[Qgis-user] Disable QGIS auto update
Frederik Mørup Jacobsen HKfrmo at herlev.dk
Thu May 28 04:59:36 PDT 2026
Our MSI is from 4. of October 2025 and is called:
QGIS-OSGeo4W-3.40.10-1.msi
This should ensure that we are installation the old 3.40.10 version.
BR
Frederik
-----Oprindelig meddelelse-----
Fra: DelazJ <delazj at gmail.com>
Sendt: 28. maj 2026 13:26
Til: Régis Haubourg <regis.haubourg at gmail.com>; Régis Haubourg via QGIS-User <qgis-user at lists.osgeo.org>; Frederik Mørup Jacobsen <HKfrmo at herlev.dk>; qgis-user at lists.osgeo.org
Emne: Re: [Qgis-user] Disable QGIS auto update
Le 28 mai 2026 08:05:38 GMT+00:00, "Régis Haubourg via QGIS-User" <qgis-user at lists.osgeo.org> a écrit :
>Can you check what executable is linked to your icon ?
>Qgis-ltr and qgis-release are isolated launchers.
Just to remind that qgis-release doesn't point to 3.40 anymore but to 4.0. So unless the OP specifically selected the 3.40 executable in the download archives folder, they were probably installing 4.0 at the start...
Harrissou
>If you have custom deployment and packaging scripts. I'm afraid we can't diagnose this for you.
>Le 28 mai 2026 08:33:42 GMT+02:00, "Frederik Mørup Jacobsen" <HKfrmo at herlev.dk> a écrit :
>>Hi.
>>This is weird.
>>We are using our own win32 apps. Made from the offline installer from the qgis website.
>>I tried installing the 3.40.10 version on my own computer from our Company Portal yesterday. I then closed the application and after a few hours it was updated to version 4.
>>This is the same behavior other colleagues have experienced.
>>Venlig hilsen
>>Konsulent
>>Tlf: 4452 7123
>>HKfrmo at herlev.dk
>>[Nyt HK logo 290925]
>>IT og Digitalisering
>>Herlev Kommune
>>Herlev Hovedgade 110, 1. sal
>>2730 Herlev
>>[cid:image006.png at 01DCEE7C.AF9698F0]<https://www.facebook.com/2730HerlevKommune>   [cid:image007.png at 01DCEE7C.AF9698F0] <https://www.linkedin.com/company/herlev-kommune>    [cid:image008.png at 01DCEE7C.AF9698F0] <https://www.instagram.com/herlev.kommune/>
>>Fra: Régis Haubourg <regis.haubourg at gmail.com>
>>Sendt: 28. maj 2026 08:25
>>Til: Frederik Mørup Jacobsen <HKfrmo at herlev.dk>;
>>Emne: Re: SV: [Qgis-user] Disable QGIS auto update
>>Hi, Frederik,
>>let's try to narrow down what is happening.
>>QGIS itself doesn't have autoupgrade feature, I confirm. There is a notification message in the status bar possibly, but nothing without manually downloading the packages and launching the installation.
>>Are you using your own Intune packages or are they already proposed by the Microsoft store?
>>Bien cordialement,
>>Régis Haubourg
>>On 28/05/2026 07:51, Frederik Mørup Jacobsen wrote:
>>If so, then I have another problem internally. 😊
>>Sådan behandler Herlev Kommune dine persondata Når du henvender dig
>>til Herlev Kommune, behandler vi oplysninger om dig i overensstemmelse med databeskyttelsesreglerne. Vi bruger dine oplysninger til at behandle og besvare din henvendelse, og vi sletter dine oplysninger efter arkivlovens regler. På Herlev.dk/persondata<https://www.herlev.dk/om-kommunen/rettigheder-og-svarfrister/databeskyttelse/> kan du læse mere om dine rettigheder, og om hvordan vi passer på dine oplysninger.
Når du henvender dig til Herlev Kommune, behandler vi oplysninger om dig i overensstemmelse med databeskyttelsesreglerne. Vi bruger dine oplysninger til at behandle og besvare din henvendelse, og vi sletter dine oplysninger efter arkivlovens regler. På Herlev.dk/persondata<https://www.herlev.dk/om-kommunen/rettigheder-og-svarfrister/databeskyttelse/> kan du læse mere om dine rettigheder, og om hvordan vi passer på dine oplysninger.
More information about the QGIS-User mailing list
