[Qgis-user] Fw: Semi-Automatic Classification Plugin for QGIS incompatible python environment
Richard Duivenvoorde rdmailings at duif.net
Wed May 20 22:47:43 PDT 2026
Hi Brent,
Not sure if you are on Linux or Windows? Maybe other with experience on Remotior Sensus can help with your install (though it looks like they only provide the conda install https://pypi.org/project/remotior-sensus/?)
But I guess it will be a hell of a job to make one install use the python of the other install. You will end up in dependency hell :-(
So IF you want to play with the plugin, I'd say: install (another) QGIS in the Conda environment. Use that one when you need the plugin.
I'm not so familiar with the Conda installed QGIS, but I guess it will just use your normal profiles (and plugins). So (unless both installs are very different QGIS versions), all should 'just work' ...
HTH, Regards,
On 5/21/26 07:03, Brent Wood via QGIS-User wrote:
> Hi,
> I'm trying to set the Semi-Automatic Classification Plugin for QGIS in QGIS 3.34,
> but am unable to install the dependency Remotior Sensus except in a Conda environment.
> I'm then unable to start QGIS in this environment, getting the error:
> Inline image
> There seems to be a conflict between the QGIS system installed Python environment and the Conda environment used for Remotior Sensus.
> I'm unable to find a resolution to this in any provided documentation.
> Can anyone suggest how I can reconcile these to get the plugin working, while retaining a standard QGIS installation?
> Thanks,
> Brent Wood
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
More information about the QGIS-User mailing list
