[Qgis-user] Integrate custom transformation to Proj Database for use in QGIS
Klaus Mithöfer mithoefer at gbd-consult.de
Mon May 4 03:37:18 PDT 2026
Dear Andrea,
Thank you very much for your support! I was out of office for some days.
That worked perfectly! I did not know the concept of the "usage" table.
Kind regards,
Klaus
Am 29.04.26 um 00:23 schrieb Andrea Giudiceandrea via QGIS-User:
>> Tue Apr 28 09:43:56 PDT 2026
>> i use proj 9.4.0. I want to add a transformation similar to an
>> existing one (code 15984 EPSG 32467 to 258322). But I want to use a
>> different Transformation grid.
>> Proj.db has a table grid_transformation. I have added a data set
>> similar to 15984 to code 15984 but with a different grid name.
> You probably meant "code 15948 EPSG 31467 to 25832".
> For PROJ 9.4, you also need to modify the "usage" table, other then the
> "grid_transformation" table, adding a row corresponding with the row
> added in the "grid_transformation" table.
> For example, the following SQL statements add the needed rows for a NTv2
> transformation similar to EPSG:15948 but using the BETA2007_CUSTOM.gsb
> grid shift file:
> INSERT INTO "grid_transformation"
> VALUES ('PROJ', 'DHDN_TO_ETRS89_CUSTOM', 'DHDN to ETRS89 (CUSTOM)',
> NULL, 'EPSG', '9615', 'NTv2', 'EPSG', '4314', 'EPSG', '4258', '0.9',
> 'EPSG', '8656', 'Latitude and longitude difference file',
> 'BETA2007_CUSTOM.gsb', NULL, NULL, NULL, NULL, NULL, NULL, NULL, '0');
> INSERT INTO "usage"
> VALUES (NULL, NULL, 'grid_transformation', 'PROJ',
> 'DHDN_TO_ETRS89_CUSTOM', 'EPSG', '3339', 'EPSG', '1041');
> Regards.
> Andrea
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
More information about the QGIS-User mailing list
