[Qgis-user] Disable QGIS auto update
Frederik Mørup Jacobsen HKfrmo at herlev.dk
Thu May 28 23:25:25 PDT 2026
It still auto updates.
I made a fresh install on my computer with version 3.44.10
This morning it has autoupdated to version 4.0.2
Are there any suggestions to what may be causing this?
BR
Frederik
-----Oprindelig meddelelse-----
Fra: QGIS-User <qgis-user-bounces at lists.osgeo.org> På vegne af Frederik Mørup Jacobsen via QGIS-User
Sendt: 28. maj 2026 15:06
Til: Jürgen E. Fischer <jef at norbit.de>; qgis-user at lists.osgeo.org
Emne: Re: [Qgis-user] Disable QGIS auto update
Its called qgis-ltr-bin.exe in Properties under "Destination".
I have tried installing 3.44.10 now and will see if that autoupdates as well.
I will keep you posted.
BR
Frederik
Fra: QGIS-User <qgis-user-bounces at lists.osgeo.org> På vegne af Jürgen E. Fischer via QGIS-User
Sendt: 28. maj 2026 15:00
Til: qgis-user at lists.osgeo.org
Hi DelazJ
On Thu, 28. May 2026 at 11:25:47 +0000, DelazJ via QGIS-User wrote:
> Le 28 mai 2026 08:05:38 GMT+00:00, "Régis Haubourg via QGIS-User" <qgis-user at lists.osgeo.org> a écrit :
> >Can you check what executable is linked to your icon ?
> >Qgis-ltr and qgis-release are isolated launchers.
> Just to remind that qgis-release doesn't point to 3.40 anymore but to
> 4.0. So unless the OP specifically selected the 3.40 executable in the
> download archives folder, they were probably installing 4.0 at the start...
That's the point.
In OSGeo4W (and in turn the msis) 3.40.10 can only be an qgis-ltr (or qgis-ltr-dev), while 4.0 can only be qgis (or qgis-rel-dev).
So the link shortcut should be different (qgis-bin.exe vs. qgis-ltr-bin.exe).
So it can't even be a OSGeo4W update - how ever that could be initiated silently automatically, because that wouldn't uninstall qgis-ltr and install qgis.  An update would just update qgis-ltr to 3.44.
I suppose there is something else going on outside of the installer that determines that 4.0 is the latest release, fetches the latest MSI and removes the installed one upfront - without any action on our part.
Maybe "it" just detects that there are more downloads in the QGIS-OSGeo4W-\d+-\d+.msi scheme with QGIS-OSGeo4W-4.0.2-1.msi being the latest.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden            https://www.norbit.de/
QGIS release manager (PSC)  Germany                  Matrix: @jef:osgeo.org
Sådan behandler Herlev Kommune dine persondata Når du henvender dig til Herlev Kommune, behandler vi oplysninger om dig i overensstemmelse med databeskyttelsesreglerne. Vi bruger dine oplysninger til at behandle og besvare din henvendelse, og vi sletter dine oplysninger efter arkivlovens regler. På Herlev.dk/persondata<https://www.herlev.dk/om-kommunen/rettigheder-og-svarfrister/databeskyttelse/> kan du læse mere om dine rettigheder, og om hvordan vi passer på dine oplysninger.
QGIS-User mailing list
QGIS-User at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
More information about the QGIS-User mailing list
