{"value":0},"cr2":{"value":0},"rdx":{"value":256},"r10":{"value":0},"r9":{"value":160},"r15":{"value":256},"rbx":{"value":123145522085888},"trap":{"value":133},"err":{"value":33554737},"r11":{"value":582},"rip":{"value":140703598487290},"rbp":{"value":123145522085424},"rsp":{"value":123145522085272},"r12":{"value":123145522085296},"rcx":{"value":123145522085272},"flavor":"x86_THREAD_STATE","rdi":{"value":105553153805248}},"frames":[{"imageOffset":14074,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":347},{"imageOffset":25334,"symbol":"_pthread_cond_wait","symbolLocation":988,"imageIndex":352},{"imageOffset":2497786,"symbol":"QWaitConditionPrivate::wait(QDeadlineTimer)","symbolLocation":266,"imageIndex":65},{"imageOffset":2497432,"symbol":"QWaitCondition::wait(QMutex*, QDeadlineTimer)","symbolLocation":88,"imageIndex":65},{"imageOffset":2474410,"symbol":"QThreadPoolThread::run()","symbolLocation":1002,"imageIndex":65},{"imageOffset":2438563,"symbol":"QThreadPrivate::start(void*)","symbolLocation":371,"imageIndex":65},{"imageOffset":24141,"symbol":"_pthread_start","symbolLocation":115,"imageIndex":352},{"imageOffset":6231,"symbol":"thread_start","symbolLocation":15,"imageIndex":352}]},{"id":100226,"name":"QQmlThread","threadState":{"r13":{"value":4294967296},"rax":{"value":4},"rflags":{"value":583},"cpu":{"value":0},"r14":{"value":105553125848528},"rsi":{"value":1},"r8":{"value":1},"cr2":{"value":0},"rdx":{"value":4294967295},"r10":{"value":4294967296},"r9":{"value":0},"r15":{"value":0},"rbx":{"value":1},"trap":{"value":133},"err":{"value":33554662},"r11":{"value":582},"rip":{"value":140703598504154},"rbp":{"value":123145535315440},"rsp":{"value":123145535315368},"r12":{"value":9223372036854775807},"rcx":{"value":123145535315368},"flavor":"x86_THREAD_STATE","rdi":{"value":105553125848528}},"frames":[{"imageOffset":30938,"symbol":"poll","symbolLocation":10,"imageIndex":347},{"imageOffset":2431679,"symbol":"qt_safe_poll(pollfd*, unsigned int, QDeadlineTimer)","symbolLocation":79,"imageIndex":65},{"imageOffset":2449195,"symbol":"QEventDispatcherUNIX::processEvents(QFlags<QEventLoop::ProcessEventsFlag>)","symbolLocation":1131,"imageIndex":65},{"imageOffset":687526,"symbol":"QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>)","symbolLocation":550,"imageIndex":65},{"imageOffset":1754023,"symbol":"QThread::exec()","symbolLocation":343,"imageIndex":65},{"imageOffset":2438563,"symbol":"QThreadPrivate::start(void*)","symbolLocation":371,"imageIndex":65},{"imageOffset":24141,"symbol":"_pthread_start","symbolLocation":115,"imageIndex":352},{"imageOffset":6231,"symbol":"thread_start","symbolLocation":15,"imageIndex":352}]},{"id":100227,"name":"QNetworkAccessManager thread","threadState":{"r13":{"value":123145535852064},"rax":{"value":4},"rflags":{"value":583},"cpu":{"value":0},"r14":{"value":105553125933456},"rsi":{"value":2},"r8":{"value":1},"cr2":{"value":0},"rdx":{"value":4294967295},"r10":{"value":4294967296},"r9":{"value":0},"r15":{"value":0},"rbx":{"value":2},"trap":{"value":133},"err":{"value":33554662},"r11":{"value":582},"rip":{"value":140703598504154},"rbp":{"value":123145535852016},"rsp":{"value":123145535851944},"r12":{"value":9223372036854775807},"rcx":{"value":123145535851944},"flavor":"x86_THREAD_STATE","rdi":{"value":105553125933456}},"frames":[{"imageOffset":30938,"symbol":"poll","symbolLocation":10,"imageIndex":347},{"imageOffset":2431679,"symbol":"qt_safe_poll(pollfd*, unsigned int, QDeadlineTimer)","symbolLocation":79,"imageIndex":65},{"imageOffset":2449195,"symbol":"QEventDispatcherUNIX::processEvents(QFlags<QEventLoop::ProcessEventsFlag>)","symbolLocation":1131,"imageIndex":65},{"imageOffset":687526,"symbol":"QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>)","symbolLocation":550,"imageIndex":65},{"imageOffset":1754023,"symbol":"QThread::exec()","symbolLocation":343,"imageIndex":65},{"imageOffset":2438563,"symbol":"QThreadPrivate::start(void*)","symbolLocation":371,"imageIndex":65},{"imageOffset":24141,"symbol":"_pthread_start","symbolLocation":115,"imageIndex":352},{"imageOffset":6231,"symbol":"thread_start","symbolLocation":15,"imageIndex":352}]},{"id":100228,"name":"Thread (pooled)","threadState":{"r13":{"value":4294967552},"rax":{"value":260},"rflags":{"value":583},"cpu":{"value":0},"r14":{"value":105553150115136},"rsi":{"value":4294967552},"r8":{"value":0},"cr2":{"value":0},"rdx":{"value":0},"r10":{"value":0},"r9":{"value":160},"r15":{"value":0},"rbx":{"value":123145536389120},"trap":{"value":133},"err":{"value":33554737},"r11":{"value":582},"rip":{"value":140703598487290},"rbp":{"value":123145536388656},"rsp":{"value":123145536388504},"r12":{"value":123145536388528},"rcx":{"value":123145536388504},"flavor":"x86_THREAD_STATE","rdi":{"value":105553150115136}},"frames":[{"imageOffset":14074,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":347},{"imageOffset":25334,"symbol":"_pthread_cond_wait","symbolLocation":988,"imageIndex":352},{"imageOffset":2497786,"symbol":"QWaitConditionPrivate::wait(QDeadlineTimer)","symbolLocation":266,"imageIndex":65},{"imageOffset":2497432,"symbol":"QWaitCondition::wait(QMutex*, QDeadlineTimer)","symbolLocation":88,"imageIndex":65},{"imageOffset":2474410,"symbol":"QThreadPoolThread::run()","symbolLocation":1002,"imageIndex":65},{"imageOffset":2438563,"symbol":"QThreadPrivate::start(void*)","symbolLocation":371,"imageIndex":65},{"imageOffset":24141,"symbol":"_pthread_start","symbolLocation":115,"imageIndex":352},{"imageOffset":6231,"symbol":"thread_start","symbolLocation":15,"imageIndex":352}]},{"id":100230,"name":"Thread (pooled)","threadState":{"r13":{"value":4194304},"rax":{"value":2},"rflags":{"value":583},"cpu":{"value":0},"r14":{"value":140357210680168},"rsi":{"value":0},"r8":{"value":36},"cr2":{"value":0},"rdx":{"value":0},"r10":{"value":36},"r9":{"value":105553162238648},"r15":{"value":4290772991},"rbx":{"value":140357210680224},"trap":{"value":133},"err":{"value":33554465},"r11":{"value":582},"rip":{"value":140703598478090},"rbp":{"value":123145536920704},"rsp":{"value":123145536920344},"r12":{"value":0},"rcx":{"value":123145536920344},"flavor":"x86_THREAD_STATE","rdi":{"value":105553153646096}},"frames":[{"imageOffset":4874,"symbol":"access","symbolLocation":10,"imageIndex":347},{"imageOffset":2396640,"symbol":"QFileSystemEngine::fillMetaData(QFileSystemEntry const&, QFileSystemMetaData&, QFlags<QFileSystemMetaData::MetaDataFlag>)","symbolLocation":1584,"imageIndex":65},{"imageOffset":343973,"symbol":"QFileInfo::exists() const","symbolLocation":149,"imageIndex":65},{"imageOffset":2912461,"symbol":"QConfFileSettingsPrivate::syncConfFile(QConfFile*)","symbolLocation":541,"imageIndex":65},{"imageOffset":2911839,"symbol":"QConfFileSettingsPrivate::sync()","symbolLocation":127,"imageIndex":65},{"imageOffset":2901006,"symbol":"QConfFileSettingsPrivate::QConfFileSettingsPrivate(QSettings::Format, QSettings::Scope, QString const&, QString const&)","symbolLocation":1390,"imageIndex":65},{"imageOffset":2992057,"symbol":"QSettingsPrivate::create(QSettings::Format, QSettings::Scope, QString const&, QString const&)","symbolLocation":233,"imageIndex":65},{"imageOffset":2925489,"symbol":"QSettings::QSettings(QSettings::Scope, QObject*)","symbolLocation":113,"imageIndex":65},{"imageOffset":6188795,"symbol":"std::__1::unique_ptr<QSettings, std::__1::default_delete<QSettings>> std::__1::make_unique[abi:ne200100]<QSettings, QObject*&, 0>(QObject*&)","symbolLocation":59,"imageIndex":23},{"imageOffset":6188626,"symbol":"QgsSettings::QgsSettings(QObject*)","symbolLocation":98,"imageIndex":23},{"imageOffset":6188893,"symbol":"QgsSettings::QgsSettings(QObject*)","symbolLocation":29,"imageIndex":23},{"imageOffset":30033472,"symbol":"QgsNetworkAccessManager::setupDefaultProxyAndCache(Qt::ConnectionType)","symbolLocation":2832,"imageIndex":23},{"imageOffset":30002816,"symbol":"QgsNetworkAccessManager::instance(Qt::ConnectionType)","symbolLocation":208,"imageIndex":23},{"imageOffset":30070134,"symbol":"QgsNetworkContentFetcher::fetchContent(QNetworkRequest const&, QString const&)","symbolLocation":454,"imageIndex":23},{"imageOffset":29805193,"symbol":"QgsNetworkContentFetcherTask::run()","symbolLocation":505,"imageIndex":23},{"imageOffset":19046692,"symbol":"QgsTask::start()","symbolLocation":196,"imageIndex":23},{"imageOffset":19101225,"symbol":"QgsTaskRunnableWrapper::run()","symbolLocation":25,"imageIndex":23},{"imageOffset":2473639,"symbol":"QThreadPoolThread::run()","symbolLocation":231,"imageIndex":65},{"imageOffset":2438563,"symbol":"QThreadPrivate::start(void*)","symbolLocation":371,"imageIndex":65},{"imageOffset":24141,"symbol":"_pthread_start","symbolLocation":115,"imageIndex":352},{"imageOffset":6231,"symbol":"thread_start","symbolLocation":15,"imageIndex":352}]}],
"usedImages" : [
"source" : "P",
"arch" : "x86_64",
"base" : 4435431424,
"CFBundleShortVersionString" : "4.0.0",
"CFBundleIdentifier" : "org.qgis.qgis3",
"size" : 507904,
"uuid" : "b4ac657c-b39b-3017-a936-9895008feacb",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/MacOS\/QGIS-final-4_0_0",
"name" : "QGIS-final-4_0_0",
"CFBundleVersion" : "4.0.0"
"source" : "P",
"arch" : "x86_64",
"base" : 4502409216,
"size" : 17375232,
"uuid" : "7f07a6a1-a01f-30ee-a060-b6fca3349407",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libqgis_app.4.0.0.dylib",
"name" : "libqgis_app.4.0.0.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4436512768,
"size" : 81920,
"uuid" : "b3da0e16-8b70-3edb-9bd5-9013ab26d2c8",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libQt6QuickControls2.6.dylib",
"name" : "libQt6QuickControls2.6.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4438097920,
"size" : 450560,
"uuid" : "0513182f-cbce-3939-b8a7-decf6c1f4d30",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libQt6UiTools.6.dylib",
"name" : "libQt6UiTools.6.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4436393984,
"size" : 36864,
"uuid" : "b4042821-486c-3167-aed2-40179610b7c9",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libQt6OpenGLWidgets.dylib",
"name" : "libQt6OpenGLWidgets.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4438827008,
"size" : 28971008,
"uuid" : "559a5fe9-eab9-3838-bbba-bf84e0f37fdf",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libqgis_gui.4.0.0.dylib",
"name" : "libqgis_gui.4.0.0.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4436684800,
"size" : 28672,
"uuid" : "cbd649d2-bbeb-30ed-9162-e2ff6bedfdfb",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libqgis_native.4.0.0.dylib",
"name" : "libqgis_native.4.0.0.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4535762944,
"size" : 987136,
"uuid" : "aecf5daf-ca5c-3972-b712-cfa73c872a86",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libqwt.dylib",
"name" : "libqwt.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4497735680,
"size" : 2781184,
"uuid" : "bc7df440-8e46-3a5d-a203-193c9907eadb",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libqscintilla2_qt6.15.dylib",
"name" : "libqscintilla2_qt6.15.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4436144128,
"size" : 86016,
"uuid" : "0b513c99-24e6-3017-9c9d-5f7b78738967",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libQt6QuickWidgets.dylib",
"name" : "libQt6QuickWidgets.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4553895936,
"size" : 5128192,
"uuid" : "fe6669d5-5832-3e74-a55d-e54a2f96703e",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libQt6Quick.dylib",
"name" : "libQt6Quick.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4437209088,
"size" : 94208,
"uuid" : "f844dea7-22e1-3d1b-b096-f3e748e7f90a",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libQt6QmlMeta.dylib",
"name" : "libQt6QmlMeta.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4437041152,
"size" : 49152,
"uuid" : "3c9a7d7c-a275-39c5-8ae9-25835acf4f0f",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libQt6QmlWorkerScript.6.dylib",
"name" : "libQt6QmlWorkerScript.6.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4500918272,
"size" : 626688,
"uuid" : "3bd13606-c025-395a-a574-f021f5d23108",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libQt6QmlModels.dylib",
"name" : "libQt6QmlModels.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4437409792,
"size" : 32768,
"uuid" : "360a8b76-5a98-398d-bffc-2a5deca8721d",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libQt6MultimediaWidgets.6.9.3.dylib",
"name" : "libQt6MultimediaWidgets.6.9.3.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4540710912,
"size" : 933888,
"uuid" : "9e1ac14d-592d-380d-b7ec-0eec0504c650",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libQt6Multimedia.6.dylib",
"name" : "libQt6Multimedia.6.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4437499904,
"size" : 28672,
"uuid" : "9c07fbea-98b0-3b6b-bf2b-1d0f4c2d1690",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libQt6SvgWidgets.6.dylib",
"name" : "libQt6SvgWidgets.6.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4562436096,
"size" : 8540160,
"uuid" : "7a05ba24-d8c0-3d1a-9ac9-c5792c1c08ef",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libqgis_analysis.4.0.0.dylib",
"name" : "libqgis_analysis.4.0.0.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4537372672,
"size" : 2715648,
"uuid" : "aeb1c663-79f0-367d-ace3-889bb7b6cffd",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libgsl.dylib",
"name" : "libgsl.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4437585920,
"size" : 356352,
"uuid" : "65f68cfe-92f2-34a5-97bf-93a6c2f9dfc8",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libgslcblas.dylib",
"name" : "libgslcblas.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4502028288,
"size" : 163840,
"uuid" : "cb969f69-f1ec-3b12-a6ea-df586a06b745",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libqgispython.4.0.0.dylib",
"name" : "libqgispython.4.0.0.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4542386176,
"size" : 3371008,
"uuid" : "94ae4fce-fb17-38bd-bb8b-feb5d1ccb115",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libpython3.12.dylib",
"name" : "libpython3.12.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4593438720,
"size" : 2834432,
"uuid" : "368db744-03a3-3d7c-be2e-5d063d163a20",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libqgis_3d.4.0.0.dylib",
"name" : "libqgis_3d.4.0.0.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4767891456,
"size" : 44699648,
"uuid" : "13ea7970-17ea-3ffc-8771-446e03ed6edb",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libqgis_core.4.0.0.dylib",
"name" : "libqgis_core.4.0.0.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4549849088,
"size" : 221184,
"uuid" : "abbad552-65aa-37ee-8266-ca253435f743",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libQt6Sql.dylib",
"name" : "libQt6Sql.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4436770816,
"size" : 159744,
"uuid" : "261a0f9c-28a2-3f1b-bbe9-7be461babf86",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libmeshoptimizer.dylib",
"name" : "libmeshoptimizer.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4437983232,
"size" : 36864,
"uuid" : "55f4d6ac-f6e6-38df-aed7-ee6c210622db",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libpoly2tri.dylib",
"name" : "libpoly2tri.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4540592128,
"size" : 28672,
"uuid" : "824b37f0-6e43-3dca-b52c-e9a492d88eca",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libOpenCL.1.dylib",
"name" : "libOpenCL.1.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4549341184,
"size" : 69632,
"uuid" : "88e6e4e7-7c53-3bfe-95ab-7d27242f3912",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libtasn1.6.dylib",
"name" : "libtasn1.6.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4549074944,
"size" : 126976,
"uuid" : "9e560636-6879-3ab1-bbc2-63de05f01d9c",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libQt6Xml.dylib",
"name" : "libQt6Xml.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4551557120,
"size" : 442368,
"uuid" : "5dc63f63-a2b9-3af2-a6f4-413975938a7e",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libQt6Svg.6.dylib",
"name" : "libQt6Svg.6.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4549468160,
"size" : 159744,
"uuid" : "90275629-7645-3cf7-9031-30e8720dc1c1",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libexpat.dylib",
"name" : "libexpat.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4552232960,
"size" : 1220608,
"uuid" : "dbf89b73-78e2-3936-9b3d-b1cd58744ddb",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libsqlite3.dylib",
"name" : "libsqlite3.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4549689344,
"size" : 90112,
"uuid" : "98a695a2-f159-3894-91d0-a582a152bdcb",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libzip.5.dylib",
"name" : "libzip.5.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4550230016,
"size" : 770048,
"uuid" : "d4b7cf84-df1a-3fb8-9d7f-4649675a91db",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libprotobuf-lite.dylib",
"name" : "libprotobuf-lite.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4578435072,
"size" : 458752,
"uuid" : "52688365-d461-3e0e-b605-579efce4d52f",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libQt6Positioning.dylib",
"name" : "libQt6Positioning.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4587257856,
"size" : 1929216,
"uuid" : "c9d8e46e-a633-3acc-a43e-fd313cc72a3d",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libexiv2.dylib",
"name" : "libexiv2.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4583649280,
"size" : 675840,
"uuid" : "814dad16-4c16-3152-946f-3bc6149eb518",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libqca.2.3.7.dylib",
"name" : "libqca.2.3.7.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4584964096,
"size" : 598016,
"uuid" : "43f31212-0ed8-3f88-bbfc-dbc33e46308c",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libspatialindex.dylib",
"name" : "libspatialindex.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4579192832,
"size" : 36864,
"uuid" : "2159693f-b62e-3d50-86f5-5874f8a0dce5",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libqt6keychain.0.14.3.dylib",
"name" : "libqt6keychain.0.14.3.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4582223872,
"size" : 327680,
"uuid" : "fdcbd1a3-6e02-3eff-8dac-8f6a87eeabb1",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libQt6PrintSupport.6.dylib",
"name" : "libQt6PrintSupport.6.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4615340032,
"size" : 5537792,
"uuid" : "6854aa5e-bde5-30b5-8371-b9c89627247f",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libQt6Widgets.dylib",
"name" : "libQt6Widgets.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4599611392,
"size" : 860160,
"uuid" : "3353b77f-d568-340b-b258-cf945e649a35",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libdraco.dylib",
"name" : "libdraco.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4601155584,
"size" : 6959104,
"uuid" : "465fad2d-caf2-35b2-9789-582d700a6623",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libspatialite.dylib",
"name" : "libspatialite.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4579303424,
"size" : 225280,
"uuid" : "df4f5118-9e3d-3352-8df5-dd60eaa02f3f",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libgeos_c.dylib",
"name" : "libgeos_c.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4608376832,
"size" : 3076096,
"uuid" : "be0e231d-0488-31b5-84a7-8abc64c53e0d",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libproj.25.9.7.1.dylib",
"name" : "libproj.25.9.7.1.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4553801728,
"size" : 49152,
"uuid" : "e374e845-2998-3ade-9a20-9002b0b974d9",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libfreexl.dylib",
"name" : "libfreexl.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4553596928,
"size" : 90112,
"uuid" : "0e493d9f-12e5-3732-8348-ca2b7edfc7f7",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libz.dylib",
"name" : "libz.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4585848832,
"size" : 1064960,
"uuid" : "0360c221-956b-3894-966d-19ee899433ad",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libxml2.2.13.8.dylib",
"name" : "libxml2.2.13.8.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4582821888,
"size" : 315392,
"uuid" : "cbe4a884-2260-3d0e-b540-31cdc3f8a152",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libQt6Core5Compat.6.9.3.dylib",
"name" : "libQt6Core5Compat.6.9.3.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4581011456,
"size" : 892928,
"uuid" : "9c2faecf-2882-368a-b6ce-3a08323a8e59",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libzstd.1.dylib",
"name" : "libzstd.1.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4658393088,
"size" : 8826880,
"uuid" : "3e71aac8-9561-3274-8f83-38c98ce983b9",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libSFCGAL.2.dylib",
"name" : "libSFCGAL.2.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4582010880,
"size" : 81920,
"uuid" : "89089ec6-c224-3679-bf19-827801abe04b",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libQt6SerialPort.6.9.3.dylib",
"name" : "libQt6SerialPort.6.9.3.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4592300032,
"size" : 552960,
"uuid" : "667ade92-d44b-3e7b-b61c-e2881827b6be",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libQt63DExtras.6.dylib",
"name" : "libQt63DExtras.6.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4629934080,
"size" : 1843200,
"uuid" : "df7fbb58-94e3-363e-8a06-3d0566e6fec3",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libQt63DRender.dylib",
"name" : "libQt63DRender.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4612767744,
"size" : 471040,
"uuid" : "6a5d3169-a812-344a-9f56-8a9352e66033",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libQt6OpenGL.6.dylib",
"name" : "libQt6OpenGL.6.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4591640576,
"size" : 319488,
"uuid" : "328b17de-a13c-36a5-a7f9-14272fae718b",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libQt63DInput.6.dylib",
"name" : "libQt63DInput.6.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4579684352,
"size" : 49152,
"uuid" : "cf5c8bad-8aec-3cb4-b965-570ce637f62c",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libQt63DLogic.dylib",
"name" : "libQt63DLogic.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4590399488,
"size" : 368640,
"uuid" : "e996e2a2-ba9e-3993-831e-50073e28130d",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libQt63DCore.6.dylib",
"name" : "libQt63DCore.6.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4677124096,
"size" : 6324224,
"uuid" : "5edf94ff-25c1-3547-8b9b-543e57ce93e0",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libQt6Gui.dylib",
"name" : "libQt6Gui.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4436336640,
"size" : 16384,
"uuid" : "ff6e7282-28f8-351e-8326-492308da1afa",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libQt6Concurrent.dylib",
"name" : "libQt6Concurrent.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4686057472,
"size" : 5836800,
"uuid" : "582a65f7-7f94-3f89-9ca6-bec1e6cc8bf1",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libpdalcpp.dylib",
"name" : "libpdalcpp.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4851671040,
"size" : 22368256,
"uuid" : "dd892fc3-cd54-3df7-bc47-2e501e67ed74",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libgdal.dylib",
"name" : "libgdal.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4647223296,
"size" : 4706304,
"uuid" : "3f45a4ad-e16f-3c1b-8833-3ae4e9f5e1f5",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libQt6Qml.dylib",
"name" : "libQt6Qml.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4633243648,
"size" : 1433600,
"uuid" : "0af03fb6-2fb7-390f-b5d3-35d73b9f7f18",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libQt6Network.6.dylib",
"name" : "libQt6Network.6.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4635570176,
"size" : 4907008,
"uuid" : "7ddfa30e-2d78-32bd-bfa8-2871dc1ad2f8",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libQt6Core.6.dylib",
"name" : "libQt6Core.6.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4613517312,
"size" : 618496,
"uuid" : "63e838a9-f612-3ec3-a7cf-8195f6d85505",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libQt6DBus.6.dylib",
"name" : "libQt6DBus.6.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4583288832,
"size" : 200704,
"uuid" : "f1c0d9ef-bc9a-3e7d-807c-13f11b6abf5b",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libpng16.16.53.0.dylib",
"name" : "libpng16.16.53.0.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4626182144,
"size" : 1048576,
"uuid" : "be59cf91-d50b-3ea6-a376-89e7f9b67c5d",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libharfbuzz.0.dylib",
"name" : "libharfbuzz.0.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4625154048,
"size" : 692224,
"uuid" : "89f0f940-cba4-37b2-af64-ca742dc20fca",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libfreetype.dylib",
"name" : "libfreetype.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4642672640,
"size" : 2306048,
"uuid" : "b311ff4a-ebcf-331e-ba11-0d39008e221b",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libicui18n.dylib",
"name" : "libicui18n.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4627517440,
"size" : 1630208,
"uuid" : "bee40ce3-52e6-306b-9558-79bc9937b364",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libicuuc.dylib",
"name" : "libicuuc.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4881391616,
"size" : 33112064,
"uuid" : "1222327b-5bb3-3079-a616-9ac7aa05aa31",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libicudata.dylib",
"name" : "libicudata.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4583546880,
"size" : 57344,
"uuid" : "3ac91636-7977-3dea-8f14-51a956ba6d57",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libdouble-conversion.dylib",
"name" : "libdouble-conversion.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4436971520,
"size" : 28672,
"uuid" : "bff992d7-b571-3d77-8eb4-4cecbe4cf8d7",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libb2.dylib",
"name" : "libb2.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4646371328,
"size" : 765952,
"uuid" : "fbae0af0-f3ab-3dd3-bda0-4282c61e0a4d",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libpcre2-16.0.dylib",
"name" : "libpcre2-16.0.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4587134976,
"size" : 77824,
"uuid" : "5b7bf33e-f8b4-312f-9471-b1327e28f63d",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libbz2.dylib",
"name" : "libbz2.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4591333376,
"size" : 49152,
"uuid" : "4ee8c5a2-621e-335e-bd29-bd85acd65e7e",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libbrotlidec.1.dylib",
"name" : "libbrotlidec.1.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4591128576,
"size" : 135168,
"uuid" : "f2a61865-6975-3740-8b57-cd0544382352",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libbrotlicommon.1.dylib",
"name" : "libbrotlicommon.1.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4654567424,
"size" : 1396736,
"uuid" : "ed742d1a-f99d-3790-9724-e1eec6809b00",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libQt6QuickTemplates2.dylib",
"name" : "libQt6QuickTemplates2.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4623495168,
"size" : 761856,
"uuid" : "0f160680-c506-38a1-ab9a-42d6dfd8107f",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libssl.dylib",
"name" : "libssl.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4707176448,
"size" : 4222976,
"uuid" : "bb6162ba-b6ac-3c1d-ad97-03eb0424e550",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libcrypto.dylib",
"name" : "libcrypto.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4591423488,
"size" : 106496,
"uuid" : "d901a636-b982-3c88-ad1f-9884828c2162",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libgeotiff.dylib",
"name" : "libgeotiff.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4614619136,
"size" : 376832,
"uuid" : "681def50-e1a1-384c-b7de-acb5c5db41e9",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libnlohmann_json_schema_validator.2.4.0.dylib",
"name" : "libnlohmann_json_schema_validator.2.4.0.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4657352704,
"size" : 495616,
"uuid" : "37f81a85-d322-3f68-9e72-86d53ee56e31",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libtiff.6.2.0.dylib",
"name" : "libtiff.6.2.0.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4697485312,
"size" : 638976,
"uuid" : "807ddd30-9d06-3650-9a50-1d711177eccb",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libcurl.4.8.0.dylib",
"name" : "libcurl.4.8.0.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4657950720,
"size" : 163840,
"uuid" : "860459e9-9fc7-38d1-828b-dfa024aa8be1",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/liblzma.5.8.2.dylib",
"name" : "liblzma.5.8.2.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4624560128,
"size" : 425984,
"uuid" : "5934b8ca-387e-33d8-a080-7782f581ef7c",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libqhull_r.dylib",
"name" : "libqhull_r.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4698263552,
"size" : 577536,
"uuid" : "c40fcdb9-1140-3ece-bede-ae549f2f00a0",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libLerc.dylib",
"name" : "libLerc.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4695900160,
"size" : 786432,
"uuid" : "a4b74f10-4af8-3f96-bd34-fdba17cfb225",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libjpeg.62.4.0.dylib",
"name" : "libjpeg.62.4.0.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4502331392,
"size" : 32768,
"uuid" : "ac7bb6b1-73cf-3644-8720-2cf63edae045",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libgif.dylib",
"name" : "libgif.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4702109696,
"size" : 1347584,
"uuid" : "805147c8-0709-31dd-8c32-48f3a03edd02",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libnetcdf.dylib",
"name" : "libnetcdf.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4700151808,
"size" : 585728,
"uuid" : "911ac1c8-33ac-3a2e-b134-17066427bfd7",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libwebp.7.2.0.dylib",
"name" : "libwebp.7.2.0.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4696825856,
"size" : 262144,
"uuid" : "1824c637-174f-3a66-a04b-fab4edf1095f",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libpq.dylib",
"name" : "libpq.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4593266688,
"size" : 61440,
"uuid" : "d2317295-baf4-352a-880a-46c56b10ad80",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libadbc_driver_manager.104.0.0.dylib",
"name" : "libadbc_driver_manager.104.0.0.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4615221248,
"size" : 36864,
"uuid" : "53b3dd20-670c-34fb-b269-807a362e0414",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libminizip.dylib",
"name" : "libminizip.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4625993728,
"size" : 114688,
"uuid" : "8bbf5050-147c-3f30-a984-6a2171663ce5",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/liburiparser.1.1.0.dylib",
"name" : "liburiparser.1.1.0.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4698931200,
"size" : 839680,
"uuid" : "fca5fb06-a1f3-3a41-bb21-6a67f4e323a1",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libpcre2-8.0.dylib",
"name" : "libpcre2-8.0.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4703780864,
"size" : 1167360,
"uuid" : "23bc442d-a444-3bd6-8337-3b3032319b53",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libarrow_dataset.2200.dylib",
"name" : "libarrow_dataset.2200.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4625043456,
"size" : 45056,
"uuid" : "4b448acb-836e-3603-bc10-1ca2bbf1caaf",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libjson-c.5.4.0.dylib",
"name" : "libjson-c.5.4.0.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4720615424,
"size" : 2785280,
"uuid" : "7f4db302-a4fa-346a-a332-e667a0db8fc1",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libpoppler.151.0.0.dylib",
"name" : "libpoppler.151.0.0.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4553728000,
"size" : 28672,
"uuid" : "78d806f9-c0f7-373d-b051-43962862b190",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libsharpyuv.0.dylib",
"name" : "libsharpyuv.0.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4706533376,
"size" : 364544,
"uuid" : "6037dc22-96cd-3150-a704-dac0b578892b",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libkea.dylib",
"name" : "libkea.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4713086976,
"size" : 229376,
"uuid" : "b9976745-0977-3a89-9f7d-6665ad193e2b",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libhdf5_cpp.dylib",
"name" : "libhdf5_cpp.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4713545728,
"size" : 3448832,
"uuid" : "c5649ec9-c987-3538-80b7-005ff7ebad73",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libhdf5.310.5.1.dylib",
"name" : "libhdf5.310.5.1.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4701683712,
"size" : 368640,
"uuid" : "957ed397-0cea-3afd-bcf3-7a68d85e26cf",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libopenjp2.7.dylib",
"name" : "libopenjp2.7.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4697169920,
"size" : 106496,
"uuid" : "c549d267-5547-3b8c-a349-e66903e50b16",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libkmlengine.dylib",
"name" : "libkmlengine.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4700831744,
"size" : 274432,
"uuid" : "1359536b-083e-32ef-84ce-9c2da5cd2375",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libkmldom.dylib",
"name" : "libkmldom.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4629721088,
"size" : 77824,
"uuid" : "85206f1a-8c1b-3571-9d23-27840de33353",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libkmlbase.1.dylib",
"name" : "libkmlbase.1.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4733181952,
"size" : 2383872,
"uuid" : "93f7ddc8-6967-30a3-9425-454bb00781fe",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libparquet.dylib",
"name" : "libparquet.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4717608960,
"size" : 1171456,
"uuid" : "4bd159b3-1dfa-34bb-94e9-26c14e7f619b",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libarrow_acero.dylib",
"name" : "libarrow_acero.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4737679360,
"size" : 11505664,
"uuid" : "68a25030-b3e5-30b9-9826-da7fab627c7b",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libarrow_compute.2200.dylib",
"name" : "libarrow_compute.2200.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4945104896,
"size" : 9277440,
"uuid" : "eaaf0af6-5ba9-36ed-b287-7d8b80addf23",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libarrow.2200.dylib",
"name" : "libarrow.2200.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4658171904,
"size" : 102400,
"uuid" : "78cc7b7b-26c2-35a7-a420-0f5836f83aae",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libhdf5_hl.dylib",
"name" : "libhdf5_hl.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4701433856,
"size" : 57344,
"uuid" : "9e881696-d53f-3800-8d04-977f6daea00e",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libtinyxml2.11.dylib",
"name" : "libtinyxml2.11.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4697415680,
"size" : 28672,
"uuid" : "bcc7affc-7cc5-3185-8280-0825ca4d5cad",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libsz.2.dylib",
"name" : "libsz.2.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4700000256,
"size" : 28672,
"uuid" : "02e2ff78-f5db-3eb4-9ddb-9913b710af20",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libaec.0.1.3.dylib",
"name" : "libaec.0.1.3.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4719874048,
"size" : 294912,
"uuid" : "834852ad-7abe-36c1-9a76-7b1536a0ea89",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libthrift.dylib",
"name" : "libthrift.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4726079488,
"size" : 753664,
"uuid" : "f3677fa5-67e2-3de4-9764-61254282a5f6",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libbrotlienc.dylib",
"name" : "libbrotlienc.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4724948992,
"size" : 163840,
"uuid" : "643c3e31-0e0d-3356-83ae-baaf8e218fc0",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/liblz4.1.10.0.dylib",
"name" : "liblz4.1.10.0.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4699828224,
"size" : 28672,
"uuid" : "e01cbf7f-b7b2-302a-9e24-01a98d5f9c75",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libsnappy.1.2.2.dylib",
"name" : "libsnappy.1.2.2.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4728938496,
"size" : 630784,
"uuid" : "a0cf995f-2e07-36d9-be45-3de99485c9c4",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libre2.dylib",
"name" : "libre2.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4724502528,
"size" : 348160,
"uuid" : "d61ec68e-c909-3727-b627-afe7d69bb8be",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libutf8proc.3.2.2.dylib",
"name" : "libutf8proc.3.2.2.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4760342528,
"size" : 1978368,
"uuid" : "4cbe2274-a738-3423-af73-fa1bf2fb48cc",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libgeos.dylib",
"name" : "libgeos.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4726890496,
"size" : 266240,
"uuid" : "a73cf83b-4379-3cec-b9dc-4727e73f9d4d",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libfontconfig.dylib",
"name" : "libfontconfig.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4727234560,
"size" : 147456,
"uuid" : "4730521e-e6ad-32a7-8f84-df852416b2e0",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libboost_serialization.dylib",
"name" : "libboost_serialization.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4549292032,
"size" : 8192,
"uuid" : "066344f3-ee7f-3cb7-9d9f-8fc79d733360",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libgmpxx.dylib",
"name" : "libgmpxx.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4725153792,
"size" : 438272,
"uuid" : "d1080611-284d-3aa3-b9ad-eb964b9db007",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libmpfr.dylib",
"name" : "libmpfr.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4729966592,
"size" : 425984,
"uuid" : "0185e13a-d1ba-3052-91ba-5bc7ad663dfe",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libgmp.dylib",
"name" : "libgmp.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4701548544,
"size" : 49152,
"uuid" : "edb0b72a-0270-3a3f-a2e4-11a4b9e864db",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libboost_thread.dylib",
"name" : "libboost_thread.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4699897856,
"size" : 8192,
"uuid" : "2a2dc9d0-d335-322f-b29e-fcf616d2ad25",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libboost_atomic.1.90.0.dylib",
"name" : "libboost_atomic.1.90.0.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4658335744,
"size" : 16384,
"uuid" : "fc0dcdc8-3072-3089-8a54-461c5a73d3f9",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libboost_chrono.1.90.0.dylib",
"name" : "libboost_chrono.1.90.0.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4437164032,
"size" : 8192,
"uuid" : "8c0fa030-c162-326d-a8e3-9c972ff609c8",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libboost_date_time.dylib",
"name" : "libboost_date_time.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4707024896,
"size" : 49152,
"uuid" : "f1053081-e18a-3049-b0f1-fe84c12a6d0d",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libboost_container.dylib",
"name" : "libboost_container.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4727656448,
"size" : 114688,
"uuid" : "a2b94785-9706-36e9-9b74-5808505f97f7",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libintl.dylib",
"name" : "libintl.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4728508416,
"CFBundleShortVersionString" : "3.0",
"CFBundleIdentifier" : "com.apple.security.csparser",
"size" : 94208,
"uuid" : "804fc5d6-3660-3422-b95a-5ab53b1928ea",
"path" : "\/System\/Library\/Frameworks\/Security.framework\/Versions\/A\/PlugIns\/csparser.bundle\/Contents\/MacOS\/csparser",
"name" : "csparser",
"CFBundleVersion" : "61901.80.25"
"source" : "P",
"arch" : "x86_64",
"base" : 4757516288,
"size" : 753664,
"uuid" : "9e96e627-faf1-3d48-aebd-c335d5198c9c",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/platforms\/libqcocoa.dylib",
"name" : "libqcocoa.dylib"
"source" : "P",
"arch" : "x86_64h",
"base" : 4732198912,
"size" : 53248,
"uuid" : "0a35bc69-660d-3bc0-8ab4-3fa8d922eecb",
"path" : "\/usr\/lib\/libobjc-trampolines.dylib",
"name" : "libobjc-trampolines.dylib"
"source" : "P",
"arch" : "x86_64h",
"base" : 4765483008,
"CFBundleShortVersionString" : "7.1.6",
"CFBundleIdentifier" : "com.apple.AMDRadeonX6000GLDriver",
"size" : 1368064,
"uuid" : "e99a64d9-86ab-3741-85a6-89850aaaabfb",
"path" : "\/System\/Library\/Extensions\/AMDRadeonX6000GLDriver.bundle\/Contents\/MacOS\/AMDRadeonX6000GLDriver",
"name" : "AMDRadeonX6000GLDriver",
"CFBundleVersion" : "7.0.1"
"source" : "P",
"arch" : "x86_64",
"base" : 4732563456,
"size" : 172032,
"uuid" : "b40595e4-0d60-34bb-bde4-e12eca88f7fa",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/styles\/libqmacstyle.dylib",
"name" : "libqmacstyle.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4756729856,
"size" : 49152,
"uuid" : "ac15a16a-405b-3f94-bb48-6be66ec7eb7e",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/iconengines\/libqsvgicon.dylib",
"name" : "libqsvgicon.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 5184483328,
"size" : 667648,
"uuid" : "46857134-9323-30ce-ab41-70ec8efb263e",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/qgis\/libplugin_geometrychecker.so",
"name" : "libplugin_geometrychecker.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5185888256,
"size" : 167936,
"uuid" : "a60c5b3f-91cf-3de1-b990-5644030d51ff",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/qgis\/libplugin_offlineediting.so",
"name" : "libplugin_offlineediting.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5188235264,
"size" : 430080,
"uuid" : "1b374ce8-c2e6-3bd8-8f47-2de58abba98d",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/qgis\/libplugin_topology.so",
"name" : "libplugin_topology.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5186424832,
"size" : 745472,
"uuid" : "45d84c66-3e34-3447-b321-c8ca1eeddc2b",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/qgis\/libprovider_arcgisfeatureserver.so",
"name" : "libprovider_arcgisfeatureserver.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5191139328,
"size" : 442368,
"uuid" : "af18e065-efc6-30b0-bacd-7700632bbe58",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/qgis\/libprovider_arcgismapserver.so",
"name" : "libprovider_arcgismapserver.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5189120000,
"size" : 569344,
"uuid" : "459ad96f-efd3-3a91-aa27-ef3d52cb06ba",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/qgis\/libprovider_delimitedtext.so",
"name" : "libprovider_delimitedtext.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5190230016,
"size" : 327680,
"uuid" : "43e8bbc9-d77c-3ff6-bc80-a2a13dba6518",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/qgis\/libprovider_gpx.so",
"name" : "libprovider_gpx.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5202370560,
"size" : 2162688,
"uuid" : "a19df391-9347-3547-b4be-87e6a5261ba1",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/qgis\/libprovider_mdal.so",
"name" : "libprovider_mdal.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5197107200,
"size" : 1220608,
"uuid" : "61a2b206-80ab-32ae-aa03-5636d25f509b",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/qgis\/libprovider_mssql.so",
"name" : "libprovider_mssql.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5192134656,
"size" : 1396736,
"uuid" : "08615275-417b-3c32-af1d-e391eef36e03",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/qgis\/libprovider_oracle.so",
"name" : "libprovider_oracle.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5195902976,
"size" : 221184,
"uuid" : "cc6db03b-1021-33ba-ac52-2382007c6943",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/qgis\/libprovider_pdal.so",
"name" : "libprovider_pdal.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5216256000,
"size" : 2224128,
"uuid" : "40145a27-aa44-33e9-aa46-18066ef07f4e",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/qgis\/libprovider_postgres.so",
"name" : "libprovider_postgres.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5199585280,
"size" : 1208320,
"uuid" : "be124590-22c9-35d1-9017-4e7776501351",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/qgis\/libprovider_postgresraster.so",
"name" : "libprovider_postgresraster.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5212270592,
"size" : 1089536,
"uuid" : "7a354891-6250-3ba4-ae11-788c85a6c0fb",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/qgis\/libprovider_spatialite.so",
"name" : "libprovider_spatialite.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5209747456,
"size" : 524288,
"uuid" : "2954c809-f389-3c77-b28b-f723337b5f1b",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/qgis\/libprovider_virtuallayer.so",
"name" : "libprovider_virtuallayer.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5196394496,
"size" : 163840,
"uuid" : "d60607fc-a891-3a4b-a361-3aaca73b093c",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/qgis\/libprovider_virtualraster.so",
"name" : "libprovider_virtualraster.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5207457792,
"size" : 659456,
"uuid" : "98737d96-f479-3578-867e-a6b6d4b41abe",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/qgis\/libprovider_wcs.so",
"name" : "libprovider_wcs.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5229580288,
"size" : 2015232,
"uuid" : "f0b430c1-aaa9-34ae-8311-34cc66e96109",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/qgis\/libprovider_wfs.so",
"name" : "libprovider_wfs.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5234036736,
"size" : 1851392,
"uuid" : "377b1b76-eb7e-3d3d-abba-d6361ee2e0da",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/qgis\/libprovider_wms.so",
"name" : "libprovider_wms.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5190930432,
"size" : 61440,
"uuid" : "74a4c322-fee7-3796-bb75-738f2440fa1f",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libpdal_plugin_reader_draco.19.dylib",
"name" : "libpdal_plugin_reader_draco.19.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 5194854400,
"size" : 528384,
"uuid" : "b615f701-4a98-38c0-9c39-2cca40e9b97f",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libpdal_plugin_reader_e57.19.dylib",
"name" : "libpdal_plugin_reader_e57.19.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 5237878784,
"size" : 2125824,
"uuid" : "c89cd56e-365a-3773-9bc1-ed2823432507",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libxerces-c.dylib",
"name" : "libxerces-c.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 5195677696,
"size" : 57344,
"uuid" : "df3ca7f1-6c69-3ad3-b64f-4bd36c0a2f29",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libpdal_plugin_reader_pgpointcloud.dylib",
"name" : "libpdal_plugin_reader_pgpointcloud.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 5196779520,
"size" : 151552,
"uuid" : "638e7869-8aeb-356f-bb10-d8b299736f20",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libpdal_plugin_writer_draco.19.dylib",
"name" : "libpdal_plugin_writer_draco.19.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 5208858624,
"size" : 540672,
"uuid" : "25b47128-90f2-328a-aa84-fdd6d99b6e7d",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libpdal_plugin_writer_e57.19.dylib",
"name" : "libpdal_plugin_writer_e57.19.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 5202104320,
"size" : 73728,
"uuid" : "13086f92-26b0-344f-8791-4f0cb86780d6",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libpdal_plugin_writer_pgpointcloud.19.dylib",
"name" : "libpdal_plugin_writer_pgpointcloud.19.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 5567500288,
"size" : 172032,
"uuid" : "cc42b9ec-9507-3632-9dd7-0f068ffdc088",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/crypto\/libqca-gnupg.dylib",
"name" : "libqca-gnupg.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 5186211840,
"size" : 24576,
"uuid" : "3a60869c-d95c-3b50-8914-00d66e6e5696",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/crypto\/libqca-logger.dylib",
"name" : "libqca-logger.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 5228769280,
"size" : 196608,
"uuid" : "e5d8b764-b25b-353c-a5df-27a02b8b1b0d",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/crypto\/libqca-ossl.dylib",
"name" : "libqca-ossl.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 5568749568,
"size" : 184320,
"uuid" : "041f70ff-e8e8-3588-ae36-700ddd8a247a",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/qgis\/libauthmethod_apiheader.so",
"name" : "libauthmethod_apiheader.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5567848448,
"size" : 200704,
"uuid" : "7d4cb1ab-dd69-3853-bb14-f9a1a76e99dd",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/qgis\/libauthmethod_awss3.so",
"name" : "libauthmethod_awss3.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5570170880,
"size" : 208896,
"uuid" : "3c34a1cb-434e-30ce-b27a-2f4e3df6d921",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/qgis\/libauthmethod_basic.so",
"name" : "libauthmethod_basic.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5568319488,
"size" : 172032,
"uuid" : "13e91afd-2cda-3e25-85ce-ece389cd9a4a",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/qgis\/libauthmethod_esritoken.so",
"name" : "libauthmethod_esritoken.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5570633728,
"size" : 192512,
"uuid" : "28b53e46-2a61-3c31-9bd9-6a8079d6a082",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/qgis\/libauthmethod_identcert.so",
"name" : "libauthmethod_identcert.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5571080192,
"size" : 184320,
"uuid" : "ee0f2457-4d45-37df-a66e-14cdb08d6790",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/qgis\/libauthmethod_maptilerhmacsha256.so",
"name" : "libauthmethod_maptilerhmacsha256.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5575217152,
"size" : 872448,
"uuid" : "ab2bafa9-a575-335d-ad5b-247ceec81cc9",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/qgis\/libauthmethod_oauth2.so",
"name" : "libauthmethod_oauth2.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5569171456,
"size" : 221184,
"uuid" : "a1377d40-51b7-3a7f-bb82-2bc4eb92556e",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/qgis\/libauthmethod_pkcs12.so",
"name" : "libauthmethod_pkcs12.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5569679360,
"size" : 217088,
"uuid" : "d4277b33-d0a7-319d-a0c5-93c4d2a29104",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/qgis\/libauthmethod_pkipaths.so",
"name" : "libauthmethod_pkipaths.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5571518464,
"size" : 364544,
"uuid" : "9fda9338-4ade-303e-87ce-51593df6d7e0",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/qgis\/libauthmethod_planetary_computer.so",
"name" : "libauthmethod_planetary_computer.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5216038912,
"size" : 65536,
"uuid" : "0c5dfb18-7b16-3baa-ace2-e76fbfe8b50d",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/sqldrivers\/libqsqlite.dylib",
"name" : "libqsqlite.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 5229199360,
"size" : 192512,
"uuid" : "4628053c-73b5-335f-bdd0-1a03518b6422",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/tls\/libqopensslbackend.dylib",
"name" : "libqopensslbackend.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 5572481024,
"size" : 69632,
"uuid" : "c4045e7e-d6d7-3449-b293-db308649961b",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/tls\/libqcertonlybackend.dylib",
"name" : "libqcertonlybackend.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 5191065600,
"size" : 24576,
"uuid" : "be32e0ac-556c-35f6-8ae8-0812d9c39c5e",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/imageformats\/libqsvg.dylib",
"name" : "libqsvg.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 5195808768,
"size" : 32768,
"uuid" : "a4d6249c-ecfc-3f13-abed-59ab2f6e4ab1",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/imageformats\/libqgif.dylib",
"name" : "libqgif.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 5202272256,
"size" : 20480,
"uuid" : "29a9284b-b61d-388f-a424-fa7c736ddf85",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/imageformats\/libqwbmp.dylib",
"name" : "libqwbmp.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 5212164096,
"size" : 28672,
"uuid" : "12a2c575-7ce5-3335-b09f-c36779218ada",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/imageformats\/libqwebp.dylib",
"name" : "libqwebp.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4765425664,
"size" : 16384,
"uuid" : "0c1da85e-076d-3ed1-af4f-651d910023d3",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libwebpdemux.2.0.17.dylib",
"name" : "libwebpdemux.2.0.17.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 5572984832,
"size" : 40960,
"uuid" : "75ee4a9c-0df3-311b-b2b9-516afea936b8",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libwebpmux.dylib",
"name" : "libwebpmux.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 5216178176,
"size" : 32768,
"uuid" : "88d8032d-bcde-3e50-adcb-7816ff539ab5",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/imageformats\/libqico.dylib",
"name" : "libqico.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 5573066752,
"size" : 28672,
"uuid" : "5b2db613-81a4-3898-93bf-26b936349597",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/imageformats\/libqmacheif.dylib",
"name" : "libqmacheif.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 5572780032,
"size" : 40960,
"uuid" : "e6df73db-e956-3418-9c2a-bc5243ca8510",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/imageformats\/libqjpeg.dylib",
"name" : "libqjpeg.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 5572878336,
"size" : 36864,
"uuid" : "7f6952d3-ea0a-3ae5-839e-1af989461861",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/imageformats\/libqtiff.dylib",
"name" : "libqtiff.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 5573484544,
"size" : 32768,
"uuid" : "4906a718-51b8-36a3-af19-e9e408122267",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/imageformats\/libqjp2.dylib",
"name" : "libqjp2.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 5573558272,
"size" : 319488,
"uuid" : "c19348be-5607-385c-a421-d0167b49c8eb",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libjasper.7.dylib",
"name" : "libjasper.7.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 5573967872,
"size" : 36864,
"uuid" : "04298c04-0829-3c35-a84e-7568f7a20f6e",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/imageformats\/libqicns.dylib",
"name" : "libqicns.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 5574189056,
"size" : 20480,
"uuid" : "b53731b9-6250-3222-b515-bed2178e3da2",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/PlugIns\/imageformats\/libqtga.dylib",
"name" : "libqtga.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 5573136384,
"size" : 49152,
"uuid" : "f337dff4-3ec1-35f0-8ba8-5a85f28ba32e",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/lib-dynload\/math.cpython-312-darwin.so",
"name" : "math.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5596315648,
"size" : 1736704,
"uuid" : "4698fdc3-c677-3f83-9882-14b85df9029d",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/PyQt6\/QtCore.abi3.so",
"name" : "QtCore.abi3.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5574627328,
"size" : 90112,
"uuid" : "aaef7cdf-0b41-3540-9147-c4b8d8bdf3a3",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/PyQt6\/sip.cpython-312-darwin.so",
"name" : "sip.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5720219648,
"size" : 37683200,
"uuid" : "d42ac355-bf47-31c8-ae32-de33814b8350",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/qgis\/_gui.so",
"name" : "_gui.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5574250496,
"size" : 81920,
"uuid" : "e22ea863-69cf-3a7e-9f01-ba9f932fd442",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/PyQt6\/QtXml.abi3.so",
"name" : "QtXml.abi3.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5594304512,
"size" : 540672,
"uuid" : "981c0265-f402-35e1-b247-890272221791",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/PyQt6\/QtNetwork.abi3.so",
"name" : "QtNetwork.abi3.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5607149568,
"size" : 1605632,
"uuid" : "3f8d7dc8-a2e1-32d5-bb85-e4afa29d558a",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/PyQt6\/QtGui.abi3.so",
"name" : "QtGui.abi3.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5600169984,
"size" : 2736128,
"uuid" : "bc51fdf4-e1ea-3171-94a8-bcf0da3c6f43",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/PyQt6\/QtWidgets.abi3.so",
"name" : "QtWidgets.abi3.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5579522048,
"size" : 196608,
"uuid" : "060a730d-d780-3659-a122-89af1ee98878",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/PyQt6\/QtSql.abi3.so",
"name" : "QtSql.abi3.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5574811648,
"size" : 135168,
"uuid" : "3a5f9bd8-cb8f-3782-86eb-0eed882a7164",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/PyQt6\/QtPrintSupport.abi3.so",
"name" : "QtPrintSupport.abi3.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5592285184,
"size" : 143360,
"uuid" : "ba392c78-7b56-31d1-ad3b-d7c84f316570",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/PyQt6\/QtPositioning.abi3.so",
"name" : "QtPositioning.abi3.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5595570176,
"size" : 282624,
"uuid" : "68de7e0e-4482-34f8-af55-cc207e73aebe",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/PyQt6\/QtMultimedia.abi3.so",
"name" : "QtMultimedia.abi3.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5574451200,
"size" : 57344,
"uuid" : "00f755a0-eb99-3986-8b42-22473ef1cd5c",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/PyQt6\/QtSerialPort.abi3.so",
"name" : "QtSerialPort.abi3.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5610598400,
"size" : 41988096,
"uuid" : "e6e52339-c6d3-39f1-b8ef-54699eff9e69",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/qgis\/_core.so",
"name" : "_core.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5694017536,
"size" : 794624,
"uuid" : "019ac44e-fe32-37da-9d8e-bc05f55e7589",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/PyQt6\/Qsci.abi3.so",
"name" : "Qsci.abi3.so"
"source" : "P",
"arch" : "x86_64",
"base" : 4727955456,
"size" : 4096,
"uuid" : "6c84c184-fab2-34b5-a94c-19ac9c362277",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/lib-dynload\/_opcode.cpython-312-darwin.so",
"name" : "_opcode.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5709697024,
"size" : 5021696,
"uuid" : "d0c364ea-9334-30ce-b03f-f592c0da5f4e",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/numpy\/core\/_multiarray_umath.cpython-312-darwin.so",
"name" : "_multiarray_umath.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 4727816192,
"size" : 65536,
"uuid" : "8b73b75c-5eec-3d51-8a5b-fb7dd4cb141d",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/lib-dynload\/_datetime.cpython-312-darwin.so",
"name" : "_datetime.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 4730466304,
"size" : 24576,
"uuid" : "1c9cb245-6f85-3791-8590-6983edda6ad0",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/lib-dynload\/_struct.cpython-312-darwin.so",
"name" : "_struct.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5577179136,
"size" : 90112,
"uuid" : "57ff2784-bb32-3329-b8c8-56c7b58db805",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/lib-dynload\/_pickle.cpython-312-darwin.so",
"name" : "_pickle.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 4728000512,
"size" : 4096,
"uuid" : "94ace964-bfe9-3013-8f47-91cf43433f9b",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/lib-dynload\/_contextvars.cpython-312-darwin.so",
"name" : "_contextvars.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5577457664,
"size" : 73728,
"uuid" : "4aaff1a0-bba3-392a-b8ac-b042ca739635",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/numpy\/core\/_multiarray_tests.cpython-312-darwin.so",
"name" : "_multiarray_tests.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5580226560,
"size" : 77824,
"uuid" : "2e2baf4b-50ef-3096-89d8-83179b03cdf0",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/lib-dynload\/_ctypes.cpython-312-darwin.so",
"name" : "_ctypes.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 4731342848,
"size" : 28672,
"uuid" : "e13f0e60-2b23-3f5d-a45b-4f12e89d871d",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libffi.8.dylib",
"name" : "libffi.8.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 4731121664,
"size" : 139264,
"uuid" : "30b4c21a-dc7a-3494-bf7a-442816921f6d",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/numpy\/linalg\/_umath_linalg.cpython-312-darwin.so",
"name" : "_umath_linalg.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5577592832,
"size" : 73728,
"uuid" : "080d2ee6-2f58-3427-a4c4-0f21ed005daf",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/numpy\/fft\/_pocketfft_internal.cpython-312-darwin.so",
"name" : "_pocketfft_internal.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5707857920,
"size" : 454656,
"uuid" : "c02194a4-01ae-3cfe-b723-ea433fbcdd15",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/numpy\/random\/mtrand.cpython-312-darwin.so",
"name" : "mtrand.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 4731412480,
"size" : 32768,
"uuid" : "d2806c88-0c26-3f86-95ba-f5996545e7b8",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/lib-dynload\/zlib.cpython-312-darwin.so",
"name" : "zlib.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5588811776,
"size" : 135168,
"uuid" : "3a20363f-26d4-3b65-8c37-16490c275168",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/numpy\/random\/bit_generator.cpython-312-darwin.so",
"name" : "bit_generator.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5606252544,
"size" : 159744,
"uuid" : "eebcc736-e9af-3b56-8529-94c9bff7b792",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/numpy\/random\/_common.cpython-312-darwin.so",
"name" : "_common.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5573242880,
"size" : 20480,
"uuid" : "fd672db8-c3dc-3adb-a3d8-b716058761ea",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/lib-dynload\/binascii.cpython-312-darwin.so",
"name" : "binascii.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5577883648,
"size" : 28672,
"uuid" : "97abba04-e4ba-3339-aeb9-3844cc30783c",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/lib-dynload\/_hashlib.cpython-312-darwin.so",
"name" : "_hashlib.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5575131136,
"size" : 32768,
"uuid" : "f4b7ef2d-1bcd-368e-87bb-5dd4d1edc262",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/lib-dynload\/_blake2.cpython-312-darwin.so",
"name" : "_blake2.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5209694208,
"size" : 12288,
"uuid" : "46db0c6f-61c6-3b47-a13f-1786d99840ce",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/lib-dynload\/_bisect.cpython-312-darwin.so",
"name" : "_bisect.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 4730548224,
"size" : 8192,
"uuid" : "b58986e5-529f-38d7-bb5c-af78a501868e",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/lib-dynload\/_random.cpython-312-darwin.so",
"name" : "_random.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5578833920,
"size" : 45056,
"uuid" : "cf6579f3-5b5f-3035-a608-f2bee66f9111",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/lib-dynload\/_sha2.cpython-312-darwin.so",
"name" : "_sha2.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5606825984,
"size" : 241664,
"uuid" : "ab188de3-c7d9-31a0-9c4f-45a86c359505",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/numpy\/random\/_bounded_integers.cpython-312-darwin.so",
"name" : "_bounded_integers.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5579112448,
"size" : 61440,
"uuid" : "c350585d-5298-3a7e-8492-8baec25575b5",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/numpy\/random\/_mt19937.cpython-312-darwin.so",
"name" : "_mt19937.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5579964416,
"size" : 53248,
"uuid" : "fa6b6389-f780-3e61-8f69-6786b0ad07f4",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/numpy\/random\/_philox.cpython-312-darwin.so",
"name" : "_philox.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5580390400,
"size" : 65536,
"uuid" : "7d0d9681-19ba-3c3b-946e-996862aa4026",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/numpy\/random\/_pcg64.cpython-312-darwin.so",
"name" : "_pcg64.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5588533248,
"size" : 36864,
"uuid" : "7b05be7f-34eb-3319-b026-5559674376e7",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/numpy\/random\/_sfc64.cpython-312-darwin.so",
"name" : "_sfc64.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5718503424,
"size" : 573440,
"uuid" : "e29b6324-f1bf-3e5b-b570-8a657cc4739f",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/numpy\/random\/_generator.cpython-312-darwin.so",
"name" : "_generator.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5606473728,
"size" : 122880,
"uuid" : "1807537d-6258-3f8c-acc0-bb6981bf7a7b",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/shapely\/lib.cpython-312-darwin.so",
"name" : "lib.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5719863296,
"size" : 217088,
"uuid" : "6ddb458e-8b4d-3f76-9001-841feddc5f8d",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/shapely\/_geometry_helpers.cpython-312-darwin.so",
"name" : "_geometry_helpers.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5591465984,
"size" : 32768,
"uuid" : "afb1d75f-3a0b-339d-9b55-7e8b9dafcdb6",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/shapely\/_geos.cpython-312-darwin.so",
"name" : "_geos.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5591744512,
"size" : 36864,
"uuid" : "fc904bd4-dea9-376d-8c8e-c7e23e932e0d",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/lib-dynload\/array.cpython-312-darwin.so",
"name" : "array.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5588611072,
"size" : 24576,
"uuid" : "0bd91055-81d6-30bf-82ff-94b91ca410ed",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/lib-dynload\/_json.cpython-312-darwin.so",
"name" : "_json.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5577973760,
"size" : 12288,
"uuid" : "7b1708ac-bc7e-3207-bc27-97290d42a50e",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/lib-dynload\/_bz2.cpython-312-darwin.so",
"name" : "_bz2.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5589024768,
"size" : 24576,
"uuid" : "ad03f0e2-2086-37ca-ab90-966d06d18a24",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/lib-dynload\/_lzma.cpython-312-darwin.so",
"name" : "_lzma.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5592637440,
"size" : 24576,
"uuid" : "7a90fca0-1b20-3a76-a27a-d733bf61e91f",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pandas\/_libs\/pandas_parser.cpython-312-darwin.so",
"name" : "pandas_parser.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5592989696,
"size" : 24576,
"uuid" : "6d3795cb-e65c-3a7d-9d14-b108bcd88820",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pandas\/_libs\/pandas_datetime.cpython-312-darwin.so",
"name" : "pandas_datetime.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5784039424,
"size" : 839680,
"uuid" : "bd8d62d7-bd40-328c-9460-c74168fed639",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pandas\/_libs\/interval.cpython-312-darwin.so",
"name" : "interval.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5789065216,
"size" : 1622016,
"uuid" : "a687beb5-4111-3e52-8540-d71b4788924d",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pandas\/_libs\/hashtable.cpython-312-darwin.so",
"name" : "hashtable.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5703663616,
"size" : 131072,
"uuid" : "c77a3ce8-f508-382c-81ee-108d25f5b372",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pandas\/_libs\/missing.cpython-312-darwin.so",
"name" : "missing.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5707153408,
"size" : 118784,
"uuid" : "911c7dc8-50cb-3536-9e13-eccfd98e0f8d",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pandas\/_libs\/tslibs\/dtypes.cpython-312-darwin.so",
"name" : "dtypes.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5593432064,
"size" : 53248,
"uuid" : "3e85a777-6391-39d5-b017-1be0884c2c52",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pandas\/_libs\/tslibs\/ccalendar.cpython-312-darwin.so",
"name" : "ccalendar.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5709488128,
"size" : 94208,
"uuid" : "b1e8f779-19e2-303d-bbab-aa420e7ff0fd",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pandas\/_libs\/tslibs\/np_datetime.cpython-312-darwin.so",
"name" : "np_datetime.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5715599360,
"size" : 184320,
"uuid" : "f3771e88-07d8-352c-acc1-93e441f97c2f",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pandas\/_libs\/tslibs\/conversion.cpython-312-darwin.so",
"name" : "conversion.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5701926912,
"size" : 32768,
"uuid" : "e87e7730-e69f-3509-b48f-229a002040b6",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pandas\/_libs\/tslibs\/base.cpython-312-darwin.so",
"name" : "base.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5791121408,
"size" : 749568,
"uuid" : "fbe781a1-9f01-33aa-8628-a48142560af3",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pandas\/_libs\/tslibs\/offsets.cpython-312-darwin.so",
"name" : "offsets.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5787951104,
"size" : 425984,
"uuid" : "7dc49fcf-59f2-3efc-a75e-54b49948c0b3",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pandas\/_libs\/tslibs\/timestamps.cpython-312-darwin.so",
"name" : "timestamps.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5719175168,
"size" : 139264,
"uuid" : "c9cdf597-38f1-3307-ac2f-c7ae675c9fbc",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pandas\/_libs\/tslibs\/nattype.cpython-312-darwin.so",
"name" : "nattype.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5787394048,
"size" : 405504,
"uuid" : "5901643a-9e46-3b37-88f8-977c009ca21a",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pandas\/_libs\/tslibs\/timedeltas.cpython-312-darwin.so",
"name" : "timedeltas.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5783449600,
"size" : 180224,
"uuid" : "616cc984-b56c-3189-946e-b57768418e99",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pandas\/_libs\/tslibs\/timezones.cpython-312-darwin.so",
"name" : "timezones.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5593055232,
"size" : 24576,
"uuid" : "5272dd8e-91c3-3751-99e4-dcf57340d635",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/lib-dynload\/_zoneinfo.cpython-312-darwin.so",
"name" : "_zoneinfo.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5788647424,
"size" : 225280,
"uuid" : "d178f8c9-5ad9-36f0-8f4a-3041ddbf3630",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pandas\/_libs\/tslibs\/fields.cpython-312-darwin.so",
"name" : "fields.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5578919936,
"size" : 12288,
"uuid" : "fcab796d-afab-3340-8038-a732cb72c577",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/lib-dynload\/fcntl.cpython-312-darwin.so",
"name" : "fcntl.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5591556096,
"size" : 12288,
"uuid" : "b920c2cb-27b1-3a7d-b322-5c277f263dfe",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/lib-dynload\/_posixsubprocess.cpython-312-darwin.so",
"name" : "_posixsubprocess.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5693956096,
"size" : 20480,
"uuid" : "687c1fc4-3355-3a3c-a0e0-32de3f8522c8",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/lib-dynload\/select.cpython-312-darwin.so",
"name" : "select.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5786001408,
"size" : 204800,
"uuid" : "212070a9-8558-3ab6-815b-5bd830976637",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pandas\/_libs\/tslibs\/tzconversion.cpython-312-darwin.so",
"name" : "tzconversion.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5703385088,
"size" : 49152,
"uuid" : "4b6bb29c-699b-31af-8e70-fdcd092d1301",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pandas\/_libs\/properties.cpython-312-darwin.so",
"name" : "properties.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5793419264,
"size" : 290816,
"uuid" : "10f1909e-904c-3787-9d65-43c7a8f0f70b",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pandas\/_libs\/tslibs\/parsing.cpython-312-darwin.so",
"name" : "parsing.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5795090432,
"size" : 270336,
"uuid" : "0c66e329-0bd6-3c88-be1b-cc305dd5887e",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/lib-dynload\/_decimal.cpython-312-darwin.so",
"name" : "_decimal.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5795663872,
"size" : 245760,
"uuid" : "9af8b2de-8dd8-3868-bcd7-726fa6f5a7e6",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pandas\/_libs\/tslibs\/strptime.cpython-312-darwin.so",
"name" : "strptime.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5797720064,
"size" : 335872,
"uuid" : "d04d66fb-371c-3e86-bd5e-eed400e398a5",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pandas\/_libs\/tslibs\/period.cpython-312-darwin.so",
"name" : "period.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5794385920,
"size" : 151552,
"uuid" : "07bf7bb1-f40b-3b81-9c0a-dec95f689b90",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pandas\/_libs\/tslibs\/vectorized.cpython-312-darwin.so",
"name" : "vectorized.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5703872512,
"size" : 32768,
"uuid" : "51350661-c6c2-3534-bff8-d9c7227766b7",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pandas\/_libs\/ops_dispatch.cpython-312-darwin.so",
"name" : "ops_dispatch.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5801697280,
"size" : 1564672,
"uuid" : "a623d911-f11e-35ee-90f8-e671dacdf504",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pandas\/_libs\/algos.cpython-312-darwin.so",
"name" : "algos.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5800685568,
"size" : 581632,
"uuid" : "ad029bdb-f0c5-39d0-a5a4-ed554f0b19ec",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pandas\/_libs\/lib.cpython-312-darwin.so",
"source" : "P",
"arch" : "x86_64",
"base" : 5805887488,
"size" : 1114112,
"uuid" : "3acc9282-67aa-384d-a1b6-55412bc5dfe1",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/lib-dynload\/unicodedata.cpython-312-darwin.so",
"name" : "unicodedata.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5796237312,
"size" : 163840,
"uuid" : "1f8bee9a-8626-351c-a84d-0c6b2618dc98",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pandas\/_libs\/ops.cpython-312-darwin.so",
"name" : "ops.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5796941824,
"size" : 126976,
"uuid" : "117d54e1-f59c-3377-9e09-4d1555440120",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pandas\/_libs\/hashing.cpython-312-darwin.so",
"name" : "hashing.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5704089600,
"size" : 73728,
"uuid" : "f14bc99c-dc98-3360-9ff6-ea64e2e290cf",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pandas\/_libs\/arrays.cpython-312-darwin.so",
"name" : "arrays.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5705416704,
"size" : 24576,
"uuid" : "dc6c304a-ff13-3ed6-9966-a865a3fea6dc",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/lib-dynload\/_csv.cpython-312-darwin.so",
"name" : "_csv.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5805555712,
"size" : 221184,
"uuid" : "a504465b-610b-3d01-9258-b12c83db555c",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pandas\/_libs\/tslib.cpython-312-darwin.so",
"name" : "tslib.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5809975296,
"size" : 729088,
"uuid" : "bcd0b4a3-14f2-3227-9e4a-4c53cec0d5f0",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pandas\/_libs\/sparse.cpython-312-darwin.so",
"name" : "sparse.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5809143808,
"size" : 262144,
"uuid" : "b2e6a767-d297-3026-a6bb-2986286410df",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pandas\/_libs\/internals.cpython-312-darwin.so",
"name" : "internals.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5706874880,
"size" : 36864,
"uuid" : "22e45744-c3ab-376a-a91f-e8e0ce804bbb",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pandas\/_libs\/indexing.cpython-312-darwin.so",
"name" : "indexing.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5813559296,
"size" : 626688,
"uuid" : "117dd40f-6c63-30dc-a6a7-dbfd996660fb",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pandas\/_libs\/index.cpython-312-darwin.so",
"name" : "index.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5803655168,
"size" : 147456,
"uuid" : "e4a77009-53b1-33c5-bc24-2ffb6609da5d",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pandas\/_libs\/writers.cpython-312-darwin.so",
"name" : "writers.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5811920896,
"size" : 958464,
"uuid" : "3e5b0b1a-e6ff-360a-8aab-21a46a44dda6",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pandas\/_libs\/join.cpython-312-darwin.so",
"name" : "join.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5702017024,
"size" : 16384,
"uuid" : "cf65d791-7070-39c9-a244-ea7a52da3006",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/lib-dynload\/mmap.cpython-312-darwin.so",
"name" : "mmap.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5573304320,
"size" : 8192,
"uuid" : "d7f6e3b5-88b0-3a39-97a3-83f6c143beaf",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/lib-dynload\/grp.cpython-312-darwin.so",
"name" : "grp.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5817282560,
"size" : 274432,
"uuid" : "3c7546dd-f43d-3cd2-82c7-54827f87bc36",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pandas\/_libs\/window\/aggregations.cpython-312-darwin.so",
"name" : "aggregations.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5805129728,
"size" : 126976,
"uuid" : "29d9162c-1047-3931-bdde-a8784a1c4e58",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pandas\/_libs\/window\/indexers.cpython-312-darwin.so",
"name" : "indexers.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5808500736,
"size" : 200704,
"uuid" : "a4e3a51b-f9b9-37da-993b-2ef93adc3e86",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pandas\/_libs\/reshape.cpython-312-darwin.so",
"name" : "reshape.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5823332352,
"size" : 1912832,
"uuid" : "df4b62c2-5c0b-3cd8-b71c-5a23f0369b6f",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pandas\/_libs\/groupby.cpython-312-darwin.so",
"name" : "groupby.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5577707520,
"size" : 4096,
"uuid" : "2f639e6f-e1d7-3c3f-9f4f-7fe2e848bf71",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/lib-dynload\/_uuid.cpython-312-darwin.so",
"name" : "_uuid.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5707354112,
"size" : 45056,
"uuid" : "4156c2c3-aebe-3093-91aa-9d7a84f8546b",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pandas\/_libs\/json.cpython-312-darwin.so",
"name" : "json.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5822476288,
"size" : 385024,
"uuid" : "426a5517-e3ab-3c97-a35a-571d3172a407",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pandas\/_libs\/parsers.cpython-312-darwin.so",
"name" : "parsers.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5708668928,
"size" : 69632,
"uuid" : "c613b5ed-8fb1-3d22-8213-a10e4dc21cfe",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pandas\/_libs\/testing.cpython-312-darwin.so",
"name" : "testing.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5705482240,
"size" : 28672,
"uuid" : "b0083006-e6a0-34bb-9bed-1c3f3b88e6ad",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/lib-dynload\/cmath.cpython-312-darwin.so",
"name" : "cmath.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5708947456,
"size" : 61440,
"uuid" : "14bba4c0-26a7-31c9-936c-941c22cadf86",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pyproj\/_context.cpython-312-darwin.so",
"name" : "_context.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5716025344,
"size" : 28672,
"uuid" : "2be3bb77-212c-31d8-acad-8a6793284ed5",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pyproj\/_compat.cpython-312-darwin.so",
"name" : "_compat.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5716303872,
"size" : 28672,
"uuid" : "a4a3c3b0-4248-3450-96bd-d90945cf3675",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pyproj\/_network.cpython-312-darwin.so",
"name" : "_network.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5716582400,
"size" : 61440,
"uuid" : "4520903a-8964-3c38-a400-bbf2d0b1d9ab",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/lib-dynload\/_socket.cpython-312-darwin.so",
"name" : "_socket.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5716111360,
"size" : 16384,
"uuid" : "a9b3d661-5ee8-34cf-be14-9fecd2ced5f6",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pyproj\/_version.cpython-312-darwin.so",
"name" : "_version.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5821489152,
"size" : 327680,
"uuid" : "32928b0d-9151-38fc-b297-de477226559d",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pyproj\/_crs.cpython-312-darwin.so",
"name" : "_crs.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5783875584,
"size" : 86016,
"uuid" : "ef51a174-2773-3e9a-95f1-d02603bad255",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pyproj\/_geod.cpython-312-darwin.so",
"name" : "_geod.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5718188032,
"size" : 28672,
"uuid" : "85715a9c-c361-3ee6-882d-acc09244555c",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pyproj\/list.cpython-312-darwin.so",
"name" : "list.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5779845120,
"size" : 73728,
"uuid" : "d130b818-6abc-325e-ab60-14bda0a69da2",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pyproj\/database.cpython-312-darwin.so",
"name" : "database.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5809528832,
"size" : 135168,
"uuid" : "7af0b667-cb2b-3e7d-a8f5-03062b3b6daf",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pyproj\/_transformer.cpython-312-darwin.so",
"name" : "_transformer.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5816643584,
"size" : 98304,
"uuid" : "e60662b5-4dcb-3906-bd80-4d1f8a19e7da",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/lib-dynload\/_ssl.cpython-312-darwin.so",
"name" : "_ssl.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5591838720,
"size" : 4096,
"uuid" : "7d26d5a2-6bad-37fc-a60d-f42dcbc690b8",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/lib-dynload\/_scproxy.cpython-312-darwin.so",
"name" : "_scproxy.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5719601152,
"size" : 20480,
"uuid" : "13b0ac14-43b2-322c-b384-c18256149b83",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/pyproj\/_sync.cpython-312-darwin.so",
"name" : "_sync.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5706969088,
"size" : 4096,
"uuid" : "fdd4c7c6-ee1d-3c03-a625-8592cd2e1b0d",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/lib-dynload\/_statistics.cpython-312-darwin.so",
"name" : "_statistics.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5841600512,
"size" : 1204224,
"uuid" : "40274ff1-32a6-352a-aed1-d2ea67cd0415",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/osgeo\/_gdal.cpython-312-darwin.so",
"name" : "_gdal.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5781434368,
"size" : 36864,
"uuid" : "e44f7fdf-20c4-3adb-a5a8-f6b42baf0854",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/osgeo\/_gdalconst.cpython-312-darwin.so",
"name" : "_gdalconst.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5845073920,
"size" : 733184,
"uuid" : "cae2d849-3c68-337b-a08e-0665120ea9c9",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/osgeo\/_ogr.cpython-312-darwin.so",
"name" : "_ogr.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5827629056,
"size" : 409600,
"uuid" : "45fa9714-9d8b-3111-b9d1-eace31c860b4",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/osgeo\/_osr.cpython-312-darwin.so",
"name" : "_osr.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5796483072,
"size" : 77824,
"uuid" : "504e7002-d3a4-3167-8492-9b284461fb1c",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/osgeo\/_gdal_array.cpython-312-darwin.so",
"name" : "_gdal_array.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5781843968,
"size" : 69632,
"uuid" : "5fa8178d-8279-37a7-902c-bea2a972b595",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/osgeo\/_gnm.cpython-312-darwin.so",
"name" : "_gnm.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5716389888,
"size" : 16384,
"uuid" : "1e27bccc-348a-3674-aa4d-da8b986cb95a",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/lib-dynload\/_heapq.cpython-312-darwin.so",
"name" : "_heapq.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5709643776,
"size" : 8192,
"uuid" : "ee75f576-3510-3e90-9a1c-307bf8042801",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/lib-dynload\/_queue.cpython-312-darwin.so",
"name" : "_queue.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5782122496,
"size" : 24576,
"uuid" : "4c5d37ae-de89-3152-b9c9-dbf68ffa5aab",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/lib-dynload\/_multibytecodec.cpython-312-darwin.so",
"name" : "_multibytecodec.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5852274688,
"size" : 1683456,
"uuid" : "44d0c9b3-e25c-3fba-8750-f969bfe20eb4",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/lxml\/etree.cpython-312-darwin.so",
"name" : "etree.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5830791168,
"size" : 184320,
"uuid" : "f8c6c10b-3d2a-3be7-a070-0d0a8d9d0fb7",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libxslt.1.dylib",
"name" : "libxslt.1.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 5785165824,
"size" : 65536,
"uuid" : "10dc4d10-d4ea-394e-a9f4-4a30dbb1e60f",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libexslt.0.dylib",
"name" : "libexslt.0.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 5831049216,
"size" : 139264,
"uuid" : "6458ee24-a234-3340-9d0a-14aa00b2a49c",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/lxml\/_elementpath.cpython-312-darwin.so",
"name" : "_elementpath.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5785444352,
"size" : 45056,
"uuid" : "8353f890-fef3-312a-a6e9-36a036e00625",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/lib-dynload\/_elementtree.cpython-312-darwin.so",
"name" : "_elementtree.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5785722880,
"size" : 40960,
"uuid" : "d9be030f-2155-30a0-87b6-12cbd98ecd5c",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/lib-dynload\/pyexpat.cpython-312-darwin.so",
"name" : "pyexpat.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5718274048,
"size" : 4096,
"uuid" : "42e50ab3-1598-3d05-8b09-ca0f4e745616",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/markupsafe\/_speedups.cpython-312-darwin.so",
"name" : "_speedups.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5862023168,
"size" : 1044480,
"uuid" : "b218d2d6-966e-3fec-8f6d-c0c116f48aca",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/qgis\/_analysis.so",
"name" : "_analysis.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5830086656,
"size" : 172032,
"uuid" : "e38ec342-2e42-3c1b-9666-388faaf7b1b9",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Resources\/python3.11\/site-packages\/psycopg2\/_psycopg.cpython-312-darwin.so",
"name" : "_psycopg.cpython-312-darwin.so"
"source" : "P",
"arch" : "x86_64",
"base" : 5566361600,
"size" : 24576,
"uuid" : "0ebd3e43-e518-311b-91c1-43f0301a4af0",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Qt6\/qml\/QtQuick\/Layouts\/libqquicklayoutsplugin.dylib",
"name" : "libqquicklayoutsplugin.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 5844357120,
"size" : 155648,
"uuid" : "42802061-14d3-3438-9704-eb261261b99d",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libQt6QuickLayouts.6.dylib",
"name" : "libQt6QuickLayouts.6.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 5566189568,
"size" : 40960,
"uuid" : "bfe8fd4f-0d6c-3ce5-b886-40a64e76395e",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Qt6\/qml\/QtQuick\/Controls\/libqtquickcontrols2plugin.dylib",
"name" : "libqtquickcontrols2plugin.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 5847199744,
"size" : 192512,
"uuid" : "dc490a77-16bc-3df4-b852-3e4f28117af0",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libQt6QuickControls2Impl.dylib",
"name" : "libQt6QuickControls2Impl.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 5566271488,
"size" : 28672,
"uuid" : "5331d70a-95c6-3263-afae-5eeab09e32d6",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Qt6\/qml\/QtQuick\/Controls\/Material\/libqtquickcontrols2materialstyleplugin.dylib",
"name" : "libqtquickcontrols2materialstyleplugin.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 5893480448,
"size" : 1556480,
"uuid" : "77bc973f-16b5-3c2b-b7ec-87d883c221cc",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libQt6QuickControls2Material.6.dylib",
"name" : "libQt6QuickControls2Material.6.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 5566558208,
"size" : 237568,
"uuid" : "63722365-80dc-3d3d-b28b-91e39cb46703",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libQt6QuickControls2MaterialStyleImpl.dylib",
"name" : "libQt6QuickControls2MaterialStyleImpl.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 5567307776,
"size" : 28672,
"uuid" : "c4a21fca-d2e3-3b1f-a0eb-e90049c4f622",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Qt6\/qml\/QtQuick\/Controls\/Basic\/libqtquickcontrols2basicstyleplugin.dylib",
"name" : "libqtquickcontrols2basicstyleplugin.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 5887086592,
"size" : 1540096,
"uuid" : "f92cdfbe-c3f6-3dca-a419-c1381b522291",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libQt6QuickControls2Basic.6.dylib",
"name" : "libQt6QuickControls2Basic.6.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 5567131648,
"size" : 49152,
"uuid" : "32b4986a-836c-3917-aab9-f1e353c88ecd",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libQt6QuickControls2BasicStyleImpl.dylib",
"name" : "libQt6QuickControls2BasicStyleImpl.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 5567377408,
"size" : 24576,
"uuid" : "5968d74f-a1eb-37f1-b279-b4b34672061a",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Qt6\/qml\/QtQuick\/Effects\/libeffectsplugin.dylib",
"name" : "libeffectsplugin.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 5850705920,
"size" : 294912,
"uuid" : "86341ac8-020d-3f13-b51e-f76ce09b86d4",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Frameworks\/libQt6QuickEffects.dylib",
"name" : "libQt6QuickEffects.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 5719396352,
"size" : 24576,
"uuid" : "1427e88f-d28f-3430-bfdf-d94b8f98168c",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Qt6\/qml\/QtQuick\/Templates\/libqtquicktemplates2plugin.dylib",
"name" : "libqtquicktemplates2plugin.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 5567442944,
"size" : 16384,
"uuid" : "da7bfb52-f07a-3a80-98c3-29b092463012",
"path" : "\/Applications\/QGIS-final-4_0_0.app\/Contents\/Qt6\/qml\/QtQuick\/Window\/libquickwindowplugin.dylib",
"name" : "libquickwindowplugin.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 140703598780416,
"size" : 40016,
"uuid" : "fc0c42b2-0b55-370b-8fc7-17bac96bb458",
"path" : "\/usr\/lib\/system\/libsystem_platform.dylib",
"name" : "libsystem_platform.dylib"
"size" : 0,
"source" : "A",
"base" : 0,
"uuid" : "00000000-0000-0000-0000-000000000000"
"source" : "P",
"arch" : "x86_64",
"base" : 140703598473216,
"size" : 252184,
"uuid" : "2a7e104e-0d59-34a8-83d9-cc70154464eb",
"path" : "\/usr\/lib\/system\/libsystem_kernel.dylib",
"name" : "libsystem_kernel.dylib"
"source" : "P",
"arch" : "x86_64h",
"base" : 140703599013888,
"CFBundleShortVersionString" : "6.9",
"CFBundleIdentifier" : "com.apple.CoreFoundation",
"size" : 4963843,
"uuid" : "513bef17-6379-3bb8-897b-69a7999d5abf",
"path" : "\/System\/Library\/Frameworks\/CoreFoundation.framework\/Versions\/A\/CoreFoundation",
"name" : "CoreFoundation",
"CFBundleVersion" : "4302"
"source" : "P",
"arch" : "x86_64",
"base" : 140703618494464,
"CFBundleIdentifier" : "com.apple.Foundation",
"size" : 16723299,
"uuid" : "ec8bb14d-3fce-346e-9b31-29429579e895",
"path" : "\/System\/Library\/Frameworks\/Foundation.framework\/Versions\/C\/Foundation",
"name" : "Foundation",
"source" : "P",
"arch" : "x86_64",
"base" : 140703664607232,
"CFBundleIdentifier" : "com.apple.AppKit",
"size" : 25141499,
"uuid" : "2bd11255-89ea-38b5-b640-4dac3f1ae380",
"path" : "\/System\/Library\/Frameworks\/AppKit.framework\/Versions\/C\/AppKit",
"name" : "AppKit",
"CFBundleVersion" : "2685.40.108"
"source" : "P",
"arch" : "x86_64",
"base" : 140703596933120,
"size" : 293154,
"uuid" : "22d4457f-c2ab-36da-a743-e92bef816167",
"path" : "\/usr\/lib\/system\/libdispatch.dylib",
"name" : "libdispatch.dylib"
"source" : "P",
"arch" : "x86_64",
"base" : 140703598727168,
"size" : 49192,
"uuid" : "f9c81fc7-1abf-3b5e-a6b3-3113dad29577",
"path" : "\/usr\/lib\/system\/libsystem_pthread.dylib",
"name" : "libsystem_pthread.dylib"
"sharedCache" : {
"base" : 140703552618496,
"size" : 30064771072,
"uuid" : "c5c54f46-8539-3e2c-b310-991d6c162ab1"
"vmSummary" : "ReadOnly portion of Libraries: Total=2.1G resident=0K(0%) swapped_out_or_unallocated=2.1G(100%)\nWritable regions: Total=837.1M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=837.1M(100%)\n\n VIRTUAL REGION \nREGION TYPE SIZE COUNT (non-coalesced) \n=========== ======= ======= \nAccelerate framework 128K 1 \nActivity Tracing 256K 1 \nAttributeGraph Data 1024K 1 \nColorSync 8K 1 \nCoreAnimation 808K 71 \nCoreGraphics 24K 4 \nCoreUI image data 568K 5 \nFoundation 16K 1 \nJS VM Gigacage 4096K 1 \nJS VM Isolated Heap 4368K 4 \nJS VM Isolated Heap (reserved) 2048K 1 reserved VM address space (unallocated)\nKernel Alloc Once 12K 2 \nMALLOC 738.6M 220 \nMALLOC guard page 64K 16 \nMALLOC_LARGE (reserved) 384K 1 reserved VM address space (unallocated)\nSTACK GUARD 56.1M 18 \nStack 24.1M 19 \nVM_ALLOCATE 57.1M 77 \n__CTF 824 1 \n__DATA 54.2M 1411 \n__DATA_CONST 141.6M 1369 \n__DATA_DIRTY 7905K 867 \n__FONT_DATA 2352 1 \n__GLSLBUILTINS 5174K 1 \n__INFO_FILTER 8 1 \n__LINKEDIT 413.1M 347 \n__OBJC_RO 64.4M 1 \n__OBJC_RW 2570K 2 \n__TEXT 1.7G 1384 \n__TEXT (graphics) 16.8M 6 \n__TPRO_CONST 4K 1 \ndyld private memory 23.5M 165 \nmapped file 557.7M 85 \nshared memory 1324K 22 \n=========== ======= ======= \nTOTAL 3.8G 6108 \nTOTAL, minus reserved VM space 3.8G 6108 \n",
"legacyInfo" : {
"threadTriggered" : {
"queue" : "com.apple.main-thread"
"logWritingSignature" : "c89049d9ccb6ee21165ef61b902b458eb7c60459",
"roots_installed" : 0,
"bug_type" : "309",
"trmStatus" : 2105856,
"trialInfo" : {
"rollouts" : [
"rolloutId" : "60186475825c62000ccf5450",
"factorPackIds" : [
"deploymentId" : 240000083
"rolloutId" : "67181b10c68c361a728c7cfa",
"factorPackIds" : [
"deploymentId" : 240000005
"experiments" : [
Model: MacBookPro16,1, BootROM 2094.80.5.0.0 (iBridge: 23.16.13120.0.0,0), 6 processors, 6-Core Intel Core i7, 2.6 GHz, 16 GB, SMC
Graphics: Intel UHD Graphics 630, Intel UHD Graphics 630, Built-In
Graphics: AMD Radeon Pro 5300M, AMD Radeon Pro 5300M, PCIe, 4 GB
Display: Color LCD, 3072 x 1920 Retina, MirrorOff, Online
Display: LG Ultra HD, 3840 x 2160 (2160p/4K UHD 1 - Ultra High Definition), Main, MirrorOff, Online
Memory Module: BANK 0/ChannelA-DIMM0, 8 GB, DDR4, 2667 MHz, SK Hynix, HMA81GS6CJR8N-VK
Memory Module: BANK 2/ChannelB-DIMM0, 8 GB, DDR4, 2667 MHz, SK Hynix, HMA81GS6CJR8N-VK
AirPort: spairport_wireless_card_type_wifi (0x14E4, 0x7BF), wl0: Jul 26 2024 22:36:01 version 9.30.514.0.32.5.94 FWID 01-68d7ff80
AirPort:
Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
Thunderbolt Bus: MacBook Pro, Apple Inc., 63.5
Jacob Chaar
More information about the QGIS-User
