FW: MODERATE for dev@visibilitycommittee.osgeo.org
Michael P. Gerlek
mpg at lizardtech.com
Fri Mar 3 14:49:47 EST 2006
Ummm... I saw Markus' post go through -- presumably someone did the
'approval'?
-mpg
-----Original Message-----
dev-reject-1141409874.32000.gbdefnahacoelggdpmja at visibilitycommittee.osg
eo.org
[mailto:dev-reject-1141409874.32000.gbdefnahacoelggdpmja at visibilitycommi
ttee.osgeo.org]
Sent: Friday, March 03, 2006 10:18 AM
Cc:
dev-allow-tc.1141409874.ilalejkjdgafcphgpeeb-neteler.osgeo=gmail.com at vis
Subject: MODERATE for dev at visibilitycommittee.osgeo.org
The enclosed message was submitted to the
mailing list. If you'd like to approve it for distribution to all
the subscribers, please e-mail:
dev-accept-1141409874.32000.gbdefnahacoelggdpmja at visibilitycommittee.osg
eo.org
Usually, this happens when you just hit the "reply" button. You can
check the address to make sure that it starts with
"dev-accept". If this does not work, simply copy the
address and paste it into the "To:" field of a new message.
To reject the post and cause it to be returned to the
sender, please send a message to:
eo.org
Usually, it is easiest to hit the "reply-to-all" button, and then
remove all the addresses except the one starting with
"dev-reject".
You do not need to copy the post in your response to accept or
reject it. If you wish to send a comment to the sender of a rejected
post, please include it between two marker lines starting with three
percent signs ('%'):
%%% Start comment
%%% End comment
Thank you for your help!
--- Enclosed, please find the posted message.
An embedded message was scrubbed...
From: "Markus Neteler" <neteler.osgeo at gmail.com>
Subject: test only MN
Date: Fri, 3 Mar 2006 10:17:52 -0800
Url: http://lists.osgeo.org/pipermail/viscom-dev/attachments/20060303/0ed770c7/attachment.mht
More information about the Viscom-dev
