[QGIS-ZA-user] QGIS Legend Problem
Immo Blecher immob19 at gmail.com
Mon Jul 17 06:10:18 PDT 2017
Hello Everyone again,
It seems my file is still too big. Only 100k is allowed. Will try a new
example with maybe only 3 or 4 polygons.
Regards
Immo
On 17/07/2017 14:45, Dean Ollis via qgis-za-user wrote:
> Hi, Immo
> Could you send us a copy of the layer you are trying to render with a
> legend, or a clipped section of the layer? That will help with the
> testing...
> Thanks
> Dean
> Dean Ollis
> Freshwater Research Centre
> Kommetjie, Cape Town
> CELL: 072 377 7006
> -------- Original Message --------
> Subject: Re: [QGIS-ZA-user] QGIS Legend Problem
> From: Immo Blecher via qgis-za-user <qgis-za-user at lists.osgeo.org>
> To: South Africa QGIS user group <qgis-za-user at lists.osgeo.org>
> Cc: Immo Blecher <immob19 at gmail.com>
> Date: 17/07/2017 14:23
>> Sorry Frank, I realised later that I did not send that info. Here it is:
>> QGIS version
>> 2.18.10
>> QGIS code revision
>> 59e0f78 <https://github.com/qgis/QGIS/commit/59e0f78>
>> Compiled against Qt
>> 4.8.7
>> Running against Qt
>> 4.8.7
>> Compiled against GDAL/OGR
>> 1.11.3
>> Running against GDAL/OGR
>> 1.11.3
>> Compiled against GEOS
>> 3.5.0-CAPI-1.9.0
>> Running against GEOS
>> 3.5.0-CAPI-1.9.0 r4084
>> PostgreSQL Client Version
>> 9.5.2
>> SpatiaLite Version
>> 4.3.0a
>> QWT Version
>> 5.2.3
>> PROJ.4 Version
>> 492
>> QScintilla2 Version
>> 2.9.1
>> And I run it under Ubuntu 16.04 LTS
>> Thanks
>> Immo
>> On 17/07/2017 14:19, Frank Sokolic via qgis-za-user wrote:
>>> Hi Immo,
>>> Which version of QGIS are you using?
>>> Frank.
>>> On 17/07/2017 09:48, Immo Blecher via qgis-za-user wrote:
>>>> Good Morning Everyone,
>>>> I have a geology layer with a few columns, including the
>>>> chronostratigraphic symbol, the rock type description and,
>>>> importantly, a colour column (String type). The values stored in
>>>> the colour column are the HTML hex values for the colour according
>>>> to the 1 : 1 000 000 simplified geological map of South Africa.
>>>> When I open the layer and select the colour column for colouring
>>>> the lithological units it works beautifully, but I do not get a
>>>> legend for the composer. But if I set the Properties|Style to
>>>> Categorized and then again select the colour from the Colour column
>>>> in the table I also get the same nicely coloured map according to
>>>> the colour column, an a Legend. But the Legend is wrong...it
>>>> chooses random colours! What am I doing wrong? Is there a way to
>>>> get a correct legend, also only showing the units which are
>>>> actually on the map in the composer. I can set the colours manually
>>>> to match the value in the colour field but that sort of defeats the
>>>> purpose.
>>>> Thanks for your help so long,
>>>> Immo
>>>> *Immo F. Blecher**Street: */52 Lynedoch Eco Village, Lynedoch,
>>>> 7603, South Africa //*Postal:*//52 Lynedoch Eco Village, Lynedoch,
>>>> 7603, South Africa //*Cell:*///+27 83 272 6791 |*Fax: *+27 86
>>>> 7363302 *Email:*_immo at blecher.co.za_ <mailto:immo at blecher.co.za> |
>>>> _immob19 at gmail.com_ <mailto:immob19 at gmail.com>|
>>>> _immob at mymtnmail.co.za <mailto:immob at mymtnmail.co.za>
>>>> _*Internet:*_http://www.blecher.co.za/_
>>>> _______________________________________________
>>>> qgis-za-user mailing list
>>>> https://lists.osgeo.org/mailman/listinfo/qgis-za-user
>> *Immo F. Blecher**Street: */52 Lynedoch Eco Village, Lynedoch, 7603,
>> South Africa //*Postal:*//52 Lynedoch Eco Village, Lynedoch, 7603,
>> South Africa //*Cell:*///+27 83 272 6791 |*Fax: *+27 86 7363302
>> Contact me: immob19 at gmail.com immoblecher
>> <http://www.linkedin.com/pub/immo-blecher/30/414/b8>
>> Please consider your environmental responsibility. Before printing
>> this e-mail message, ask yourself whether you really need a hard copy.
>> IMPORTANT: The contents of this email and any attachments are
>> confidential. They are intended for the named recipient(s) only. If
>> you have received this email by mistake, please notify the sender
>> immediately and do not disclose the contents to anyone or make copies
>> thereof.
*Immo F. Blecher**
Street: */52 Lynedoch Eco Village, Lynedoch, 7603, South Africa
//*Postal:*//52 Lynedoch Eco Village, Lynedoch, 7603, South Africa
_immob19 at gmail.com_ <mailto:immob19 at gmail.com>| _immob at mymtnmail.co.za
Please consider your environmental responsibility. Before printing this
confidential. They are intended for the named recipient(s) only. If you
thereof.
URL: <http://lists.osgeo.org/pipermail/qgis-za-user/attachments/20170717/5ef714fb/attachment.html>
More information about the qgis-za-user mailing list
