[QGIS-ZA-user] How to add Google Earth Satellite on Qgis
Mahlape Ramahloko rmahlape at gmail.com
Sun Sep 6 20:03:12 PDT 2020
Thanks, I'll check it out.
Regards
On Sun, 06 Sep 2020, 06:19 Gavin Taylor, <gavin.taylor.gis at gmail.com> wrote:
> Hi Mahlape
> If you run this script in your python console it will automatically add a
> bunch of xyz tile layers for you to use as base maps:
> https://github.com/klakar/QGIS_resources/blob/master/collections/Geosupportsystem/python/qgis_basemaps.py
> If you are on a company network then you may need to change the proxy
> settings in Qgis for the layers to render.
> Regards
> Gavin
> On Sun, 06 Sep 2020, 6:48 AM Mahlape Ramahloko via qgis-za-user, <
> qgis-za-user at lists.osgeo.org> wrote:
>> Thank you for your response.
>> Regards
>> On Fri, Sep 4, 2020 at 4:25 PM Frank Sokolic via qgis-za-user <
>>> Dear Mahlape,
>>> You can do it by installing the QuickMapServices plugin from the Plugin
>>> menu and then activating the "Contributed Pack" by clicking:
>>> Web > QuickMapServices > Settings > More services > Get contributed pack.
>>> Now you can go to Web > QuickMapServices > Google and select the Google
>>> layer you need.
>>> Regards, Frank.
>>> On 2020/09/04 14:46, Mahlape Ramahloko via qgis-za-user wrote:
>>> Good Afternoon,
>>> I am trying to add Google Earth Image in QGIS. I right clicked on XYZ
>>> tiles and selected new connections. I copied and pasted the URL address
>>> that I found on Google earth website. This is the URL I used and nothing
>>> happened. Kindly assist.
>>> https://earth.google.com/web/@0,0,0a,22251752.77375655d,35y,0h,0t,0r
>>> regards
>>> qgis-za-user mailing listqgis-za-user at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/qgis-za-user
URL: <http://lists.osgeo.org/pipermail/qgis-za-user/attachments/20200907/d8011059/attachment.html>
More information about the qgis-za-user mailing list
