[QGIS-ZA-user] Adding NGI data as base layers in QGIS
Dean Peters
deangis at msn.com
Wed Aug 12 05:09:04 PDT 2020
Hi Frank
Thank you so much. This is a great resource to be able to access.
Regards
Dean Peters
From: qgis-za-user <qgis-za-user-bounces at lists.osgeo.org> on behalf of Frank Sokolic via qgis-za-user <qgis-za-user at lists.osgeo.org>
Sent: Wednesday, 12 August 2020 07:30
To: qgis-za-user at lists.osgeo.org <qgis-za-user at lists.osgeo.org>
Cc: Frank Sokolic <sokolic at worldonline.co.za>
Subject: [QGIS-ZA-user] Adding NGI data as base layers in QGIS
Hi QGIS users,
Every now and then I get asked how to add aerial photos as base layers
in QGIS projects so I thought I'd share this method with you. We are
very lucky in South Africa as National Geo-spatial Information (NGI)
have made it so easy to access their spatial data. One can quickly add
their colour aerial photos, 1:50000 and 1:250000 topo maps, or landcover
maps to QGIS using these simple steps:
Step 1: Select the following text and save it as a text file with an xml
extension, e.g. NGI_WMS.xml:
<!DOCTYPE connections>
<qgsWMSConnections version="1.0">
<wms
name="NGI WMS"
url="http://apollo.cdngiportal.co.za/erdas-iws/ogc/wms/CDNGI_PORTAL_BACKDROP"
username=""
password=""
referer=""
dpiMode="7"
ignoreAxisOrientation="false"
smoothPixmapTransform="false"
invertAxisOrientation="false"
ignoreGetMapURI="false"
ignoreGetFeatureInfoURI="false"
</qgsWMSConnections>
Step 2: In QGIS open the Data Source Manager, e.g. by clicking <Ctrl>+L
or from the menu: Layer > Data Source Manager.
Step 3: Highlight the WMS/WMTS tab.
Step 4: Click the Load button, navigate to where you saved the xml file
in Step 1 and select the file.
Step 5: Choose the connection called NGI WMS and import it. You have now
created a connection to the WMS server that hosts the NGI spatial layers.
Step 6: In the Data Source Manager WMS/WMTS tab, make sure that NGI WMS
is selected in the drop-down list and then click the Connect button.
After a few seconds a list of available layers will display.
Step 7: Select/highlight a layer in the list and click Add to add it to
your QGIS project.
You might see the words "Returned legend is flawed" in the Layers Panel.
I think that this is due to a configuration issue with the WMS on the
server and is not a QGIS bug.
Regards, Frank.
qgis-za-user mailing list
https://lists.osgeo.org/mailman/listinfo/qgis-za-user
URL: <http://lists.osgeo.org/pipermail/qgis-za-user/attachments/20200812/be1702e7/attachment.html>
More information about the qgis-za-user
