[Qgis-user] cant import dwg
Klaus Mithöfer
mithoefer at gbd-consult.de
Tue Oct 20 06:31:40 PDT 2026
Hi Boaz,
you have to to convert your data to AutoCAD to another version Check
gdal.org. QGIS supports older AutoCAD DWG versions (typically 2004
through 2013.
Regards,
Klaus
Am 20.10.26 um 15:20 schrieb Boaz Bar Ilan via QGIS-User:
> hi
> using 3.44.15
> trung to import dwg and get
> Drawing import failed (unsupported version. Cannot read AutoCAD
> 2018/2019/2020 documents.)
> what can i do ?
> thanks
> boaz
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
More information about the QGIS-User
