[QGIS-ZA-user] QGIS Legend Problem
Immo Blecher
immob19 at gmail.com
Mon Jul 17 05:23:45 PDT 2017
Sorry Frank, I realised later that I did not send that info. Here it is:
QGIS version
2.18.10
QGIS code revision
59e0f78 <https://github.com/qgis/QGIS/commit/59e0f78>
Compiled against Qt
4.8.7
Running against Qt
4.8.7
Compiled against GDAL/OGR
1.11.3
Running against GDAL/OGR
1.11.3
Compiled against GEOS
3.5.0-CAPI-1.9.0
Running against GEOS
3.5.0-CAPI-1.9.0 r4084
PostgreSQL Client Version
9.5.2
SpatiaLite Version
4.3.0a
QWT Version
5.2.3
PROJ.4 Version
492
QScintilla2 Version
2.9.1
And I run it under Ubuntu 16.04 LTS
Thanks
Immo
On 17/07/2017 14:19, Frank Sokolic via qgis-za-user wrote:
> Hi Immo,
> Which version of QGIS are you using?
> Frank.
> On 17/07/2017 09:48, Immo Blecher via qgis-za-user wrote:
>> Good Morning Everyone,
>> I have a geology layer with a few columns, including the
>> chronostratigraphic symbol, the rock type description and,
>> importantly, a colour column (String type). The values stored in the
>> colour column are the HTML hex values for the colour according to the
>> 1 : 1 000 000 simplified geological map of South Africa.
>> When I open the layer and select the colour column for colouring the
>> lithological units it works beautifully, but I do not get a legend
>> for the composer. But if I set the Properties|Style to Categorized
>> and then again select the colour from the Colour column in the table
>> I also get the same nicely coloured map according to the colour
>> column, an a Legend. But the Legend is wrong...it chooses random
>> colours! What am I doing wrong? Is there a way to get a correct
>> legend, also only showing the units which are actually on the map in
>> the composer. I can set the colours manually to match the value in
>> the colour field but that sort of defeats the purpose.
>> Thanks for your help so long,
>> Immo
>> *Immo F. Blecher**Street: */52 Lynedoch Eco Village, Lynedoch, 7603,
>> South Africa //*Postal:*//52 Lynedoch Eco Village, Lynedoch, 7603,
>> South Africa //*Cell:*///+27 83 272 6791 |*Fax: *+27 86 7363302
>> *Email:*_immo at blecher.co.za_ <mailto:immo at blecher.co.za> |
>> _immob19 at gmail.com_ <mailto:immob19 at gmail.com>|
>> _immob at mymtnmail.co.za <mailto:immob at mymtnmail.co.za>
>> _*Internet:*_http://www.blecher.co.za/_
>> qgis-za-user mailing list
>> qgis-za-user at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/qgis-za-user
South Africa //*Postal:*//52 Lynedoch Eco Village, Lynedoch, 7603, South
_immob19 at gmail.com_ <mailto:immob19 at gmail.com>| _immob at mymtnmail.co.za
<mailto:immob at mymtnmail.co.za> _*Internet:*_http://www.blecher.co.za/_
Contact me: immob19 at gmail.com immoblecher
<http://www.linkedin.com/pub/immo-blecher/30/414/b8>
Please consider your environmental responsibility. Before printing this
e-mail message, ask yourself whether you really need a hard copy.
IMPORTANT: The contents of this email and any attachments are
confidential. They are intended for the named recipient(s) only. If you
have received this email by mistake, please notify the sender
immediately and do not disclose the contents to anyone or make copies
thereof.
URL: <http://lists.osgeo.org/pipermail/qgis-za-user/attachments/20170717/0ccdaaca/attachment-0001.html>
More information about the qgis-za-user
