[QGIS-ZA-user] Creating batch jobs from using Grass inside QGIS 3.4
Zoltan Szecsei
zoltans at geograph.co.za
Fri Sep 13 07:43:16 PDT 2019
Ha!
Looks good.
Thanks Admire.
Regards,
Zoltan
On 2019/09/13 16:32, admire via qgis-za-user wrote:
> Hi Zoltan
> On 2019/09/13 14:43, Zoltan Szecsei via qgis-za-user wrote:
>> Hi Listers,
>> I'm using Grass 7.6 inside QGIS 3.4 (installed via OSGEO4W64)
>> I'm needing to set up a chain of tasks involving rasterizing
>> polygons, thinning them and putting them back into vector formats.
>> There are many steps involved, and I am experimenting with a large
>> number of parameters available in each step - so doing this through
>> the GUI is tedious.
>> Is there a way to capture the grass commands and parameters I have
>> chosen in the GUI?
>> I have traced much of them into users/appdata/local/blah blah, but
>> then they reference other files wherein my GUI params are listed, and
>> piecing this lot together, as my first attempt at using Grass, is not
>> massively intuitive (no, I have not RTFM'd :-) )
> If you are using the algorithms from the processing toolbox you simply
> have to navigate to the Processing Menu > History and you will see
> that each algorithm has been captured
> as a processing.run with all the parameters captures there. You can
> then just run the processing.run() algorithms within the python
> console or create a script that will incorporate them.
> Regards
>> If I can create a batch file chaining all the steps together, I could
>> then run and tweak that in powershell (or even cmd.exe) - and test
>> different options more quickly.
>> Thanks for any pointers that might be offered.
>> Regards,
>> Zoltan
>> PS: Yes, I could go through the Grass manuals and see all the params,
>> but hacking is so much easier :-)
> qgis-za-user mailing list
> qgis-za-user at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-za-user
Zoltan Szecsei GPrGISc 0031
Geograph (Pty) Ltd.
GIS and Photogrammetric Services
P.O. Box 7, Muizenberg 7950, South Africa.
Mobile: +27-83-6004028
Qatar: +974 5083 2722 www.geograph.co.za
More information about the qgis-za-user
