[Qgis-user] QGIS 4.2.3: Ruckeln beim Zoomen und Verschieben – Optimierung und Hardwareempfehlung
Emma Hain emma at north-road.com
Mon Oct 26 01:15:28 PDT 2026
Hi Nasari
Your system seems capable. I am sure AI will tell you how to optimally run
it, from a quick look it mentions:
   - *Enable Max Render Threads:* Go to Settings -> Options -> Rendering
   and ensure *Max render threads* is set to match your high core count
   (you can safely set this to 16 or 20 to allow lightning-fast background map
   rendering).
   - *Maximize Feature Cache:* Under the same Rendering menu, enable *Enable
   feature caching where possible* to utilize your 64 GB of RAM for
   smoother pan and zoom operations.
   - *Keep GPU Drivers Updated:* Ensure you are using NVIDIA's *RTX
   Enterprise / Quadro Production Branch drivers* (rather than the New
   Feature branch) for maximum stability in GIS environments.
Here are some tests you can do.
1) Rebuild and add the data layer one by one and undertake your actions to
see if there is a data layer there that triggers it
2) Create a new user profile
<https://docs.qgis.org/3.44/en/docs/user_manual/introduction/qgis_configuration.html#working-with-user-profiles>.
This will bring in a clean project without other plugins loaded in. Test it
with the data again to see if it still behaves the same
3) Unless you need QGIS v4, I would go back to QGIS v3.44 the Long Term
Release and see if it also happens in this version.
4) Check the projections of your data as well. If there are multiple
projections, then this could be an issue.
All the best!
Em
On Mon, 26 Oct 2026 at 16:51, Karlo no Dabas maajas via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Hi!
> The weakest part of everything You have mentioned, is «Windows 11» as OS.
> Best regards,
> Z.
> 23.10.26 16:11, Nasari Ruhullah via QGIS-User rakstīja:
> > Sehr geehrte Damen und Herren,
> > wir verwenden QGIS für Vermessungs- und Trassenprojekte.
> > Beim Hinein- und Herauszoomen sowie beim Verschieben der Karte ruckelt
> > die Darstellung.
> > Es entstehen keine langen Wartezeiten, die Bedienung läuft jedoch
> > nicht flüssig.
> > Unsere Systemkonfiguration:
> >   * QGIS 4.2.3 „Belém do Pará“
> >   * Windows 11 Pro, Version 25H2, Build 26200.9711
> >   * Intel Core Ultra 7 265K, 20 Kerne
> >   * 64 GB Arbeitsspeicher
> >   * NVMe-SSD
> >   * NVIDIA Quadro P2200
> > Die Projektdaten liegen nach unserem Kenntnisstand lokal im Ordner
> > „Dokumente“. Im Projekt sind unter anderem Vermessungs- und
> > Trassenlayer sowie die Layer „DKM“ und „Ortho“ eingebunden.
> > Screenshots der Layerliste und Systeminformationen finden Sie im Anhang.
> > Welche Einstellungen oder Maßnahmen empfehlen Sie, um das Zoomen und
> > Verschieben flüssiger zu gestalten? Wie können wir feststellen,
> > welcher Layer oder Verarbeitungsschritt die Verzögerungen verursacht?
> > Ist unsere Hardware für solche Projekte ausreichend, oder empfehlen
> > Sie eine andere Ausstattung? Welche weiteren Angaben zu Datenformaten,
> > Datenmengen und Layerquellen benötigen Sie für eine fundierte
> > Einschätzung?
> > Vielen Dank für Ihre Unterstützung.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20261026/86330ef2/attachment.htm>
More information about the QGIS-User mailing list
