[Qgis-user] Error Message
oisin.kelly.wild at gmail.com oisin.kelly.wild at gmail.com
Sat Oct 17 03:15:20 PDT 2026
Have you connected by a URL? E.g. WMS, or a file download.
 For file download just drag and drop file. If you intend to edit the file, unzip download first, if not drag and drop entire zip download works. CRS is epsg 27700.
     Hi Ralph,
     Can you provide us with the screenshots?
 Best regards,
 Vladimir
        Vuković
 Founder, FiberQ
   vukovicvl at fiberq.net
         +381 60 426 2012
   FiberQ
          · open-source FTTH/GPON design
          plugin for QGIS
   FiberQ
          Designer    · fiber network
          design in the browser
        Good day
        Am using QGIS 3.44 for the first time, although have used
        (ocassionally) 3.16 before.
        Am investigating the results of LIDAR data from the UK
        government program, and the use of the data.
        I set the CRS of the program to match the info on the LIDAR file
        header and tried adding the file. All I got was a frame with a
        dashed border and an error message
         " Layer
            TM0220_P_12465_20211222_20211222:
           Untwine error:
            Untwine exited with code: 4294967295"
        What have I done wrong?
        Thanks
QGIS-User mailing list
 QGIS-User at lists.osgeo.org
List info:  https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe:  https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20261017/0189a381/attachment-0001.htm>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20261017/0189a381/attachment-0001.png>
More information about the QGIS-User mailing list
