[QGIS-ZA-user] qgis-za-user Digest, Vol 53, Issue 2
Immo Blecher immob19 at gmail.com
Tue Apr 2 03:27:31 PDT 2024
Hi Jordaan and list,
I found that one of the "best" coordinate conversion tools is at
https://twcc.fr/en/# where you can convert them manually or from a CSV.
It also gives you the option of checking if you are in the right place
with different background maps. You can then use the converted list to
plot the points in QGIS.
Regards
Immo
On 2024/04/02 11:34, Jordaan Fouche via qgis-za-user wrote:
> Thank you Ryk
> Could you please attach the spreadsheet.
> I have learnt by now that if I flip the X,Y coordinates and then use EPSG
> 22287 in QGIS, I land up in the correct area (more or less on the correct
> farm). That solution I have learnt from the PlanetGIS documentation. An
> error of 300m should be acceptable for my purpose (for now).
> Best regards
> Jordaan Fouche
> Portion 11
> Van Reenen Country Estate
> Van Reenen
> 3372
> Republic of South Africa
> Tel: +27 (0)82 555 4227
> -----Original Message-----
> From: qgis-za-user<qgis-za-user-bounces at lists.osgeo.org>  On Behalf Of
> qgis-za-user-request at lists.osgeo.org
> Sent: Tuesday, April 2, 2024 11:12 AM
> To:qgis-za-user at lists.osgeo.org
> Subject: qgis-za-user Digest, Vol 53, Issue 2
> Send qgis-za-user mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
> 	https://lists.osgeo.org/mailman/listinfo/qgis-za-user
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> 	qgis-za-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific than
> "Re: Contents of qgis-za-user digest..."
> Today's Topics:
>     1. Re: Coordinate conversion from Cape Datum Lo27? to EGS 84
>        (Ryk Taljaard)
> Message: 1
> Date: Tue, 2 Apr 2024 10:32:58 +0200
> From: "Ryk Taljaard"<ryk at boundaryhunter.co.za>
> To: "'South Africa QGIS user group'"<qgis-za-user at lists.osgeo.org>
> Subject: Re: [QGIS-ZA-user] Coordinate conversion from Cape Datum
> 	Lo27? to EGS 84
> Message-ID:<00be01da84d8$5e964640$1bc2d2c0$@co.za>
> Content-Type: text/plain; charset="utf-8"
> I use the attached spreadsheet for calculation of CAPE to WGS84
> transformation of coordinate values, for data obtained from specific SG
> diagrams.
> TRIG 1 is the trig beacon closest to the study area and the resulting values
> used for the relevant transformation calculation.
> TRIG 2 is 2nd closest to the study are and used only for indication of any
> possible gross error.
> Take note of:
> (1) The pos/neg switch of coordinate values required for GIS purposes and
> (2) Beware of the study area, TRIG1 and TRIG2 being located in different
> LO-systems.
> Mowbray makes available the localities of all TRIG beacons in KML format, as
> well as the coordinates of all TRIG beacons in both Clarke1880 and WGS84 in
> TXT format, to use as input to the attached spreadsheet.
> Best regards
> Ryk Taljaard
> Boundary Hunter
> Mobile: 082 895 2906
> 1 Joerning Street * Paarl * 7646 * SOUTH AFRICA
> Web:<http://www.boundaryhunter.co.za/>  www.boundaryhunter.co.za  * Email:
> <mailto:ryk at boundaryhunter.co.za>  ryk at boundaryhunter.co.za
> From: qgis-za-user [mailto:qgis-za-user-bounces at lists.osgeo.org] On Behalf
> Of Gavin Fleming via qgis-za-user
> Sent: Tuesday, 02 April 2024 09:51
> To: South Africa QGIS user group
> Cc: Gavin Fleming
> Subject: Re: [QGIS-ZA-user] Coordinate conversion from Cape Datum Lo27? to
> EGS 84
> Hi Jordan and thanks FC
> I?m not sure how FC did the projection / transformation but you can use
> QGIS, proj or a number of other tools.
> An issue to be aware of is that no GIS will do an accurate datum
> transformation from Cape to WGS84/Hartebeeshoek94 since there are different
> errors all over the country, as much as 300m. If you need accuracy, rather
> speak to a land surveyor, who can do a local transformation taking into
> account the known errors.
> Gavin
> On 22 Mar 2024, at 09:25, Jordaan Fouche via qgis-za-user
> <qgis-za-user at lists.osgeo.org>  wrote:
> Thank you FC, what software did you use to do the transformation?
> Could you explain in a bit more detail?
> Jordaan Fouche
> Portion 11
> Van Reenen
> 3372
> From: FC Basson<FC.Basson at westerncape.gov.za>
> Sent: Thursday, March 21, 2024 8:26 PM
> Cc:j.fouche9 at gmail.com
> EGS 84
> Just a slight edit to the Google Maps link:
> https://maps.app.goo.gl/VVS9XDfhjp88dXw97
> And if you prefer OSM:
> https://www.openstreetmap.org/?mlat=-26.82808180999955
> <https://www.openstreetmap.org/?mlat=-26.82808180999955&mlon=28.591287809999
> 518#map=12/-26.8281/28.5913>
> &mlon=28.591287809999518#map=12/-26.8281/28.5913
>    _____
> From: qgis-za-user<qgis-za-user-bounces at lists.osgeo.org>  on behalf of FC
> Basson via qgis-za-user<qgis-za-user at lists.osgeo.org>
> Sent: 21 March 2024 20:09
> To:qgis-za-user at lists.osgeo.org  <qgis-za-user at lists.osgeo.org>
> Cc: FC Basson<FC.Basson at westerncape.gov.za>;j.fouche9 at gmail.com
> <j.fouche9 at gmail.com>
> EGS 84
> I was able to locate the farm and can confirm that the coordinate should be
> in LO 29.
> <image001.png>
> For GIS purposes, we use the rotated coordinate system, so the coordinates
> should be X: -40600, Y: -2968350, which converts to geographic coordinate of
> Lat: -26.828082, Lon: 28.591288, if you assume the input datum is Cape.  And
> here is a link to the location in Google Maps:
> https://maps.app.goo.gl/bEwU4pMa35Db2gpNA
> Regards
> FC Basson
>    _____
> Jordaan Fouche via qgis-za-user<qgis-za-user at lists.osgeo.org>
> Sent: 21 March 2024 17:14
> Cc:j.fouche9 at gmail.com  <j.fouche9 at gmail.com>
> Subject: [QGIS-ZA-user] Coordinate conversion from Cape Datum Lo27? to EGS
> 84
> Have a set of old borehole data that I wish to plot in QGIS.
> They were clearly drilled pre 1994 (Hartebeesthoek) and I am really
> struggling to plot them on QGIS. I suspect they may be Cape Datum.
> The example that I am including is on the farm Rietvley 600 in the Balfour
> district.
> The coordinates are legible as X:2968350;Y: 40600.
> Can somebody please help me.
> Jordaan Fouche
> Portion 11
> Van Reenen
> 3372
> "All views or opinions expressed in this electronic message and its
> attachments are the view of the sender and do not necessarily reflect the
> views and opinions of the Western Cape Government (the WCG). No employee of
> the WCG is entitled to conclude a binding contract on behalf of the WCG
> unless he/she is an accounting officer of the WCG, or his or her authorised
> representative.
> The information contained in this message and its attachments may be
> confidential or privileged and is for the use of the named recipient only,
> except where the sender specifically states otherwise.
> If you are not the intended recipient you may not copy or deliver this
> message to anyone."
> representative.
> message to anyone."
>   <mailto:qgis-za-user at lists.osgeo.org>  qgis-za-user at lists.osgeo.org
> <https://lists.osgeo.org/mailman/listinfo/qgis-za-user>
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL:
> <http://lists.osgeo.org/pipermail/qgis-za-user/attachments/20240402/4b56dfed
> /attachment.htm>
> A non-text attachment was scrubbed...
> Type: application/vnd.ms-excel
> Desc: not available
> URL:
> /attachment.xls>
> Subject: Digest Footer
> End of qgis-za-user Digest, Vol 53, Issue 2
*Immo F. Blecher**
*/*Mobil(e):*///+491512 639 6176 | +27 83 272 6791
*Tel.:* +49 5508 449 0071
*Email:*_immo at blecher.co.za_ <mailto:immo at blecher.co.za> |
_immob19 at gmail.com_ <mailto:immob19 at gmail.com>
*Internet:*_https://www.blecher.co.za_ <https://www.blecher.co.za/> |
_https://aquabase.blecher.co.za_ <https://www.blecher.co.za/>
Please consider your environmental responsibility. Before printing this
e-mail message, ask yourself whether you really need a hard copy.
*IMPORTANT*: The contents of this email and any attachments are
confidential. They are intended for the named recipient(s) only. If you
have received this email by mistake, please notify the sender
immediately and do not disclose the contents to anyone or make copies
thereof.
URL: <http://lists.osgeo.org/pipermail/qgis-za-user/attachments/20240402/ba6d1dcd/attachment-0001.htm>
More information about the qgis-za-user mailing list
