[QGIS-ZA-user] SOLVED: Re: Field calculator issue - QGIS version,3.10.1-A Coruña on Win10 via OSGEO4W64
Neil Falconer
nfalconersa at gmail.com
Fri May 8 08:53:08 PDT 2020
Yup, I agree but see you found the issue. Cheers Neil
On Fri, 8 May 2020, 16:51 Zoltan Szecsei via qgis-za-user, <
qgis-za-user at lists.osgeo.org> wrote:
> Hi Neil,
> Nope - an integer should be able to be cast as 'double'
> Thanks for the interest, though.
> Regards,
> Zoltan
> On 2020/05/08 17:37, Neil Falconer via qgis-za-user wrote:
> Hi Zoltan, Seems crazy but could it possibly be because the 17 is an
> integer...if it was 17.0 it would be recognised as a Double? Regards Neil
> On Fri, 8 May 2020, 16:04 Zoltan Szecsei via qgis-za-user, <
>> Hiya,
>> Blooming decimal point/comma issue :-(
>> Thanks anyway,
>> Zoltan
>> On 2020/05/08 16:26, Zoltan Szecsei via qgis-za-user wrote:
>> Hi,
>> Can anyone shed light on why I get: Eval Error: Cannot convert '[LonM]'
>> to double
>> from this expression:
>> if( "LonD" IS 'Longitude' , 0.0, "LonD" + ( "LonM" / 60.0 ))
>> I've pulled a CSV file into 'Layer' and failed to generate Point using
>> Toolbox->Geometry by Expression, so I am now trying to create decimal Deg
>> columns (virtual).
>> The first few lines in the CSV are:
>> Num,LonD,LonM,LonS,DirE,LatD,LatM,LatS,DirN
>> A1,Longitude,Latitude,,,,
>> 1,17,25.00,0.0,E,23,7.53,0.0,N
>> 2,17,25.10,0.0,E,23,7.52,0.0,N
>> Thanks and regards,
>> Zoltan
>> Zoltan Szecsei GPrGISc 0031
>> Geograph (Pty) Ltd.
>> GIS and Photogrammetric Services
>> P.O. Box 7, Muizenberg 7950, South Africa.
>> Mobile: +27-83-6004028 (Best option: WhatsApp)
>> India: +91 83418 01616
>> Qatar: +974 5083 2722 www.geograph.co.za
>> qgis-za-user mailing listqgis-za-user at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/qgis-za-user
>> Geograph (Pty) Ltd.
> Geograph (Pty) Ltd.
URL: <http://lists.osgeo.org/pipermail/qgis-za-user/attachments/20200508/1e7ef1e6/attachment.html>
More information about the qgis-za-user
