[QGIS-ZA-user] South African CRSs in QGIS
Immo Blecher
immo at blecher.co.za
Wed Nov 14 22:52:07 PST 2018
Morning Frank,
This is exactly the one I am using but it has proj 493. I will do a
complete removal and install again, maybe some older files remain due to
dependencies?
Thanks for all your help.
Regards
Immo
On 2018/11/14 08:37, Frank Sokolic via qgis-za-user wrote:
> Hi Immo,
> This is the repository I'm using:
> deb https://qgis.org/ubuntu cosmic main
> When I install QGIS 3.4 from this repository it loads Proj 5.1.0 which
> contains the CRSs I listed in my earlier post.
> Frank.
> On 2018/11/14 07:58, Immo Blecher via qgis-za-user wrote:
>> Good Morning,
>> I think the "latest" proj4 probably sits with the ubuntugis-unstable
>> version. And I am on Ubuntu 18.04 LTS, which apparently does not
>> support the latest ubuntugis-unstable. Or did anybody get it
>> installed and working?
>> Regards
>> Immo
>> On 2018/11/13 19:16, Paul Young via qgis-za-user wrote:
>>> Hi there I tried to pul the Docker Proj4 and it would not upgrade.
>>> It gave: Rel. 4.9.3, 15 August 2016
>>> Maybe it needs to be compiled from source?
>>> On Tue, 13 Nov 2018 at 12:24, Immo Blecher via qgis-za-user
>>> <qgis-za-user at lists.osgeo.org <mailto:qgis-za-user at lists.osgeo.org>>
>>> wrote:
>>> Hi Frank,
>>> That is weird! I am on 3.4, but installed from the Debian link,
>>> not the ubuntugis as there I had dependency issues. Maybe there
>>> is still a big difference between the two. But I will try the
>>> ubuntugis route again. The proj version obviously makes all the
>>> difference.
>>> Regards
>>> Immo
>>> On 2018/11/13 12:20, Frank Sokolic via qgis-za-user wrote:
>>>> Hi Immo,
>>>> Not sure why they don't show up for you. I can see them on QGIS
>>>> 3.14 and the Proj version is 5.1.0. This is on Ubuntu Linux.
>>>> Regards, Frank.
>>>> On 2018/11/13 11:31, Immo Blecher via qgis-za-user wrote:
>>>>> Hi QGIS Users,
>>>>> I can't find these in my QGIS 3.4. And I see that Proj4 is
>>>>> still on version 4.93, but the latest seems to be 5.2.
>>>>> But what I also noticed is that Proj4 changed the way it
>>>>> converts from/to Hartebeesthoek94 (15 to 31) from version 4.7
>>>>> to vers. 4.9: Using proj4 4.7 to convert one had to turn
>>>>> around E-W and N-S, w.o.w. X = -X and Y = -Y and then convert.
>>>>> From vers. 4.9 this was not necessary any longer so I think
>>>>> the calculations in QGIS should be sorted out (it is actually
>>>>> a bug and that is why everything is upside down and
>>>>> right=left). That would also mean that we would not need the
>>>>> ZANGI:ZANGI projections any longer but just use the built-in
>>>>> Hartebeesthoek94 ones.
>>>>> For what it's worth!
>>>>> Immo
>>>>> On 2018/11/13 10:58, Frank Sokolic via qgis-za-user wrote:
>>>>>> Hi QGIS users,
>>>>>> I noticed last week that these CRSs have appeared in QGIS
>>>>>> under Project Coordinate Systems > Transverse Mercator:
>>>>>> EPSG:102480 Hartebeesthoek94_Lo15
>>>>>> EPSG:102481 Hartebeesthoek94_Lo17
>>>>>> EPSG:102482 Hartebeesthoek94_Lo19
>>>>>> EPSG:102483 Hartebeesthoek94_Lo21
>>>>>> EPSG:102484 Hartebeesthoek94_Lo23
>>>>>> EPSG:102485 Hartebeesthoek94_Lo25
>>>>>> EPSG:102486 Hartebeesthoek94_Lo27
>>>>>> EPSG:102487 Hartebeesthoek94_Lo29
>>>>>> EPSG:102488 Hartebeesthoek94_Lo31
>>>>>> EPSG:102489 Hartebeesthoek94_Lo33
>>>>>> EPSG:102562 Hartebeesthoek94_Lo19_(E-N)
>>>>>> EPSG:102563 Hartebeesthoek94_Lo21_(E-N)
>>>>>> EPSG:102564 Hartebeesthoek94_Lo23_(E-N)
>>>>>> EPSG:102565 Hartebeesthoek94_Lo25_(E-N)
>>>>>> EPSG:102566 Hartebeesthoek94_Lo27_(E-N)
>>>>>> EPSG:102567 Hartebeesthoek94_Lo29_(E-N)
>>>>>> EPSG:102568 Hartebeesthoek94_Lo31_(E-N)
>>>>>> Anyone know anything about them? Are these now the official
>>>>>> South African CRSs in the EPSG database? If so, where are
>>>>>> L015_(E-N), L017_(E-N) and L033_(E-N)?
>>>>>> With these new additions, there are now a few versions of the
>>>>>> South African CRSs in the QGIS CRS database (e.g. EPSG 2046
>>>>>> to EPSG 2055 as well as ZANGI:HBKNO15 to ZANGI:HBK033) so I
>>>>>> guess things need to be cleaned up.
>>>>>> Regards, Frank.
>>>>>> _______________________________________________
>>>>>> qgis-za-user mailing list
>>>>>> https://lists.osgeo.org/mailman/listinfo/qgis-za-user
>>>>> *Immo F. Blecher**
>>>>> Street: */36 Saffraan Ave., Die Boord, Stellenbosch, 7613,
>>>>> South Africa
>>>>> //*Postal:*//PO Box 74, Lynedoch, 7603, South Africa
>>>>> //*Cell:*///+27 83 272 6791 |*Fax: *+27 86 736 3302
>>>>> *Email:*_immo at blecher.co.za_ <mailto:immo at blecher.co.za> |
>>>>> _immob19 at gmail.com_ <mailto:immob19 at gmail.com>|
>>>>> _immob at mymtnmail.co.za <mailto:immob at mymtnmail.co.za>
>>>>> _*Internet:*_http://www.blecher.co.za/_
>>>>> Contact me: immob19 at gmail.com <mailto:immob19 at gmail.com>
>>>>> immoblecher
>>>>> <http://www.linkedin.com/pub/immo-blecher/30/414/b8>
>>>>> Please consider your environmental responsibility. Before
>>>>> printing this e-mail message, ask yourself whether you really
>>>>> need a hard copy.
>>>>> IMPORTANT: The contents of this email and any attachments are
>>>>> confidential. They are intended for the named recipient(s)
>>>>> only. If you have received this email by mistake, please
>>>>> notify the sender immediately and do not disclose the contents
>>>>> to anyone or make copies thereof.
>>> *Immo F. Blecher**
>>> Street: */36 Saffraan Ave., Die Boord, Stellenbosch, 7613, South
>>> Africa
>>> immoblecher
>>> need a hard copy.
>>> confidential. They are intended for the named recipient(s) only.
>>> If you have received this email by mistake, please notify the
>>> sender immediately and do not disclose the contents to anyone or
>>> Regards
>>> Paul Young
>>> Home: +27 (0) 31 5662608
>>> Work: +27 (0) 87 9432416
>>> Mobile: +27 (0) 84 2471544 / +27 (0) 604141439
>>> Google+ <http://google.com/+PaulYoung1969> ; LinkedIn
>>> <https://www.linkedin.com/in/paulysa1969> ; FaceBook
>>> <https://www.facebook.com/paulysa1969> ; Twitter
>>> <https://www.twitter.com/paulysa1969> ; Instagram
>>> <https://www.instagram.com/paulysa1969> ; Pinterest
>>> <https://za.pinterest.com/paulysa1969> ; SnapChat
>>> <https://www.snapchat.com/add/paulysa1969>
>>> N�n�r����)em�h�yhiם�w^���
>> *Immo F. Blecher**
>> Street: */36 Saffraan Ave., Die Boord, Stellenbosch, 7613, South Africa
>> Contact me: immob19 at gmail.com immoblecher
>> Please consider your environmental responsibility. Before printing
>> this e-mail message, ask yourself whether you really need a hard copy.
>> confidential. They are intended for the named recipient(s) only. If
>> you have received this email by mistake, please notify the sender
>> immediately and do not disclose the contents to anyone or make copies
>> thereof.
*Immo F. Blecher**
_immob19 at gmail.com_ <mailto:immob19 at gmail.com>| _immob at mymtnmail.co.za
Please consider your environmental responsibility. Before printing this
confidential. They are intended for the named recipient(s) only. If you
thereof.
URL: <http://lists.osgeo.org/pipermail/qgis-za-user/attachments/20181115/03db1722/attachment-0001.html>
More information about the qgis-za-user
