[QGIS-ZA-user] Adding NGI data as base layers in QGIS
    Frank Sokolic
    sokolic at worldonline.co.za
    Wed Aug 12 00:30:30 PDT 2020
Hi QGIS users,
Every now and then I get asked how to add aerial photos as base layers
in QGIS projects so I thought I'd share this method with you. We are
very lucky in South Africa as National Geo-spatial Information (NGI)
have made it so easy to access their spatial data. One can quickly add
their colour aerial photos, 1:50000 and 1:250000 topo maps, or landcover
maps to QGIS using these simple steps:
Step 1: Select the following text and save it as a text file with an xml
extension, e.g. NGI_WMS.xml:
<!DOCTYPE connections>
<qgsWMSConnections version="1.0">
     <wms
       name="NGI WMS"
url="http://apollo.cdngiportal.co.za/erdas-iws/ogc/wms/CDNGI_PORTAL_BACKDROP"
       username=""
       password=""
       referer=""
       dpiMode="7"
       ignoreAxisOrientation="false"
       smoothPixmapTransform="false"
       invertAxisOrientation="false"
       ignoreGetMapURI="false"
       ignoreGetFeatureInfoURI="false"
</qgsWMSConnections>
Step 2: In QGIS open the Data Source Manager, e.g. by clicking <Ctrl>+L
or from the menu: Layer > Data Source Manager.
Step 3: Highlight the WMS/WMTS tab.
Step 4: Click the Load button, navigate to where you saved the xml file
in Step 1 and select the file.
Step 5: Choose the connection called NGI WMS and import it. You have now
created a connection to the WMS server that hosts the NGI spatial layers.
Step 6: In the Data Source Manager WMS/WMTS tab, make sure that NGI WMS
is selected in the drop-down list and then click the Connect button.
After a few seconds a list of available layers will display.
Step 7: Select/highlight a layer in the list and click Add to add it to
your QGIS project.
You might see the words "Returned legend is flawed" in the Layers Panel.
I think that this is due to a configuration issue with the WMS on the
server and is not a QGIS bug.
Regards, Frank.
More information about the qgis-za-user
