[Qgis-user] Question about accessing GIS files stored in Box directly from QGIS
Patrick Dunford
enzedrailmaps at gmail.com
Sun Nov 8 16:02:35 PST 2026
Good day.
It appears from your query you are wishing to have some form of access
to local files which are synchronised to a cloud such as Google Drive.
This may work well if there is only one user accessing the data but
generally as is the case when using a local area network, there are
likely to be significant problems if files are being shared between
multiple users. Web drive synchronisation of local files is not a
reliable substitution for client/server database management systems that
are normally required for multi user access in complex data processing
applications like Qgis.
On 06/11/2026 18:20, 篠田侑希 via QGIS-User wrote:
> Hello,
> I am currently testing different ways of accessing GIS data in QGIS.
> We are comparing the following storage locations:
> ・Local folders
> ・Cloud drives mounted or accessible from Windows Explorer
> ・Web-based cloud storage such as Box
> We would like to know whether GIS files stored in Box, such as
> Shapefiles, GeoPackages, and GeoTIFF files, can be accessed directly
> from QGIS using a Box URL, without downloading them to a local folder.
> We have the following questions:
> 1.Can QGIS directly access GIS files stored in Box using a shared URL
> or download URL?
> 2.If not, is there another supported method for accessing files stored
> in Box from QGIS?
> 3.Would using a desktop synchronization tool such as Box Drive be the
> recommended approach?
> 4.Are there any limitations or considerations regarding performance,
> editing, or saving data when using cloud storage with QGIS?
> Our goal is to determine whether a web-based cloud storage service
> such as Box can be used as a practical data storage location for QGIS.
> Thank you very much for your help.
> Best regards,
> Yuki
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
More information about the QGIS-User
